Everything posted by Onoff
Got similar fitted to the old ensuite tray. Rearrange the words: like sieve leaks a The fact that to make it work you'd have to load it with CT1 anyway just do away with it and bring the tiles down onto the tray I would.
Keeping rats out of foundation wall penetrations
Onoff replied to WWilts's topic in Waste & Sewerage
Stainless steel "wool" pan scourers from Wilko for example. Jam in and foam in place. In my experience everything from birds to social bees and wasps will have a go at the foam potentially, I've seen it here multiple times. They just seem to sense a nice habitable cavity behind. Best is to then render over the foam. -
I'm all for reinventing the wheel believe me but I did wonder why you didn't go for plastic eaves trays in the first place. If you read the instructions on some of the modern, breathable felts it specifically says about fitting 1/4" thick or so strips along the line of the trusses so the subsequent battens sit up off the felt and allow free drainage.
Ahem...I tend to visit the IoW once a year and have a roof rack...what's the plan for the ST panels once removed? ? Could bring my lad and maybe finally get him a flight with Butterfly Dave!
Another year...another room
Onoff commented on MikeGrahamT21's blog entry in Back on the self-build waggon...
Presume you'll be getting a new telly? Won't that one on the wall be full of dust and soot? -
@Stewpot as I understand it, with the hydrated lime I have here then that's calcium hydroxide. It will, over time turn back into calcium carbonate aka limestone?
Here's a mad thought... Time and techniques have moved ever onward. The issue with using normal cement mortar is one of shrinkage around the flints, frost action and cracking. Could I perhaps lay them in the same 4:1 mortar mix I used for the pillars then when cured just spray them with a water seal like Thompsons or Permagard?
I have seen that before thanks. It would mean changing to natural hydraulic lime and binning the hydrated I have here. I see Lawsons builders merchants near me do it. Certainly not cheap down this way! https://www.lawsons.co.uk/search?q=Hydraulic lime I'm shortly going to knock up a test of: 4 sharp 2 soft (orange builders) 1 lime (hydrated) 1 opc ...and see what that looks like. I am concerned I won't be able to get the demarcation between brickwork and flint panels neat hence back to thinking about a trim.
I quite like the complexity of this mix suggested on another forum: "When doing flint work I use 4 sharp sand, 2 soft washed(building sand), 1 lime and 1 white cement".
Dunno, back to the potential shrinkage/frost pocket worry. So many options. Got myself in a bit of a pickle, a... ...you might say!
Tack some 50x6 ply strips over that bottom OSB up the line of the trusses? If that OSB is just to hide the battens/felt, then cut pieces that sit between the truss ends rather than on them? You'd need a little batten either side flush with the truss tops then screw the infill up to them. Overall though I'd agree, OSB the lot and counterbatten. I'm in the SE too btw. Has other benefits, felt sag allows vermin in. Ask me how I know! ?
I'm coming round to the idea, I can keep the new bag of lime for getting for getting rid of the body... ? The one thing I will say about these sand/lime mixes only is they seem to be getting harder by the day. Is it something to do with them absorbing atmospheric CO2 and eventually reverting to limestone? Video of the 2 sharp / 1 lime sample: Then the 1.5 sharp / 0.5 soft / 1 lime: As I understand the method of laying flints I need to place a board against the wall then hold the flints tight against the board and infill from behind. Quite how that'll turn out when I remove the board I don't know as I'm guessing an opc mortar might dry quicker. Maybe there's an optimum for removing the board with slump and still being able to tidy round the flints. Yet again, soft sand or sharp if I go with opc and no lime? Aiming to start tomorrow whatever and hope!
Bonkers idea or a great idea?
Onoff replied to canalsiderenovation's topic in Landscaping, Decking & Patios
Gotcha! It did look "sprayed" around the plates etc. Würth Zinc Light is an excellent "silver" cold galvanising paint. For a darker zinc then their Zinc Dark. The term "cold galvanising" is a bit misleading tbh - they all come in a can but some are better than others. Zinga is very good. Galvafroid is the old favourite. -
If it doesn't kill you! -
I've watched a jack burrow through a bag of feed to get to the rat's nest behind. -
Bin store is another thing I've seen pallets used for..... -
So the trespassers don't get offended? ?
Like getting an answer from SWMBO! ? Did he buy the lengths of steel "mill finish", weld them together then get the whole assembly galvanised at a place that specialises in hot dip galvanising? Did he weld on plain finish mesh and send the whole lot to the galvanisers or did he get the galv frame back etc? Is your Dad on here, can I ask him??? ?? -
Just playing (again) with laying out the flints I have. Basically got 4 boards and marked the areas to fill. Vague recollection of someone saying aim for a finger width's of mortar between the flints. I do have a set of copper boppers I bought but struggle to shape the flints tbh. I think, in all honesty I'd prefer the mortar for the flints to match the 4:1 I used for the bricks. Is there any way to make it (the mortar) "flexible"? Adding lime I believe acts as a plasticiser, is that the same thing? Tbh I'm not at all happy with the strength of my sample mixes containing just lime & sand. Reading the new lime bag and I'm not sure how I missed where it says it's no good for mortar without cement in the mix! Wondering therefore if a mix containing cement and lime will give strength but also flexibility so the mix doesn't shrink away from the flints?
I remember reading about it as a kid when visiting the Underground Hospital on Jersey.
Galvanised steel frame? Nice! Did you buy ready made or have commissioned specially to size? -
The Germans used I believe coal furnace ash on Jersey etc due to shortages of other materials. A handy by-product was it made for a really strong, long lasting concrete. As evidenced by the still standing fortifications today.
Ask me how I know... ?
Post a picture of the bag the sand came in is easiest sling with a good pic of a handful of the sand. Trying to render with a pure sharp sand mix is a bitch.
Seen loads of cheap FCUs burn out when being run at their limit for long periods. Fitted an MK to the last one and it's lasted.
