Russell griffiths
    65
  1. Whilst we are on the subject of icf, I spoke recently to a rep of one of the major suppliers, regarding thicker insulation on the outside skin of their blocks he said it was funny how in Canada they just use the standard block and it is only the uk market that ask for thicker blocks. Are we over thinking u values, or do the Canadians not mind having a heating bill. I do wonder about having 400mm thick walls and then a sliding door 5.5m wide slap bang in the middle of it. Thoughts.
  2. Our planning consultant charged me £90 per hour so you won’t get a lot for £600 if you are thinking of more then 1 plot then I wouldn’t be scrimping,
  3. This table is very handy for me so thanks for doing it, however it is based on a lot of figures rather than a lot of the points I have thought of when trying to decide which icf. My main thoughts were ease of use, how user friendly is the product ? second fixing, if you need to fit battens how will they fix ? how does the reinforcement fix, does it need tying in or does it lock in ? Having to tie the reo at corners will take time. How neat do the blocks look after they have been filled. I have viewed two sites near to me using icf, one looks neat and tidy and easy to clad, the other looks as though you will need to pack a lot of the battens or rasp down areas that look a bit wonky. Just my take on it, I will get a couple of quotes but won’t be picking the cheapest. However the cheapest one on your list is one I liked. ?
  4. Well done, house looks spot on. you have probably got another pile of paperwork to deal with when you start the demolition. ?
  5. I think it is easy to find a pic of a poor installation of anything, standard practice would be that any pipes should be clipped where they come into contact with an object and as peter said the metal webs have nicely rounded edges to protect cables when they are being yanked about. More concering are the steel fixing plates on roof trusses, now these are blooming sharp.
  6. In that case there’s no need to fit it a course at a time, i would think you need to be guided by your icf company. Who did you choose in the end we are still making our mind up.
  7. We are thinking of icf and have done a lot of research on different models i would think trying to do this how you list above will be a thorough pita, all the systems I have looked at come in rolls and you would want to eliminate as many joins as possible running whole strips vertically or horizontally, the thought of joining it every lift of blocks seams like hard work. Can you not batter back the sides of your excavation so you can get in there.
  8. Thinking outside the box is it as simple as having a landscape plan done and incorporating a screening hedge so your proposed house is not visible from the listed building. We also used a consultant and don’t believe we would have got planning without them in the grand scheme of things their fees where less than we have paid our useless architect.
  9. If we have to walk or set up on a flat roof we keep a couple of old 1m wide carpet off cuts, lay these out and put your scaffold planks on top. It just ensures that if you had a scratchy stone stuck to the underside of your scaffold plank it wouldn’t make contact with the roof covering.
  10. In that case be very careful with the fence location, in the pics it looks a bit close, you should have some wording listing the tree protection zone and the distance out from the trunk, be careful builders will move things to make life easy for themselves and you could get a nasty fine. Just a friendly warning.
  11. Hi looks nice and flat, have you not had to put a tree protection zone near those beech trees, be careful of any root damage it could reflect in future crown die back, builders do tend to think trees have a root system like a carrot.
  12. Bloody hell thats cheap.
  13. Hi I’m looking at the moment for structural engineers to design my foundation system can anybody tell me the sort of costs you have paid. I know tanners do a lot of the passive slabs used by people on here, what sort of cost did you incur for this. Also @recoveringacademic I believe you had to have a ground improvement system, who designed this and was it part of your slab or was it two different companies. Thanks everyone.
  14. Is there the potential to bulk order, @Visti has commented that he has to have a beam and block floor, whats the chances of contacting a supplier for this with the understanding that there will be lots of future orders.
  15. I’m with all who say get the first floor in.
  16. Morning can anybody point me in the right direction regarding pvc products and damage that may occur if in contact with certain types of insulation im looking at building with icf so a great deal of eps-xps will be around i have just read on one insulation company website of potential damage to pipes and cables i had heard about the use of non-smoke cabling when in contact with eps, can anybody confirm this and any other products to avoid or measures to put in place to prevent damage. I am concerned about electric cabling but also waste water pipes in bathrooms and kitchen. Thanks russ.
  17. This is how it’s fitted up.
  18. Basically it’s very similar looking to a wet room or shower drain but a bit different, from the top it looks identical, its the bits below the floor that are different the ozzy, American version has a large trap built into it to prevent smells coming back up into the room. Ar ha you say thats the same as all the normal ones, the difference is a central floor drain will not have any water down it as it doesn’t function until there is a flood, so what happens is the trap dries out and smells come in, so what Jonny foreigner has done is install a connection on the side of the floor drain so another waste water outlet passes through it every time it is used, say the sink the water from the sink passes through the central floor drain and flushes the trap and fills it with new water keeping the smells out.
  19. May find this hard to explain as it’s not something I’ve ever seen in a house in England When we lived in oz and built our last place all the rooms with any wet area had a central floor drain, when I first lived over there I thought it was a silly idea but after having a couple of houses and building our last one I really liked the idea. so has anybody installed floor drains in their wet areas and has anybody got thoughts on how to achieve this using the uk spec drainage pipe. Will try to find a pic.
  20. I remember somebody talking about there beam and block floor and a few comments trying to dissuade them from having it, can anybody give me some pointers as to why I don’t want one. I personally don’t want one, but I want to be armed with some good justification as to why, after I have had my soil tests and the structural engineer has had a look I want to be able to steer him towards the method I want. Cheers.
  21. Can you really not have the concrete as the finish so not needing the blocks or sand so giving you more room for the insulation, you need to not think of it as a horrible grey rough as a badgers whotsit, and look at all the great finishes you can achieve with it.
  22. Sorted surveyor coming this afternoon his office is only 5 mins down the road. Cheers.
  23. We had to have a rather complex flood risk assessment because of all the water around us, ffl is 88.35 im doing a rough site scrape and instead of removing lots of topsoil and then bringing it back in when the house is in place I wanted to be able to leave it in place in areas it won’t get in my way. Think I will just bung the surveyor a nifty and get a peg knocked in.
  24. What’s the chances of buying damaged bricks to use for the cuts ?
  25. If you get some standard scaffold fittings you can tie it in to a window opening or something sturdy.
