scottishjohn
    23
  1. correct the eps in those systems is purly insulation and a former for the concrete -no structural value once concrete is poured. but whatever system you use you have to have an insulation layer between concrete and UFH -or you will be making a radiator out of the floor structure to heat down stairs workshop-very expensive to run if worried about fire below then maybe you should be fitting sprinkler system what ever system you use simple to do and can run on mains watrer pressure
  2. I,m sure this will be covered in the converstion with the drilling men -- there are 3lb+ trout in it and lots of roach - -so it can,t be that bad and of course i willl get the water tested at some point. a 6acre pond which has depths to 50ft ,so i,m assured by quarry men that used to work there, again we will have a wee boating excursion with a plumb line to confirm It is a large body of water and a very nice blue colour when the sun shines and so clear and no weed I can see at all -
  3. Ok --thats what ithought only some are advertising black as suitabler for potable water--will ask them more questions
  4. that could be true --but need to allow for worst scenario of sucking directly from quarry pond at this stage if you add 50% for hard rock thats over 20K and not having to run a 3phase cable down to pump at bottom of hill will save £2000--we will see what drilling men say this week
  5. nope sucking will not work head of pump is always many times what it will suck ,would have to be 2 pumping stations -so might as well have one big one at bottom --juts needs 16bar pipe nick-- can you tell me is black pipng passed for potable water ?
  6. not b+b but renting out parts of building as self contained accomodation
  7. I will be asking for a quote for a 450 ft bore hole --but i thinkthey will never give a fixed price quote --we,ll try and even then will the flow be enough
  8. still need a very large tank i talked to a eco guy from up north west who does this sort of thing and he admits that with even just 3 people his 9000litre tank runs out in dry times in may ,as its quite dry then my idea is not just a house for the 2 of us but as it is so big there will be 2-4 letting sections of it as well --so that means water usage will be quite large in summer when rain and stream is worst and maybe 12+ people If i rebuild all of the building it will be 700+sqm-- so how big a tank for that 30000litres? taking assumption that its 150litres a day per person --12 x150 ==1800 per day and could be more --so with say 3 weeks no rain --thats 37000litres- I know its all guess work --but now is the time to make sure you get it right the pump i,m looking will deliver 2000lpr hour --so will only need a sensible sized pressure vessel+ maybe a pump to keep pressure happy when al showers etc going at once . to be honest it would not cost that much more in the scale of the project to have twice that volume. I think there would be more pain with rainwater +purification system longterm
  9. problem with that will be the adjacent quarry -- quite sure tthat with it being a sheer face within 80 yards of the house the subterranian water will go easiest way and I know there is water coming in to the quarry from the rock face at low level so there will be no water till you get down to below level of quarry pond --so thats 450 ft hole in solid granite drilled at a slant to be sure --its a big pond a good few acres could be wrong but thats a big expensive guess
  10. I think I might be holding up completion till i have a reasonable solution --one that don,t cost 40K for water supply
  11. or use an insulated type conrete floor set up and just uFh into that there are lots ofsystems now where you use insualtion as the base for the concrete floor /roof https://www.quadlock.com/ICF-Floors-and-Roofs/quad-deck.htm one of many izodom2000--ukagent is in scotland https://www.econekt.co.uk/wp-content/uploads/2016/02/ECONEKT.-ICF-Elements-Brochure2.pdf see page 35 i,m sure lots of others as well
  12. yes the road to get there ,which has no mains water on it--last house connected is 300m down the road and 60 m lower and then my own road of about 800yds is not viable. the easiest route would mean a wayleave through another piece of ground which is slopy very rough fields no gaurentee i would get it
  13. I agree if I can find asuitable location for pump station --but std rate for blue mdpe is 12,5 bar not 14 -so still short to get 2 bar at house ,yes i could use a booster at house --but 16 bar pipe sorts it simpler - more later when definite numbers are known I still have to find a suitable route as well around the many rocky bits so I can bury it enough going straight up the face.which would be simpler , but that would mean fully insulated piping so it can,t freeze in winter the only insulated pipe I ,ve seen would be MEGA EXPENSIVE for the length required a knotty problem all round using rianwater and surface stream + very large tank would be a problem if we get a winter like is forecast--no rainwater and stream would be frozen iwonder how much insulation would be needed --for -14c when mians water will be around 5-8c
  14. thanks ifound that website --but no mention of being WRAS approved and it needs to be 50 mm --but they do that as well -sent email for clarification
  15. not sure i will use what i have --but maybe a good ebay sales item .LOL there are even soeme lengths of 4" plastic thick walled stuff -- not sure how long --but looks like a lot . and the scrap on the site-- huge winch s and rollers -- --all will help the coffers If i got enough of the 2" galv --maybe get a quote to re galv them -- and to think i sold an electric piping thread cutting bench a few years ago -- maybe going to need to hire one --
  16. fully granite --you could paint a foundation line and build on it 6m is accpetable +hire of joing tool if nec## but will abs not be very rigid --will be hard to make trenchs for non flexible piping £6 m x 400 = alot you would need 2 pump houses then --no not a good choice I feel
  17. yes could do -its twice the price of mdpe and as you say in rough uneven ground a pain to lay --it will be heavy diggin as most of it will be rock change when below 10bar --to be sure --not sure what the coulings are rated at ==that will be next hunting job --but suppose at a pinch could use compression fittings
  18. Ijusat found some black 50mm -16bar https://www.mjabbottdirect.co.uk/Products/DUCT,-PIPE-HOSE/PE-PIPE/Black-Water-Pipe/Black-HPPE-Water-Pipe/50mm-x-50-metres-HPPE-(PE100-SDR11)-water-pipe-to-BS-EN-12201-16-bar-BLACK but no mention of WRAS approved--not sure if that would be a problem
  19. I have found some mdpe 63mm at 16 bar --so will keep hunting -maybe change size half way up
  20. it is next to a quarry so there is loads of galv piping that was used for water supply to cutting machines etc in the quarry -- how corroded internally will be the worry --certainly no sign on outside of galv piping -- but 30 years since being used!!also need to check size mains at road level will be at least 3 bar i think( looking at houses along the main road and thier height above it) ,but they will never warranty anything more than 1 bar-- so thats still leaves us needing a better pipe than std 12.bar maybe i got to get mains connection and measure what it is and then make a decision on pump station location still a bit iffy cos it could change right pipe is best idea no problem in getting a pump to do it ,other than the usual one -cost - it needs to be a single phase 2.2kw -or a 3phase --looking to about 2.5-3k +cost of tank and pump house structure I,m erring towards 3 phase as cable size i have to run to it from house 400m away and that changes in size alot between single and 3 phase due to amperage only scratching the surface of the problems and possibilites of this site__must be mad maybe even some hydro --but all costs money to start with I think i will end up selling a house on other side of the quarry , to get some money to do what i want and itsplot is 5 acres+ i see every possibility for another house plot there as well!!--it also has outstanding views and possibilites for life style biz with holiday cabins etc up the hill I no doubt will be offering you boys wonderful oppertunites shortly -if you up for the challenges will post it all up ,when finally the ink is dry on the contract I,m probably mad at my age --but it seemed too good to turn down --got to take a chance and something silly once in your life #worst case scenario is i sell it again at some point first job is 100+scyamores+ ashes to remove and many fallen trees as well --so first thing will be firewood biz -maybe find someone who wnats to do it ,and just take a cut,get vsome money back in the coffers
  21. I have mains water at sea level house is 440-450ft ABSL obvioulsy will check it exactly once on site and work our how long a run guess at this time 400m that would mean 2 pump houses and multiple pumps and there would be no road half way up the hill finding the right pipe will be cheaper but all suggestions welcome
  22. Hi, the plot I am in process of buying --more later -hopefully all sorted in next 2 weeks --been a long haul the house is 140m above mains connection I looked into rainwater from roof supplimented by very small stream -which is not constant --but talking to someone who has done this -i would need a very large tank --10,000litre min -then a treatment plant --so costs are high how ever I do it so i need flexible pipe to go from pumping station to house as the terrain is not flat and will be hard digging -approx 400m --very much all rock normal blue water pipe is only rated for 12.5 bar and at bottom of hill it will need to take 14 bar-- 204psi now i can find 16 bar black pipe but no blue mdpe rated above 12.5bar is it permissable to use black type for supply from my pumping station up the hill Is there any WRAS approved flexible that will take that pressure --do not want to use straight lengths --shape of ground and too many joints are there any other options like galv metal pipe up a distance then swop to blue ? alot of it lying about on the plot--need to check size 50mm is size the pump suppiers want to use first thing i was told i cannot connect pump direct to mains --so i have to start from zero head at pump station from a tank which is fed by mains open to suggestions.
  23. there are a few systems that use insulation as the roof to then pour your concrete on to https://www.insuldeck.com/ thats first one i found --lots of others.
  24. and of course you wil have the opposite curve on the inside wall--so 2 lots of filling to do
  25. too late now but maybe you should have laid insulation and cast concrete roof on top of it ? suppose you could fit insulation and then cement board or a 2" cement screed and then tile on that that and drianage from above that I could be wrong but seems very complicated with pedestals and a wet sump area around your insulation --which could freeze in winter and no plywood in the construction anywhere --thats just a booby trap waiting to rot away
