Everything posted by ToughButterCup
Wall plate straps (101)
ToughButterCup replied to MortarThePoint's topic in Roofing, Tiling & Slating
Yes, you are right, for us 7.5 concrete screws are perfect. @PeterW reminded me that they should be drilled over-length (10 mm or so) to take account of the dust that you simply cant extract. So for us ( straight into the ICF concrete ) that means a 6mm or maybe 6.5mm SDS hole , bored 110mm ( for a 100mm screw) thats rated 7.5. The grip is fantastic -
Surprised by hip roof trigonometry.
ToughButterCup replied to epsilonGreedy's topic in Roofing, Tiling & Slating
Here's a link to the sections of the Skillbuilder YooChube site which might just help you. I am afraid I didn't understand your problem statement. https://www.youtube.com/c/SkillBuilder/search?query=hip Discussion of hips in our family usually centres on the amounts of Paracetamol and Anti Inflamatory pills taken. -
MDF primer
ToughButterCup replied to Russell griffiths's topic in General Self Build & DIY Discussion
Another vote from personal experience for Zinser. But, I'm thinking about changing: why....? Here's an expert on the subject - he does much of his work in MDF. And here's the playlist which will give you a really good insight into the hiccups that can occur with things like raised grain and so on. (water-based paint sometimes raises the grain on MDF - just needs a bit of sanding to rectify, that's all.). For another perspective, Alistair Johnson takes you through the paints he uses on built-in furniture (often MDF) and why. Very detailed (order numbers and so on) Ian -
Any good build-related books?
ToughButterCup replied to Mulberry View's topic in General Self Build & DIY Discussion
Delegate. -
And, in the context of planning, what does ' sustainability ' mean now ? COVID means less trips to the bus stop: no need to walk to some of the shops. Many fewer car journeys. That term - in this context - is in the process of being re-defined.
No. Here's why.... https://youtube.com/c/PeterMillard https://youtube.com/c/FreebirdInteriors Hours and hours of video support not to mention interesting informed opinion.
Hidden cistern toilet frame, thingy
ToughButterCup replied to Russell griffiths's topic in General Plumbing
Geberit do loads of floor-fastened pans. They don't make it easy to order them or to sort out what fits with what. So ring them (in the UK) : the tech / help people are very good indeed. Order from reuter.de, much cheaper (or were when we ordered two) Need help with the German - PM me. Ian -
I wouldn't bother but, apart from laziness, can't tell you why I think that. Oh, I know, our chippie says if you don't need to cut something, don't. Very nice man, very very nice man. -
Tell us please what's immediately above stair No. 1. I ask because if it's a corridor maybe that can be nudged : if its a room, then maybe a cuboid shape can be built into the room to accomodate the stairway height clearance. We put a bed on top of such a 'bodge'. Kids loved it. If on the other hand it's a load of plumbing or a window, then ..... ? PS reading Dave's reply, I think I may have misunderstood .... apologies if I have. I cant see why stair 3 is an issue ... it seems like there's plenty of clearance. Cheap glasses?
When I tried to find some online, I couldn't at a sensible price - Lancashire BMs simply don't sell them ( "No call for em mate" : " So my request doesn't count then?" ) Ended up with the Tupperware versions and wish I'd spent the money on the metal ones, even tho' they're stoopid prices.
No. I get a discount on some items with two local BMs. As I have come to understand it, there is a commonly held misconception among self builders that they should be able to negociate lower prices because of the volume of money they spend. Mostly ( with the exception of a few serial masochists) self builders are not repeat customers. @BotusBuild : were you to regularly order £1000 of drainage stuf, I'm sure you'd get a discount.
If the data (not programs) on the iPad is iportant to you, then transfer that first - I suggest to a cloud-based account so you can download it later. Then deep (sometimes called Hard, or Factory) reset.
Sounds like the problem is on the iPad. Restart, or Soft Reset or Reset (in that order) it to factory settings. Here are the detailed instructions Uninstall as many programs as you can before doing the deep (factory) level Reset.
Architect - Making the maths add up...
Perhaps a bit late, but is this a help? And this is the pricing structure we used. -
Eco-House Build in Bristol Area
ToughButterCup replied to BristolBuild2020's topic in Introduce Yourself
Four years in and I'm still thinking , no, worrying about that. Not doing what you might reasonably be expected to - how do you know what you don't know? Ask and read here. It will repay the effort, Regards, Ian -
First ever stab at getting a house built
ToughButterCup replied to WWilts's topic in Introduce Yourself
A week, reading this forum. Welcome and good luck -
Hello! Self building a garden room.
ToughButterCup replied to WorksItOut's topic in Introduce Yourself
Right so far. Long may it last. Welcome. Ian -
If my experience is anything to go by, I think so. No stones got jammed in ours. Stones of a certain size 'stick' to it (you can brush them off later) , but thats all.
Highly UNlikely. They haven't the time or resource. But neighbours, axe grinders, bored local weasels, curtain twitchers might. And they could rattle the bush telegraph that wakes a somnolent planner. Who has to react.
Raw plug spec for wallplate strap fixing.
Hmmm, so that Mr Epsilon's question about the humble strap proves anything but boring. I knew it ! -
My (rotten) ASHP. Update.
ToughButterCup replied to zoothorn's topic in Air Source Heat Pumps (ASHP)
'Cladding it' with some sort of housing - while allowing ample air circulation? @zoothorn, could you photograph the offending bit of equipment : might help us help you (?) The thing is, if someone like @SteamyTea says you need your calclations for us to help you, you really do need them. Might you be able to ask for them? -
ICF - a list of questions/thoughts
ToughButterCup replied to mjward's topic in Insulated Concrete Formwork (ICF)
I have a moderate amount of experience with Durisol. Reading this will answer some of your questions. Good luck with your project Ian PS: just a quick thought - order the right number Dursiol of blocks, and re-order a few weeks in advance if you think you might run short. Its not like popping down to the BM for another few blocks of whatever. -
I've re-read this whole thread @zoothorn. I'm left wondering whether you might be (figuratively) using sticky tape to block the holes on a cullendar? Expensive sticky tape. Might you need to think about other ways out of the problem?
