ToughButterCup
    101
Everything posted by ToughButterCup
  1. Cheap is not a good idea with adjustable spanners. Since you mention Amazon, this selection, not the cheapest or most expensive, might well suit. I suggest this range because the jaw action is more precise. You are less likely to slip because the jaws tend to fit more precisely and so have less play.
  2. Save yer pennies. Screw it. @Russell griffiths uses his principally on his fishing trips.
  3. Erm, isolate the shower supply: I suspect you have thought of that, but just in case you haven't......
  4. Right. Wot's next then? Noo smart meter?
  5. Yes. Yes. Here's what I think is the relevant photograph of the screen It's a bit counterintuitive -not to say confusing - to see both Export and Import on the same screen With typical care and attention to detail you say Yes, I do. But I suspect smart meters are not all created equal are they? I doubt whether that figure (1767) is the one to which you refer (export figure) because its labelled Actual Import. But the screen also shows an Export indicator. There's a button on the side of the meter which makes the LCD display illuminate, and allows you to scroll through a series of (I think irrelevant) screens ( date, time, credit mode, meter balance, standing charge) They don't make it easy do they?
  6. I have a SOLIS (Ginlong) inverter with its associated meter. I am trying to find out how much of our self generated power we consume. In trying to answer the question for myself, I have tried to make sense of the SOLIS app. Frankly it's an insult to customers. Looks to me like it was designed by a first year undergrad: mostly it doesn't work. When it does, it provides a meaningless graph. There's no way of downloading and analysing the data. So I'm going back to the raw data. Here are three images from the meter next to the inverter. ( I have uploaded images because I don't understand them - yet) The amount of electricity imported since installed(?) .... amount exported (?) To whom? ... 412.8 ( below) is 413.5 less 0.7, I can see that - does that mean I have consumed 0.7 of a kWh of self-generated electricity? Or does it mean I have made a present of 0.7kWh to the National Grid Can anyone point me to an online resource which will help me sort this out for myself. Thanks for your help.....
  7. @Tony K, notwithstanding the above response ( @scottishjohn), now's the time for a bit of 'wider' thinking. If my few years' reading on the subject is to be believed, your problem is common. Look at your topography. Take a deep core maybe , after researching your local topography? Shingle? Sandstone? Mudstone? Flat? Completely flat? If it is not, can you consider making a pond? If so, duct the rainwater into it. Overflow to mains perhaps? How far away is the nearest stream? Discharge to that?
  8. Ask them. When I talked to them about an issue, they were very helpful. 01530 513000
  9. You can excite Nigella with a white box on a wall? Respect. Wonderment. (Liar?)
  10. Straight: sides unsupported. Godda have a challenge every now and then..
  11. Ok folks. I ppreciate the caution. I know it's my responsibility. To calm your nerves, heres what I propose, demonstrated on an empty block. This is a plan view. The concrete is I00mm thick, (the empty space).Theres 40mm of block - I propose a 150mm shelf supported by the M12 threaded bar embedded in at least 90 to 100 mm of concrete and 40mm of block. To me, the highest risk is of drilling the holes in the block wall where two blocks join. So I'll do some pilot holes to make sure I hit concrete. Then embed the M12 in the shelf last.
  12. Phhhhhhhhhhh. Haste and spell-checkers dont go together.....
  13. Agreed. But. Lets see what 150mm does. They just look so neat. Thanks both. Ian
  14. I have about 100 meters of m12 threaded bar leftover from earlier traumas. I could use some of it as the support for floating shelves. SWMBO wants shelves. In her panty. I'm thinking using 25 mm MDF (MRMDF) with the 12mm bar inserted into the MDF about I00mm. I say inserted - I mean epoxied. The shelves are planned at 200 mm wide. The bar will be held by the concrete (ICF) How deep should I drill the holes to hold the bar? 200mm? 100mm?
  15. Vee ken not get everysink Korrect.
  16. Borrow another ladder with a ladder standoff - or make your own temporary standoff. Here's an example and make sure the ladder goes way past your gutter, otherwise your knees will suffer (again). Make sure the bottom of the ladder is braced properly (If I can I often use our car for that ) so that the bottom of the lowest ladder (of the three) cannot move under any circumstances. As to the gutter - use your judgement : I'd remove it but I suspect that removing it might cause more aggro for you. Make sure you can step easily from the lowest ladder onto the roof ladder safely. You might like to ask someone to stand and steady the ladder (as well as having jammed the bottom of it against something immovable ) to increase the level of safety. Make sure also that you can use both hands while on the ladder. In other words, haul tools up after you have climbed to where you need to work. Only move one of your limbs at one time: three points of bodily contact at all times. If it's wet don't climb. Oh FFS where do you live? I'll come and give you a hand........
  17. Errrrm, how did you get the ladder there in the first place? And did you hurt your knees on the gutter?
  18. Welcome - at last someone who's prepared to admit they have building experience. What does your instinct tell you? And what does you experience tell you? Put one next to the other. Cogitate. Then come back here and tell us. 4000 + members, and at least 8000 opinions eh?
  19. How often have you over-filled yours ? Is so easy to end up with a boot full of red.
  20. Can I suggest those of us who are spending many thousands of pounds invest in a copy of SPONS Architects Price Guide? Yes it costs £120 ish, and takes some effort to dig in to, but saves fuss and difficult conversations. Far in excess of its cost. It gives you hard objective evidence. For non professionals spending lots of cash, its invaluable. It comes with a license for the electronic version , and that makes for high speed research. Every time I post this response to pricing threads I get a stream of PMs asking me to price something based on my copy of SPONS. Usually I can help, but my copy has vaporised recently. Proof of its value maybe? I have no financial interest in the book
  21. Yes, of course I can Russ. But my common sense isn't that common.
  22. Thanks everyone. Much appreciated. Ian
  23. ... apart from knocking the house down and starting again..... I'm told we've all done it, so we've all sorted it out. Help me not to cock the repair up please. Ta!
  24. Fabulous! Is that a sixern ?
