TerryE
    30
Everything posted by TerryE
  1. @IanR, any updates on how it is going and lessons leant? This would be a great addition to this thread.
  2. Thanks @IanR. That's link is an extremely useful cross-link for other readers :-)
  3. I am really just refreshing this topic to let members other than those who have had an MBC timberframe have an opportunity to recommend / give feedback on their supplier. The problem we have as the main contributors is having other members give constructive recommendations on other suppliers and whether they would recommend them etc. @IanR, @NSS and @RandAbuild, I know that you are both active on the forum. Any comments? Can any other members suggest who else might want to give input?
  4. I would have been tempted just to bung the insulation block into the hole and foam it into place, and with some drizzle foam zig-zagged on the front to act as a keying surface. Then when dry, tossed in a snotty mix and tapped the front Durisol plate onto it and banged a few 6" nail through to keep it in place, whilst the snot went off. But liquid does tend to flow through holes unless you plug 'em.
  5. Our planning department turned down the installation of PV in our pre-planning advice: PV on the principle elevation was "not in keeping with the preferred cottage style". The house is SE facing, so the principle elevation is the only one where it makes sense to install PV. So we use grid electricity for all energy (apart from a couple of back propane gas rings on our cooking hob, just in case of power cuts. Our village has a wind-farm and 3 largish PV installations within a 3 mile radius, so we it makes sense to buy our green electricity through the grid. We've learnt so much from Jeremy's experience, but he's reworks his system at least three times, each a stepwise improvement and he isn't living in his house full time yet! So our intent has always been to use the 1st year to complete the house inside and out and gain experience of living in it (including collecting hard performance data on the house as built) before doing any optimisation of the heating system etc..
  6. @Dreadnaught, we live at NN7 so you are close enough for you to come over for a visit and walk around / talk some of the issues. Just PM me if you want to. I am sure that other members can do likewise. I know that I've made this point on other threads, but the devil is in the detail on ensuring that the house as-built achieves the as-designed goals. We are retired and our build was on an adjacent plot split off from our previous garden -- and so we could keep an extremely close eye on all of the quality issues. This isn't the case with people how have to hold down a job and don't live next to their build. Here you have to put a lot more trust in the trades teams. Doing a self-build is extremely stressful , IMO and having a bad builder or tradesmen cut corners is the last thing that you want to face, especially if you only find out when it is too late to fix the issue cheaply. So my view is that you make damn sure that you pick the right builder / supplier with an excellent track record. As to my "bath" point, I don't use the Willis for my potable hot water at all, just the slab. I have a pair of SunAmp PVs which I heat overnight. This is absolutely fine for normal use, but we have a big bath and a full one on top of normal daily use is enough to require use to top-up the SunAmps after this with peak rate top-up.
  7. BTW with an ASHP you have three different "grades" of water: potable; + inhibitor for the UFH loops; + antifreeze for the ASHP. You need to use PHEs between these; though I believe you can use a combined inhibitor / antifreeze mix for a combined UFH + ASHP flow, though no doubt JSH or NH will correct me if I am wrong.
  8. Nick, I feel that you are missing a fundamental point here. The SunAmp uses PCM cells to get a lot of thermal capacity in a small form facts -- about 4½kWh in the standard box. The slab is a thermal store with well over 10x this thermal capacity at less than ½°C temp drop, and it is there anyway. IMO, there's little to be gained by using a SunAmp as a heat battery for the whole slab. Where is does make sense is possibly for a DHW preheat buffer, but really only when we have baths. I just tweak my version of the "Jeremy Spreadsheet" to increase the house temp to our actual average (21°C) and drop the Jan/Feb temps to actuals rather than forecast. So the prediction of this 3 year-old model was Feb average consumption of 47kWh / day. Our actuals this month vary between 42-55 kWh with an average 47.5 kWh /day , which I think is just amazing. It's bloody cold at the moment, the 24hr average temp is around 3°C so we are needing 21kWh @ low tariff + another 6kWh top-up late afternoon at peak tariff to maintain a warm house environment. This space heating element costs £1.51 (cheap) +0.83 (peak) (+5%VAT) at our current OVO tariff. Our slab could probably take more than 3kW, but I've only got the one 3kW heater. A big caveat for @Dreadnaught: for this sort of heating architecture to be viable you need to do the sums for your design and you then need to make damn sure that your house as built achieves the sort of passive class performance that you designed for. Acres of glass make a big difference to the figures; ditto bridging failures in the thermal envelope; ditto material airtightness failures. But get it right and you won't need upstairs heating at all, so no radiators cluttering walls, just a warn ground floor. This all being said, we'll be laying the insulated return pipe from the services room to the end of our garden shed (the probably place for ASHP should we decide to install one) this weekend as the paving guys are starting the drive and paving the following Monday. That way we won't have any digging to do if we do decide to install an ASHP.
  9. We have got our completion cert yet, even though the house itself is done and we are living in it. We have some groundworks outside that are covered by the planning application and want to do this zero-rated -- which we can't if we've "completed" our build. I did ping my BCO, about a certificate of temporary habitation, but he didn't even bother replying, so we just moved in, and took out normal insurance.
  10. Lizzie, quite a few of use have been caught by this: quite good initial terms but huge price hikes for extensions. As you say, it would have been a lot cheaper to buy the insurance upfront, but it's now too late to beat yourself up about it. The point is that a build insurance has to cover a lot of risks that you don't face in a completed house. We just transferred our standard house insurance to the new house when we moved in, because the build was finished by then. A year's standard insurance was about the same price as a 3-month extension to the self-build insurance. But don't do this before you've finished the building work or moved in because you might find that your insurer is unwilling to meet a claim in these circumstances. Have a trawl of the site. There's been lots of past threads on this.
  11. Ian, first you turn the power off on that lighting circuit, then check it's off, then unscrew the switch from the pattras. Now you make sure that the surfaces are prepared according to your fillers instructions. Then do your filling. You will need at least two fill layers and maybe 3: a bulk fill, a top fill which you will level and sand when dry and maybe a touch up fill because you've notice a few hollows and you are a perfectionist. When it's dry to the touch, remove the crap from the pattras and refix the switch.
  12. BTW Ian, there is always a hazard zone in the vertical and horizontal lines from any pattress. Like the others have said, a current detector is an excellent precaution, but drilling a hole in the wall directly above light switch is about as safe as sticking a screwdriver into an electrical socket?
  13. I will expand this is Part III when I get time to post it including a fixed copy of that circuit @PeterW, but I am a bit busy at the mo. We've now been using the heating system for two months, including an interim NodeRED controller. I still have to put in an upper level of control, but at the moment all I am doing is having the Willis on 00:00-07:00 (our E7 slot) and a top-up of 2 hrs in the late afternoon. This leaves a residual ripple of around ½°C over the day (as @JSHarris has discussed previously), but other than that the house is amazingly stable. If the external temperature climbs to around 10°C then the house slowly warms up by about 0.1°C per day on the overall ripple, but for an overall average of 4°C or so, this small delta seems to wash out -- to the point that putting in any more advanced control algorithm just isn't a priority. As we get into lat Feb / Mar if it does steadily warm up then I might have to trim back the afternoon heating to 90 mins or an hour and by the end of March we should have stopped it entirely. But here is a typical day's usage: The two top hats are heating the slab. The other overnight spikes are the SunAmps, washing machine and dishwasher. The other base ripple is our general electricity usage for cooking, lighting etc. The main variation is the SunAmps -- you can tell if someone has had a bath because the spikes are fatter, and the type of cooking going on that day. So our total energy bill per day for our large 4 bedroom house is around £5, and this should fall to around £3.50 by end March and around £1.50 by May. You can see why the cost benefit case for adding an ASHP is marginal. One other point that we've realised: a "comfortable" temperature varies according to your activity level: maybe 19°C if you are working; 20°C if you are up and mobile; 22°C if you are sitting at a desk or watching the TV, etc.. Getting too hot is a real PITA because you need to start stripping off to avoid sweating; so we now keep the house at ~21°C dropping to 20½°C by the evenings, and there is just so much thermal inertia in the house that it's just easier to live with this so get the comfort by putting on a gilet in the evenings.
  14. So am I, but I also have a not so little Jiminy Cricket who will let me know in no uncertain terms when I am moving in the Pandora direction so in this case my caution gets the upper hand.
  15. Thanks guys. You are just juggling so many balls in the air during design and construction that you are bound to drop one or two. In this case we used 110mm pipe foulwater pipe as an access path from the service cupboard out beyond the slab. I mistake that I made was using a normal 87½° bend to bring it up into the service cupboard instead of a Drainage 87.5° Rest Bend, or even a 45° and cutting the stub off at an angle. The normal bend has a radius at centre of around 110mm and 160 at the outer curve. This was enough to get a 25mm MDPE DCW feed up the other access pipe. It's really touch and go as to whether installing an ASHP will be cost effective, and there's no urgency. I was going to wait until autumn when I've seen how the house performs during both winter and summer before making the call. The issue that we now face if that Jan is now in JFDI mode and wants to get all of the outside paving done by a local contractor including paving over the run where we'd need to bury the pipe. It's just not worth having to dig up a trench across the new paving, so I guess that the sensible thing to do now is to fork out the £500 or so for the proper insulated pipe and get our paving guy lay it under the paving whether we end up using it or not. Time get the 9" angle grinder out. I've got to clear the concrete perimeter up the pipe -- yes, I know that I should have left a length of ESP along the trench line and had the concrete about 25mm depth over it, but again -- a Tardis moment. PS. Concrete trenching all done and outside of access pipe exposed. A combination of a 9" Angle grinder with diamond disc and a decent SDS drill to put "stamp tear perforations" across the bit wanted to chop out made fairly easy work of it. As Jan pointed out, the reason for our JDFI (army acronym -- Just F***ing Do It) mode is that we want our VAT back as the paving plan was part of our landscaping and implementing is a planning condition so the work is zero VAT rated if we do it before sign-off.
  16. Clive, just noticed this; you are a star, BTW. Ian, You shouldn't have cut the 3+E back to the same height above the rawlplug hole. Look through Clive's example again. You'll need to hack back further now. The joins need to be staggered so that no joins are at the same level. I guess this is a bit like asking Jan about her soldering skills, but you can use twisting the copper plus soldering as an alternative to crimping. You just need to strip back enough to slide the heat shrink beyond the hot bit otherwise it will shrink in the wrong place. And also wrap some wet cloth or kitchen towel around the heat shrink to keep it cool. However you achieve it, the end rest needs to be doubly insulated: once around each phase and once around the lot.
  17. I did some research and there are four different model numbers but the only difference is on the reduction gears which determine how often the backflush is triggered.
  18. We've also got a Harvey treating the entire potable supply. Works well. No more limescale; work surfaces, bathrooms, crockery, pans so much cleaner and easier to clean than without. The system uses a mechanical counter on used water volume to trigger the brine backflush, and there are four different gearings which sets the flush rate. My only slight quibble is that I suspect that the suppliers err on the salt heavy side in selecting the gearing. They certainly did in our case compared to the local Anglian hardness report. Higher frequency flush cycles mean less chance of complaints of residual hardness, and more sales of the salt bricks which aren't cheap.
  19. Our had a low spot along one gable. It must have a whole 2-3mm lower that the rest of the slab -- enough to see the puddle when it rained in the 3 weeks before the frame went up. But on serious note, the guys made it look simple, but that because they were pros; they really knew what they were doing and were extremely particular. The tiler who slated the entire ground floor said that he'd never worked on a domestic new build like it. Fantastic thermal performance and really good VFM. I am extremely happy with my slab.
  20. Ian, I hope that you have a stud/cable/pipe scanner. These should also pick up any pipe work near the surface.
  21. @AndyT, at the moment I am running my house with the a Willis Heater for the UFH + 2 × SunAmp PV for the DHW. One option that we are considering is to use an ASHP for UFH heating / cooling and also for a §unAmp DHW preheat. The form factor of a conventional buffer tank might be an issue for us. If you did a micro stack -- that is a couple of PCM cells with a phase change of around 30-35°C and vacuum panel insulated in a form factor of the SunAmpPV. This wouldn't require any of the pumps, heaters, control logic of the SumAmp PVs , so should be a lower price item than the SunAmp PV and if so this might be something of interest to us. @JSHarris, what are your thoughts?
  22. Most of us might have thought this, and isn't about time that someone invented the Tardis? You have to make decisions based on the best evidence at the time you make them. Others might make a different decision; you might do the same with 20/20 hindsight. We can't go back; only forward.
  23. @Siochair, it's a good idea to search the forum before you post a Q on a topic. In this case, you will see that many members are early adopters and most of the points that you might raise have been covered in previous discussions. ?
  24. I did a bit of project management in the IT world - enough to know the principles of good practice. We picked our major subs very carefully: a reputable TF company with good track record for the TF + slab, ditto for the windows and a good local outside ground works and stone skin. We also used some of his recommended tradesmen for trades such the electrician and plasterers. We used a local architect technician to help prepare the Planning Application, but other than that, I did all of the planning submission, the architecture and PM. Jan did a lot of the procurement online. I made damn sure that all of the interfaces between the subs were monitored and controlled, but in the first phase of the build we did as most have said: kept the site tidy, kept the troops happy, kept a fair watch on the quality of the work, but without getting in the tradesmen's way. If any tradesman has quoted a price then he or she has built in some contingency, if things run smoothly and they don't go past that contingency then the good ones will do a good job. What we also did was do pretty much all of the other internal 1st and second fix (less electrics, boarding out and plastering) ourselves. By this stage the house was secure and weather tight.This took a lot of our time and elapsed time, but we got exactly what we wanted to the quality we wanted and saved a stosh of money.
  25. It's the arrogance and illogicality that really annoys me. Person A enters into agreement with company B to rent a car under which the payment is non refundable for a set of conditions detailed in X. Yet company B's position is that the eventual rental will by under a set of T&Cs Y, so if the company B decides to deny the service to A because of a failure of a condition in Y (which A hasn't yet agreed to), then B feels entirely entitled to keep the money. The second point is as Jack says. Avis/Budget have now gone paperless, so Jan was presented with an on-screen rendering of a PDF document that she was supposed to read (by doing repeated page down) and then sign at the bottom. "Don't worry we will email you a copy of the signed PDF", said the desk agent. In other words you either stand for 20 mins in line or alternatively only get an opportunity to read the contract once you have signed it. And by the previous logic, if you don't find the terms acceptable you lose the money anyway. The phrase "bunch of crooks" comes to mind.
