makie
Everything posted by makie
Thinking ahead for when I have a roof to slate...
makie replied to dnb's topic in Roofing, Tiling & Slating
Get a roofer with an account to price them for you, will be cheaper than that. -
As a roofer please don't use Chinese slate, they are awful. Cupa is a good spanish slate (H3's are better than the rest) As said by ProDave try and get an amendment - The redland Cambrian is a good option as it is a tile made from recycled slate. The saxon is another good option. Try and avoid Marley, they are made on the cheap and they don't let them cure as long as they should now. -
You also have to consider how your attic will be ventilated after.
Contact a local roofing supplier and find out how much they charge. Then charge less.
Most brickies I know wouldn't work alone and most of their labourers will be hitting the bottle right now.
A company I'm doing work for paid £700 for half a day of cutting.
Advice? is this quote a TAD expensive
makie replied to SteveM1971's topic in Roofing, Tiling & Slating
I'm a roofer and we do this on every strip and re-tile. You only strip off what you are able to felt again in the same day. Scaffolding tents aren't needed unless you are taking off all the trusses. -
Get 3/5 quotes from different roofing firms and make your choice from there. -
I'm a roofer and a lead worker. It is an awful job and needs fixed by someone that actually knows what they are doing. Get 3 quotes from other roofing/lead companies and don't let that guy near your roof again. If he requests let him collect his scrap lead when the job is redone
Get a good quality Spanish slate (CUPA), the H3 is just as good as Scottish slate and you can get them in random sizes
Enewall is the new name of Powerwall if that helps.
Mate not a single house built that long ago has the original roof on it. The nails would have went after 100 years or so if that
Natural Slate Roof - Looking for recommendations
makie replied to colin7777's topic in Roofing, Tiling & Slating
Cupa H3's are the best Spanish ones you can get. Apart from that Scottish slate is the best -
Roofer here. Whoever done this never battened the roof correctly. You should work your way down from the top of the dormer while measuring both side of the batten. It can be fixed without stripping the full roof back but that would mean 6 tiles would not be fixed with a nail. Could narrow it down to one if they used clips.
Few hundred? Some of these guys charge just less than I would to completely renew the roof. Any tile manufacturer will strongly advise against power-washing tiles in any way as it can damage them.
Slate may withstand it better than concrete tiles but if there is any slight issues on any part of the slates/tiles it will break them. I actually get a decent amount of work out of fixing roofs that have been power-washed and painted.
Never power-wash a roof! I'm a roofer and it's a good way to make sure you need a new one.
I'm trying to source some Scotch for a job I'm doing in a conservation area. If you don't mind can you message me when you have them off?
What is the quality and the quantity of the scottish slate?
Yep, went out and found my roll that I had. http://www.monarflex.com/Product Guide/Building membranes/Roofing underlay/Ventilated roofing underlay.aspx
I can't remember the name of it and I have a roll of it somewhere in the yard.... If it helps Geoff Capes was used in the marketing of this felt.
The ventilation issue should have been sorted before hand. Being a roofer myself I see this issue a fair amount. It will need vents installed to be properly ventilated. Roofers should have multiple roof ladders to deal with different situations.
It shouldn't cause you a huge problem, bring your concerns up to the roofer and they should explain everything to you. For the ventilation issue you need to install slate vents as close to the eave as possible.
If they don't have more than one roof ladder or one that can be extended they probably aren't that good of a roofer.
Any roofer that knows what they are doing would not fully extend the roof ladder past the bellcast.
