TerryE
Everything posted by TerryE
Have a look at my blog. We put UFH in our slab during the pour so it cost very little, less than £2K. We use a Willis heater as our heating source, and I did the work myself. We use 2 x SunAmps for DHW, and our cooking is electric (though we do have 2 Propane gas rings on our hob as backup). So excluding the SAs, the cost of the installation including the cost of control system was around £1K. Because of planning constraints, we only have limited glass, and this has upsides as well as down. We stopped adding heat about a week ago, but the arrival of spring temperatures was unusually late this year. Have a look at At the moment our daily energy costs are ~£2, (but no PV; thanks to the planners). And we are absolutely delighted with how the system works.
- 54 replies
- underfloor heating
- passivhaus
What did your surveyor say about the settlement crack running up from the join of bricks 2/3 at the bottom LH of your pic all of the way up to your verge at the top RH by the looks of it? Is there equivalent settlement on the inner skin? As to the inner profile and make up, have you had a look at the original Planning / B Control docs? Failing that, then a quick exploration core should give you a good idea.
Ditto. It makes the roof a lot stronger and racks the whole thing.
Controlling underfloor heating in passive house
TerryE replied to dogman's topic in Underfloor Heating
I have tried to keep my system as simple as possible. So for example, my 230V side is isolated from from the low voltage stuff by using some Crydom SSRs. This enables my Sparky to raise his Cert to keep BControl happy. I haven't added any extra valves in my system since they weren't needed, but I will need at least one extra if I add an ASHP. As to extra expansion, why not just add a trickle bypass and avoid this. -
Floor screeding, why so late in the build process.
TerryE replied to epsilonGreedy's topic in Floor Structures
I support everything that the Js say. Our MVHR stays at 30% except for the occasional boost, and doing the airflow calcs this does a complete air change of the house roughly every 4 hrs, so the house smells airy and fresh all of the time. When we do our 3-monthly clean of the MVHR filters, we still get a covering of fine white dust on the outbound filter which I suspect is a result mostly of the rubbing down as we finish off our P&D. What horrifies me is the black particulate matter on the inbound filters. Our house fronts onto the street through our village, but this is quiet except for the ½hr rat-run period morning and evening; and the inlet and outlet are 5m up and ~12m from the road, but we still clearly get diesel particulates (and perhaps wood smoke) being taken out by the MVHR filters. As the slab, our ground floor is slated, but Jan prefers to walk around bare foot in the house because it is a nice steady ~23°C. We haven't put in the upper control on our UFH, so we still do fixed heat chunking over night. The conversation that I've just had with Jan went along the lines: "the average temp has risen by 0.8°C over the last 7 days because the average temp outside is starting to climb at last -- OK, I'll trim the overnight heating from 5½hrs to 4½." Life is tough in a passive house. We used to live in a traditional farmhouse: wavy floors and walls, draughty windows, wood-stoves, classic CH, walk from one room to the next and the temp drops by 5-10°C; within 1hr of the CH going off overnight, ditto. Do I miss it at all: not one jot. -
We have one as well, and it definitely reads long. I have 0.3m, 0.6m, 1m and 1.8m steel rules which are all consistent with my steel tapes to around 0.1mm / metre (using the standard mobile phone camera trick to take the measurements). If I use the Boch to gun an internal door frame height and then compare this to the two overlapped steel rule method, the Bocsh consistently comes out 1.5 -2 mm longer over ~2.1m. I trust the steel rule measurement to 0.2mm, so there's no way that my DLE40 achieves the claimed 0.5mm accuracy. So IMO, the Boch is brilliant for measurements up to maybe 15m accurate to 5mm, say (though you do need to do the longer range measurements after dusk because of S/N ratios.) However, it isn't good enough to measure up for cutting oa piece of wood and to get it right in one cut. PS, isn't it about bloody time that you arranged to come and see us or @RandAbuild one W/E when you are next in Roade. We've got to build up the local self-build mafia!
Wet UFH how to retro fit an electrical heater element?
TerryE replied to readiescards's topic in Underfloor Heating
@readiescards Mine is 100mm with extra 200×200 bracers every 2m and a 300×300mm ringbeam and ditto 2 loadbearing cross-members so you have ½ the thermal capacity / sq m. how many sq m in your GFL, because your curves are going to be a bit steeper than mine? -
This is what my Spakie said, but he also said that the regs didn't specify where between the CU and the meter this had to be positioned, so we have ours next to the meter on the same board. but he also ran SWA from the CU to the isolator. I had to put the ducting pipe through the TF at 45° or we wouldn't have been able to make the turn within the service cavity depth.
While I think on, IIRC they have a nominal maximum rating of 6 bar, but I run my UFH loops at 1 bar.
In the typical installation which is external heat for an indirect HW cylinder they are fitted vertically as the thermal gradient is the primary pumping action. In this case the thermal effect is trivial compared to the UFH pump so that can be fitted either way. You can see all of the ds18b20s in this figure, plus the PHE. The typical delta is -5°C out -> return at the manifold and 10°C return -> Willis top so the water flow is ~50:50 through the Willis and the PHE. The 5°C is at the medium pump flow setting. At high setting this drops to ~3°C. but I am happy with 5°C and very little pump noise. BTW, if you want to use the out/returns to measure the slab temperatures then you need to run the pump for 5 mins first. @readiescards, I am happy to talk through all of this stuff with you, but give it 3 days or so because I've had an absolutely shitty cold for 3 weeks and still can't speak easily. Also like Jeremy and others, I do offer an open invite to forum members to come and to see my build and to discuss any issues that they want. Lincolnshire to Northamptonshire isn't that far. If you want to do either, then just PM me, though can you give me your email addr because I prefer using email.
as @Dreadnaught says I have even described all this in my blog posts, so all you need to do is to read this, and ponder what I say. Make a point of reading the referenced posts which go into a lot of detail including my mathematical simulation of the system to determine its operating characteristics so that was I confident that the system would work this way before I implemented it (and the first commission tests validate the model). We have this as our sole source of UFH heating and at the moment we are at a comfortable 22°C with a ½°C ripple over the day using 17½kWh of heating at E7 for a large 4 bedroom passive class house. Hence my recent post: But to your specific Qs: Does it need an additional expansion vessel adding to the system? It add an extra ~1ltr of water in the UFH circuit, so No. If I install the device just before the UFH manifold, would extra valving be essential to prevent the UFH pump running the return water through the boiler circuit all the time? Again read my posts and have a look at the photos. I have my Wilis effectively on a 15mm bypass across the UFH loop with a PHE on the other branch. No valves, but the flow runs roughly 50:50% through the two branches. That's on the warm loop side in a boiler mix-down implementation. I don't have a boiler, so my TMV is just cranked open. It is entirely redundant and I've only got one because this was the cheapest Wunda config that suited my needs. If you read the physics of this then you will see that this isn't an issue. I have a BS1820 temp sensor buried in the slab, the control circuit seems simple ... Have I missed something? What a bizarre type of sensor. A lot of people do this and for the life of me I don't understand why. I've already got this remote sensor which integrates the slab temperature by UFH zone: the UFH flow loops. I have ds18b20s on the out and return of each loop. Simpler, easier and a simple way to balance the flow through the loops as well. OK, so I have lots of ds18b20s measuring just about everything, but at £1.50 each this is hardly breaking the bank. On your supplementary points: If the UFH pump failed the Willis unit dual thermostats will cut in and switch it off. Eh?? This isn't a failure point; it's an essential backup safety feature. If the slab temp sensor fails the floor could get too hot so an extra temp sensor on the manifold could verify the return UFH water remains within acceptable limits. Yes, which is why you should always monitor your flow and return temperatures and include cut-offs in your control system. If you are too mean to spend the extra ~£6 on doing this per loop, then by all means do it on the manifold out and return. I am not sure that you are using for your automation system but your inclusion of Javascript-like pseudo-code suggests that you are reasonably IT literate. My HA is based on a single RPi3 with SSD running Node Red. All of the IOs are done by two (soon to be one) ESP8266 modules USB-serially attached to the RPi (so the core DHW + CH system is independent of our Enet Hub + Wifi). I do use other WiFI-connected Wemos modules for nice-to-have remote sensing. I run the NodeMCU Lua subsystem on my ESPs and talk native json to Node Red, though I also run and use a MQTT broker on my RPI. The support that I get on the Lua system is excellent (but that's because I on one of the core developers on the project ). By far the most expensive bits in my system are the 4×Crydom SSRs, but that's so my sparkie could sign off the 240V side and keep my BCO happy. The rest cost < £100. Not a virtue; just no point in spending any more. Yes, it has involved a lot of personal time, but it's my hobby project, and my son-in-law is into all of this shit as well so he's my SPoF backup. -
DIY scaffolding: wind - the enemy
TerryE replied to ToughButterCup's topic in General Self Build & DIY Discussion
As opposed to an annoying southerner now living in Devon, or is it Cornwall?- 34 replies
- scaffolding
- kwikstage
(and 4 more)
Plot Boundarie Identification
TerryE replied to iSelfBuild's topic in Party Wall & Property Legal Issues
In England, the Land Registration is what it is at point of registration and the boundaries are what they are unless varied by a court order or by agreement with both parties. In the case of our previous property, there was a path along one side. The first deeds of sale in 1913 specifically discussed it as part of our property, but when our neighbour's nephew sold her property in 1994 (by that time registration was compulsory) the registering solicitors submitted a site plan to the LRO which incorrectly claimed our path. We didn't know anything of this, because we weren't consulted, and none of the neighbours noticed this mistake because we maintained the path and fence and you could only get to it from the public highway or our property so it was obviously ours. When we discovered it in 2015, the LR refused to accept that the original registration was in error, and in the end we and our neighbour had to jointly submit a TP4 to transfer the path back to us. There are two methods of registering a boundary: Use of OS National Grid co-ords, but in this case you need a properly qualified person (e.g. a chartered surveyor) using OS approved survey equipment. Use of measurements from permanent features, and IMO this is the simplest and best way: nice straight lines between permanent boundary markers, such as short concrete spur posts concreted into the ground and photographed in location. In your case, I see nothing wrong with walking the new boundary with the seller and staking, marking and taking a 3-way selfie (you, the seller and the rebar in ground context) at the way points, and proceeding on that basis, maybe with the pre-agreement that you will replace them with by permanent markers with 6 months of the sale. You don't need tape between them so long as the boundary between markers is straight, as line of site will do fine. If you do a "roll-your-own" survey, then how will you ever prove that is was accurate if you need to? No, OS grid coords = paying for a CS, but you still need permanent markers, IMO -
Ian, I half wish you wouldn't do this. The problem is that when I click on on of these links I end up watching the next 3 or 4 entranced -- and then the next time I log onto YouTube, half my recommends are videos about Fred or demolishing chimneys. Characters like him are gems and I still think of him fondly even though he's been in the ground for over a decade, but in return I will give you a monologue from another such character which I first read in a John Julius Norwich anthology from Blaster Bates: The Shower of Shit over Cheshire or the YouTube soundtrack version.- 34 replies
- scaffolding
- kwikstage
(and 4 more)
Good (relating to the scope of the development) purchased before the sign-off date for the purposes of completing the development clearly fall within VAT reclaim category. My pint is that we were very much cash constrained towards the end of our build, so we deferred any non-essential expenditure until we had sold the old house and moved into the new one. That being said, the deferred stuff was not trivial: glass doors on en-suites, fitted cupboard doors, all of the external landscaping works. Delaying BCO sign-off after this has save us maybe £4K so far.
- 32 replies
- sign off
- vat reclaim
(and 3 more)
Lizzie, there are two separate facets here: Between you and your BCO, and specifically when you've got the point were the BCO is willing to issue the completion certificate Between you and your HMRC inspector. AFAIK, you can't reclaim VAT on work executed after you have received the completion certificate. In our case the LPA insisted that we include planting plans, restoring road frontage, etc. in our conditions. At the time, I thought that this was a bureaucratic PITA, but I later realised that by bringing all of this stuff within the scope of the application, they were actually doing us a favour: this work comes within the scope of the development and is therefore reclaimable. Driveways, electric gates, landscaping ... can easily end up costing more than £20K, so delaying sign-off might well be worth while if you can avoid VAT on this.
- 32 replies
- sign off
- vat reclaim
(and 3 more)
Mike, I think that you are excusing corporate or systemic incompetence. Issues of trust and risk need to be tempered by an assessment of the consequences. You are getting hosed about 30 min fire risk in a single dwelling, one in which the self builder is proposing to live in and as nod says 12mm plasterboard + a skin will give more than that in most circumstances. Grenfell Tower had 120 flats. The 71 confirmed deaths and the total number TBD had a single exit route which had unprotected gas pipes running along it. I am not blaming the individual LA BCOs because I do think that they have a thankless job, but I am challenging the systemic environment and management policies which -- in my view at least -- mean that they can't put their focus where society needs them to and instead have to vent their frustrations on individual self-builders.
- 30 replies
- building control
- part f
(and 3 more)
Mike, what I find crazy about this is that you get this 20/20 drill down into all sorts of fine detail about your build -- where I am absolutely sure that in reality you are conforming to the spirit of the BReg and far more on the letter than any typical major constructors dwelling build (you are after all putting your lives at stake in getting this right) -- yet we can refurbish tower block like Grenfell and have copper gas mains without any fire protect in safety corridors where the live of 100s of occupants depended on their integrity, where their claddings were death waiting to happen. Yet all unchecked. Where is the sense of proportionality?
- 30 replies
- building control
- part f
(and 3 more)
I don't spend a lot of time in the shower washing my face, and I don't use bar soap.
I remember an old friend of mine -- who died 6 days before his big 90th birthday bash -- asking my what was the point of quantum mechanics. He'd read a number of introductions to it and just couldn't understand what it was all about. My answer to him was that it was less important that he understood it. The main point was did he use computers, mobile phones. the telephone, modern drugs, modern fabrics and materials, ... None of these would have been possible if the people developing them had been limited to classical physics; the relatively small numbers of scientists and engineers who are transforming our society and the quality of everyone's lives need to understand this stuff to do the magic that they do. I realise that Hawkins attempted to popularise what he is doing, but the important thing here is not that 10% of the population understands or remotely comprehends this, but that the tiny percentage of people who need to do understand. The domain where Hawkins worked is at the boundary where general relatively meets quantum mechanics --two theories that explain the physics of our universe to exquisite precision, yet are mutually inconsistent. Maybe we don't need to understand all this, but also perhaps the scientists and engineers that will build a workable fusion energy source that will transform the plight of humanity going into the 22nd century do.
Hawkins was an atheist who was publicly open about this, but for the large part only commented on this in a personal context. Of far more importance was that he was also a great scientist and thinker who achieved this greatness despite personal tragedy and disability that would crush the vast majority of us. He left the world a better place after his passing and caused no material harm to others in doing so. If I could achieve 10% of that, then I would die happy.
USB3, extra RAM and SATA would be good. The SBCs that have these are about the same price and are a far better for a SBC server.
Nick, google ESP8266 Tasmota or Sonoff Tasmota. Sonoff use the ESP8266 as their standard controller and this in an Open Source apps platform designed to run of the sonoff kit and RYO ESP boards. There are also anther couple of Open sources apps tiers based on MQTT. Just run an MQTT broker and NodeRED on your RPi and let MQTT do the connection magic. They support a range of OW, and I2C devices. Or use MicroPython or NodeMCU Lua if you aren't comfortable with the raw Arduino support. Lot's of options if you are willing to learn.
- 6 replies
- old router
- real time clock
(and 3 more)
Members' experiences of Timber frame and slab suppliers
TerryE replied to TerryE's topic in Timber Frame
Members who have used a given company can talk in detail about that company. What I would like to see is more members who have used other companies explain the values and advantages of the alternatives. Someone has to generate that content. That's what this thread is about. -
[ Edited in line with other edit above to remove dead quote. ] There is a view recently implied or expressed by some members that the forum is pro-MBC, to the exclusion of other TF alternatives. Yes, some of the active contributors including myself have been open about having MBC timber frames in their builds and have blogged and posted about our experiences. I just wish that members with other TFs would put their experiences and recommendations into print so that these can be mined by new members. I started this thread to encourage other members to present such a balanced set of alternatives to new members, but I can't create this content.
