Rebar suppliers that can do 90mm h10 links?
Russell griffiths replied to WannabeBob's topic in General Structural Issues
Total construction supplies in the west mids did mine, they didn’t like it as it was small and hard to bend, but did them as I had had £5000 worth of steel for my foundations, and they featured my foundations on their website. give them a call. could you drop to 8mm links, check with structural engineer, easier to bend to get the tight radius. -
Explain to me like I’m five years old…
Russell griffiths replied to BadgerBodger's topic in Heat Insulation
Very time consuming to cut and fit expensive even if fitted well it shrinks over time leading to a poor fit. if your doing something from scratch you should be able to design it out and save some coin. -
Securing flint to ICF
Russell griffiths replied to Bancroft's topic in Insulated Concrete Formwork (ICF)
If this is a section below finished floor level you shouldn’t need any form of waterproofing as it’s all below dpc, using real flint will stick you out 100 mm plus from the icf, you will need some serious counter batten and batten to get the cladding to overhang. using a fake stone will give you a more consistent depth and thinner profile. have you considered rendering this bit, it could save a few grand in the build process. I can see the attraction of the flint if you are doing a wall of it, but just the splash zone at ground level seems an expensive method for a strip at ground level. depending on what icf you use you will not pull the eps off the concrete, it should be very secure, nudura you actually need to destroy it to get it off. I would waterproof render onto the icf, reinforcement mesh, rough up the render, then fix the stone/ flint with slip bond adhesive, pointing as you go. -
Block outer leaf - 75mm as planned or 100mm as standard?
Russell griffiths replied to G and J's topic in Timber Frame
The cavity is clear if you use surecav, you can go lower width cavity if you use a proper barrier 50mm is fairly standard to allow for inaccurate building practices and materials. ensure you keep the bottom of the cavity clean, you will need to exercise old fashioned good practices to keep the cavity clean at the bottom. -
Yep 100mm and 8mm render and 1.6mm top coat. haven't seen anybody lay 75mm blocks for a long time. how bigs the cavity, if you use surecav can you tighten up the cavity a bit. -
What do you want it for ? i cannot think of a use for it apart from rendering.
Underfloor heating in a plant room
Russell griffiths replied to Lincolnshire Ian's topic in Underfloor Heating
If the ufh manifold is in there, then the pipes will need to travel across this floor to get to the manifold, just add a couple of extra metres to one loop and wiggle it across the bits not already covered. -
I thought you mentioned 300mm high, if so you going to push your stone out from the icf by loads if you use surecav, sounds very OTT for just a strip at ground level and below finished floor height, surecav is predominantly used on timberframe. -
reinforce retaining wall?
Russell griffiths replied to stephanh's topic in General Structural Issues
Planning will only get involved if you actually tell them. -
Cutting Limestone and Marble Tiles
Russell griffiths replied to LiamJones's topic in Wall Tiles & Tiling
Cut along a straight edge, normally aluminium. -
I don’t think they were needed at all, but did it anyway. -
Will this create a large shelf that you will need a flashing over. on an eps block I rendered onto the eps with a waterproof render with mesh included, then left the surface very rough. then laid natural stone bedded in exterior slip adhesive and stuck back to the render with the same slip adhesive, stainless screws and stainless brackets bedded in every third course. -
Badly designed wall, using incorrect materials I’m afraid. it all needs pulling down, new foundations and a new wall of some description. I would go for something more flexible like sleepers or gabion baskets with a nice stone on the face. -
If it’s blockwork nobody cares as it’s normally rendered if brickwork it should be set out correctly at damp course level, and a good architect should have worked the building and openings to brick sizes.
Pictures needed. -
The door size wasn’t equal to block sizes so going over the top won’t work to the same bond as the blockwork already laid.
Sealing timber cladding/reveal around window?
Russell griffiths replied to junglejim's topic in Timber Frame
Leave a gap, it allows it to dry out quicker if it was to get wet. mat risinger did a video on this on YouTube, it was found that sealing up every gap kept moisture in rather than letting it in briefly and out quickly. -
Brink Flair 400 Maintenance
Russell griffiths replied to Russdl's topic in Mechanical Ventilation with Heat Recovery (MVHR)
@Russdl you need a new hobby 🤣 -
Using slurry primer to adhere to concrete twice?
Russell griffiths replied to Tony K's topic in Landscaping, Decking & Patios
Don’t use pva. i would hit the concrete with a pressure washer first. -
Airtightness progress, this is a lot of work...
Russell griffiths replied to Post and beam's topic in Heat Insulation
Gaffa tape, don’t overthink this, it’s a hole, block it up, carrier bag and some tape, job done. -
Installing suspended timber floor with PIR
Russell griffiths replied to tommyleestaples's topic in Heat Insulation
I believe you only need 100mm if under a screed in an extension if the insulation in other areas is more than adequate talk to building control and ask them if 100 will do. airtightnes in this floor will be just as important as the insulation levels. you will need to be meticulous with this. -
UFH/Screed Expansion joints ?
Russell griffiths replied to Post and beam's topic in Underfloor Heating
I think you need to change your thoughts on the name of the joint. it’s not an expansion joint, but a movement joint. I was always told that if you have any shape like a tennis racket, so a big square area with a thin corridor coming off it, it will crack at the join between the two. I used a strip of firm foam with gaffa tape both sides, placed in every doorway, situated under where the door will close, so if you have different floor coverings in the different rooms the expansion trims will be hidden under the doors.
