Russell griffiths
    63
  1. You can hire a hilti shotfire gun and shotfire it on, you need to way up how long to drill the holes verses the hire cost if you had the gun on site it’s a five minute job.
  2. Would this be a crazy idea work out the area the panels would go in, then cover this section of roof with GRP, making an upstand and bonding in aluminium box section for the panels to fix to ? or ?. ?
  3. I think a lot to do with your roof covering. Describe what you are having may help people answer. I will refrain from saying 4inch nails,oops
  4. How about icf blocks, very diy able and some of the quotes I’m getting for my house seem reasonable. Insulation and structural strength and security all in one you could clad in anything you like. Even at a later date if funds are tight.
  5. I would check with your insurance providers we found it near impossible to get cover for any amount over £2000 , unless in a brick built structure if the building was not attached to the house, as our garage is about 10 m from the house this counted as a separate outbuilding so had a maximum payout of £2000 for any claim, be careful I don’t think we would be aware of this problem if I hadn’t asked the question regarding some tools I had.
  6. In regards to outer cladding type, the reason I said block outer skin is that I found it very hard to get any reasonable insurance cover on a timber building. Im talking about tool and contents insurance, not building.
  7. The problem with using the blocks as an infil if not for the structural part is they don’t bring anything to the party, hardly any insulation value not waterproof, so you will still need to render the outside very little resistance to sound penetration why not timberframe just like a house, and block outer skin for security, insulation in the timber frame and OSB inner skin for racking and a good finish to hang tools and put up shelves. Raised tie trusses for roof so a little bit of storage, but also good headroom if working with timber.
  8. The problem I found with single skin block is it’s not structurally strong enough without piers, so you end up with a non flat wall inside, so fitting workbenches or shelves is a pain, i did build a very nice workshop in single skin, but I used a block made by durox in 180mm wide, nice flat interior walls. You could then install insulation later.
  9. How about those factory seconds sip panels, i think the thing to ask is what is this building for ? if just to keep the car in then there is no need to insulate if it is to be a workshop or man cave then I would want to have a good level of insulation, i think you need to come to a conclusion on the finished product to then work out how to achieve it.
  10. My mates one has trellis on one side and he grows his runner beans up it. Doesnt lok to shabby.
  11. Looks good mate i see you have a metal chop saw in one of the pics, have you used steel track and stud somewhere?
  12. Sort of like this.
  13. You will also find all the components in a racking wall have to work together for example it is no good having a very strong wall that is not secured to the floor correctly, if laterally pushed or pulled it would lift from its base so not performing as it should, hence the floor strapping. I found in our last timberframe place that even the nail spacing was specific to the design of the wall. The 1200mm spacing is usually in line with a standard plywood bracing sheet, so sheeting is normally placed vertically so 1200 along and 2400 high.
  14. Are there any rules, or a general rule of thumb as to how many downpipes per gutter run for an example I know our house in oz should have had one outlet downpipe per 6m run of gutter are there any such regs over here my hydrology guy has drawn far to many downpipes and I want to get rid of a couple, but would like a bit of knowledge before I go for a chat. cheers russ.
  15. As @Brickie said that panel you showed looks like it doesn’t have a mortar pigment in it, just a different choice of sand and mix used. Ave you taken your sample to the batching plant to see if they do a similar one.
  16. From where I’m standing it sounds as though you will know far more than the bloke turning up.
  17. Don’t do it. They are a pain to use, one cockup and it will stand out terribly i thought you were looking into ready mix mortar remember, keep it simple., the more straightforward you make this the easier it will go if you are going to trust a brickwork gang to mix it and gauge the colouring I think you will be onto a loser before you even start.
  18. Two scaffold towers, one either end, bump it up and rest on a chunk of timber, go to other end and bump up that end, raise scaffold tower by inserting another transom, bump up again and add another transom. Cost, nothing time 2 hours. Crack on son.
  19. If you make a template lay it on both sides and drill from both sides, that way if you are not at 90degrees with your drill bit it won’t come out the other side in the wrong place.
  20. I cannot comment on the benefits of different types of floor makeup, as others on here are far more knowledgeable than me. What i I will say is how often do you go under your house to maintain it, I certainly can’t get under the one I live in now and I won’t be able to get under the one I’m planning on building this year, so I don’t really get why you are worried about getting under the floor.
  21. For the price of a plasslode you can buy an air nailer the hose and a compressor. But you you need to think of the air one like a corded drill verses a cordless its always attached to that bloody great air hose.
  22. I have both air and gas. Air gun is absolutely fool proof and unbreakable, but you need a compressor to run it, it will also be attached to the air hose so it is more cumbersome if you are climbing about on trusses with it, if using it for multiple nailing it wil go on and on and on until you have to put it down as it got to heavy. If you drop it from the roof just run down and get it and carry on. paslode is lovely, but you have to buy gas for it, mine loves to misfire just as you are in the most awkward position, doesn’t like being dropped off the scaffold, temperamental in the cold, keep a gas in your pocket. My no nonsense bit, if you have arms like cocktail sticks, just use a hammer. They are all heavy. ALWAYS WEAR SAFETY GLASSES.
