scottishjohn
yes you can but ti drops the payment you get for the ASHP --cos rate for solar is a lot less than ASHP chances of some one coming is virtually zero -
maybe a rough cross sectional drawing would help
is the ground behind it flat or does it go up at an angle --and what angle?
that changes things alot--whats it holding back
Suspended Ceiling under a flat roof : how best?
scottishjohn replied to ToughButterCup's topic in Flat Roofs
can we have drawing of what you have please ? are posi not deep enough to make holes in for services? where is the insulation for the flat roof ?- 2 replies
- suspended ceiling
- dropped ceiling
just to add another dimension and possible way to do things I ran solar thermal evac tubes on my house for years and I found them very good for dhw and indeed also helped ufh they were removed when i went ASHP-cos i would not get same RHI if they were fitted nothing to stop you fitting solar after doing RHI claim ? anyway what i had was unvented 300l tank which had solar coil at bottom ,then UFH coil in middle of tank dhw at top --with cold mixing on out let --so i did not waste the heat i stored by adding a lot of cold at taps and the parent volume of the tank was heated heated if needed by a lpg boiler In truth it was not a large enough tank cos i could boil it in the summer just with2 x20 solar panels - I fully understand the heat loss argument I ended up surrounding my tank with 50mm pir pipe insulation segments --stock item as tank was 500mm this made a major difference to heat loss --but made summer boiling worse .LOL so only real downside was tank too small 80%of the year i got all dhw from solar +some UFH --which due to old house design i needed more than you would with modern house --overheating of house was and never is a problem If doing it again i would have at least 500/800litre tank with same coil configuration and as tall as you can fit --taller+ larger if you can accommodate it and maybe UFH coil closer to bottom I not looked at it yet but maybe ashp coil in tank at that level as well rather than heating all tank--that will be investigated once i have the plot sorted +house design If you have PV then maybe elec element close to top of tank to boost dhw when solar cannot _+ If you have free energy --it will fill the tank downwards and allow solar coil at bottom to work at low temp in winter when you maybe only get 30-40c on bad days -which with passiv type house etc is plenty for UFH,as most of you are saying your floor is running at 20-22c + 150mm of pir around it and all pipes lagged -above 150mm the extra cost /insulation is not cost effective-so Kingspan man calculated taller means more thermal stratification to get best solar gain and DHW production and you do not want the water stirred up - solar coil would have a "top hat" over it with a pipe going to top of cylinder so hot water goes to top ,if hot enough first ,with side outlets at different levels so it heats where it can I know this tank sounds expensive --but balance that against cost of multiple sunamp units Yes PV can be used for other things ,but if you have space for both ,then your PV can do things other than water heating , solar thermal can do DHW-and some of the UFH I believe there is a good reason for both in a balanced system ,if space available for panels - I do not think that now PV is here that solar thermal is obsolete-it has a place along with PV what i have yet to find is a direct comparison of pv /verus solar --purely for heating water -on A DAY WHEN EITHER CAN DO IT I suspect solar thermal will be be better -as you make voltage ,transform +invert it before you send it to an element -got to be losses !! solar thermal is direct+ much simpler I think the previous posts over estimate the maintainence problems i ran mine for close to 20 years with no problems other than those caused by me in a round about way the boiling problems --due to too many panels and not large enough tank -fied a sensor which then allowed it to keep running -=-result all foam insulation on copper pipes melted off !!--so that was in excess of 170c another thermal sensor in another postion as a safety measure would have stopped that -which i then fitted apart from that I spent nothing on system when i removed it i found some of the tubes were blown --but i am putting that down to my major overheating issue --but even with 6 out of 40 tubes gone it was still working ok the cost to repair would be less than an invertor replacement .
Engineering bricks with through frog holes, a bit daft?
scottishjohn replied to epsilonGreedy's topic in Brick & Block
the way i was told -long time ago was 3-1 is a pointing mix ,very very strong 4/5-1 brick laying mix ,depends on sand type as well yes plenty use 6-1 no problem - -but the problem with mega builders was I think it wasn,t even real portland cement ,but a cheaper type mixed with other stuff,then made weaker cos it laid up easier not the right thing for all weather building why would you use 6-1 --half the cost --thats why -
Takes away a lot of of OUR problems building this way!!
scottishjohn replied to Pete's topic in New House & Self Build Design
any one where you can get people who work that hard ? -
I keep doing the lottery --I really need all 3 pieces of equip tractor with front bucket + self loading pan mixer on the back ,telehandler+ man cage + 5ton digger I keep on dreaming
not convinced you will ever get celotex packed in an i-joist or anything as well as this integrated stud. you could of course use your I-joist and spray foam them ,but a different way and no metal in wall
I know first time Iwent ot kenya big game fishing in1982 we would look for the birds to find the fish and rom the flying bridsge you could see the sholas of tuna would strech for maybe 10-15 miles and you just criss crossed them -to catch fish last time i went 5 years ago --all gone lucky if you find a shoal more than a few hundred yards long . that si the proof ir you needed nay that we as humans are too many and using up all the worlds resources quicker than nature intended or can replenish them reduce population --you reduce ALL of the worlds problems how you do it is another thing which is why I am amongst the "doom +gloom old men " that can see no real solution other than population reduction or at leat hold it where it is and do all the other things as well I don,t need to surveys done by professors etc to see what has happened to the natural world in my life time , salmon stocks less than 10% of what they were in the 50,s ,herring fleet --gone -bees ,birds ,buterflies -etc etc . all of these are due to direct pressure of populaltion
which comes back to where i started - we as individuals can do SOD ALL to make any difference. the government has been trying to raise fuel duty,to encourage people to use less, now for many budgets and every time do not --afraid of outcry from population+ biz why are cars not taxed on BHP --not matter how you want to cut it -you burn energy to make bHP --thats physics so bmw m5 should by £2000 road tax--slightly cheaper than a 44ton truck and your super cars 600bp etc £5000 a year -if you can afford that sort of car -5k for tax is no problem ,and not just have high first year duty . no politics will control what could be done
the reality is it cannot or we would not be having the planet problems we are at this time . ye if we get a killer virus that wiped most of humanity out the planet would recover over time --so all the problems are man made and the human condition says people do not change their ways unless they are forced to people who believe they will are living on cloud or "never never land"
no they have a cheap energy supply and cheap labour all raw materials are a world price --they only things you can control as a country to make goods is energy costs and labour costs ,and taxation which is why there has been a shift in mass production from country to country since ww2, used to be japan ,then taiwan and INDIA at the moment it is china already the middle classes are wanting more money etc ,so it will eventually move to africa or south america --as wages rise in china
until they get cheaper ,by a margin ,which i doubt ,then without some sort of FIT -tax credit --what ever--it will still not attract the volume needed--maybe a zero rate finance scheme ,as i was offered for my If i fitted panels --downside was i needed to use 70% of generated elec on site-- not possible with a service industry - my south facing roof is 30.m x 16m--480 sqm --thats shed load of elc prod and i already have 60va 3phase ,so was possible to do- just i,m to old to get the return -
yes you could,and i am looking at that but also to be fair you should have a different FIT depending on how far north you are,due to reality of how much you can generate
so with the law of supply and demand you havejust given the reason why MCS charge what they do to make it viable for them to continue
theres about as much chance of that happening as anybody tackling the real problem which is over population . tas for tackling imported goods that have been made using cheap energy --I,m all for ramping up import taxation dramatically eg --Ican buy fuel injector in EU for £42for 20 units per purchase -retail £98each i can buy same unit from china for £13.20 inc transport --now you could 20%-30% import duty and i would still buy from china - that taxation could go to make us more eco friendly in energy production.--but again never going to happen so anything an individual can do is bugger all in the scale of things--FIT --or TAX credits ,which is my current favorite idea is a way you could increase micro generation quickly by a large amount
My answer to you is if you think it is such a gold mine --then start up yourself and under cut the others and make money by being booked up in advance a year in front thats how biz works
sub-sahara --will be using PV ,wind or solar thermal ( to drive steam turbines) any way --not coal its china +polland +germany that are main culprits there --all developed countries and in temperate climates ,which is why wind in uk is best option --other than hydro ,which very few governmenst wants to make long term investment in dams . plenty of big rivers in europe they could use. no reason why the thames barrier could not also be be tidal generation as well--short term thinking again
MCS covers the whole lot, so what's really needed is something to compete with MCS, or that allows any competent person to demonstrate compliance with whatever set of regulations needed, in some other way. I do not see how another body will make it any cheaper ?that is purely down to supply +demand my plumber who fitted ASHP was happy to get the work ,even after me asking lots of questions on how he was going to tackle the job, so i don't think he added much at all to price ,as i got attempted to get quotes from 6 different companies to replace my gas boiler with an ASHP 3 said they would come ,but don,t think they liked me saying ,don,t just send a salesman ,but one can actually answer engineering questions about the job --so 3 never came of the day appointed day to quote 3 did -and one I discounted after a 10min conversation --he failed the exam .LOL and eventually picked the slightly more expensive one after his interview i already had UFH --so it was just a a heat source change
I agree with most of what has been said but I think the real reason MCS came about was the government misguided belief that it would stop a cowboy industry starting up like double glazing was in the beginning. where they would be paying to support and encourage its take up so having a requirement for approved fitting network to industry standards -makes nice clean break of responsibility and supposedly gives MCS system some control over standards of fitting as it encompasses not only electrical work but total fitment of systems Its not just PV but all micro generating systems that could attract grants hydro ,solar thermal ,wind,biomass ,ashp ,gshp etc technically there is nothing stopping you doing it and just paying for a completion check by MCS approved engineer who will make out the paperwork It would interested how much of a premium they really charge over what a normal plumber or sparkie would do -NOT diy where you are only paying for equipment-that is an unfair comparison . thats like someone complaining i want to charge them £800+vat for fitting a clutch to a 4x4 ,where I have to remove engine to do it and telling their friends the bits are only £150--"what a rip off" -- and they spend 3 or 4 days doing it as a diy job. no the bottom line is that the pricing of systems and no FIT will control the up take due to pay back period --not really the MCS costs
Accumulators External installation or other options
scottishjohn replied to Alex's topic in General Plumbing
adding a pressure boosting pump could be cheaper and simpler to fit than a large accumulator ? worth checking out -
this looks is very interesting development in TF construction --
when governments do their bit I will do mine and they can start with air travel and the pollution that causes and follow that up by stopping all coal fired power stations world wide what i can do to make any difference is--sod all. making it viable for us to help is what is needed and as long as we get taxed the way we are we need all the help we can get how about a tax credit for all green improvements?. thats a very low cost to them the same as registered charities get if you make a donation ? you give them£10 --they get tax credit form government for same amount
