Everything posted by jack
Good spot, thanks!
I know what a Willis heater is thanks (I seem to recall discussing whether to install one as the primary immersion way back on ebuild when doing our initial design), I'm just interested in how Terry's arranged it within his system. The arrow I put in the pic above points to something vaguely the right shape, and I can't see anything else suitable in the pictures.
Interesting stuff @TerryE, thanks for sharing. Do you have handy a schematic and/or photos showing how and where you've installed the Willis heater? We're about to have some work done on our heating circuit and it would be a good opportunity to plumb in at least a connection point for a Willis heater for backup. Many thanks.
What does First Fix really mean?
jack replied to ToughButterCup's topic in General Self Build & DIY Discussion
This, this and this. We took hundreds of photos, and they've been incredibly useful. Even so, I wish we'd taken more - a full set as soon as the studwork went up, and another set after each trade finishes (or periodically if they're all working at the same time). You mention your electrician - oddly enough, our electrician was obsessive about this (he's the one that encouraged us to do this) and took a lot of his own photos. Occasionally, the ones he's taken have shown the relevant bit that we've missed or had a poor angle on. -
Yep, exactly this. Drain runs can be hard enough even going first if they haven't been planned in advance. -
See page 26 of Part F - the minimum area is 7600mm2. I guess this is roughly based on a standard 2'6" door (7620mm) and a 10mm gap. Wider doors can get away with a bit less. This is the architrave detail we used.
I think you should balance the system with the doors how you usually have them. For example, our bathroom door is closed for less than half an hour a day. Bedroom doors are almost never closed. The only doors that're regularly closed are those on the utility room and TV room.
If you need to meet building regs, you strictly need to have a particular cross-sectional area, which ends up being 10 or 15mm (can't remember) across a standard door width.
The recommended gap is either 10mm or 15mm - I can't remember. It's a lot though! There's a formula for the size of the aperture, so you may get away with less if you have a wide door. I did a concealed gap in the top of the door frames, but I'm not sure it's actually worth it, especially given how infrequently doors are actually closed in our house.
Not a bad idea. I wonder whether it would leave it feeling top-heavy?
- 64 replies
- makita
- drill driver
I just wanted to buy a garden but had to buy the house!
jack commented on mike2016's blog entry in The Fun Irish (House)
Great story, thanks for sharing. Careful with the magnolia paint. Too much and you could end up accidentally making the house worth a lot more. -
UFH in slab or screed, eps or pir insulation?
jack replied to Tin Soldier's topic in Underfloor Heating
It probably depends what's going on top. We have EPS 100 under most of our MBC slab, with EPS 300 under the ring beam and areas of high load. That's a structural slab though, which has to handle the weight of the entire house. I haven't read everything above, but if it's just a floor slab that isn't bearing any walls, EPS 70 may be fine. That said, it depends very much on what you're actually doing - I'd be checking with your engineer or the suppliers (and building control officer) for advice before committing to a solution. -
I also wish we'd thought about this at the planning stage. MVHR is great, but during hot periods in summer, the only way to keep the house cool is to leave windows open overnight. While we're not near any significant watercourse, we do seem to get a few mosquitoes in overnight. There are roll-down and magnetic screens available, but they look a bit cack in my opinion. Perhaps if you plan to integrate roll-down screens from the start, you can conceal them so they're aren't so obvious. You also have to consider whether your windows open in or out. If they're inward opening, you really need an external screen setup, and vice versa.
I've heard mixed reviews about Milwaukee. Apparently they used to be top drawer, but were bought out several years ago and quality may have suffered. AvE has covered this in passing more than once on his Youtube channel. His review of one of the largest Makita cordless drills is here. By coincidence, I'd already bought the Makita DHP481Z, which is either the same as the one he reviews or very similar. This thing is a serious bit of kit. Amazing torque. I used it to drill about 30 x 12mm holes through softwood to the full depth of the bit, and the motor speed didn't drop even when being pushed hard with the bit buried to the chuck. I burned out a cheapo corded drill from Homebase doing something similar. One thing though: it's heavy! I wouldn't want to be spending a lot of hours holding it overhead or at odd angles unless you have more masculine wrists than my dainty things. Looking back, I seem to have gotten a good deal (£105 delivered) from FFX when I bought it about 18 months ago. I also have the basic model Makita LXT impact driver, which again is amazing. I used it to drive long galvanised carriage bolts into the holes drilled above and again the whole experience was effortless. These were the first time I'd ever spent money on decent tools and there's just no way I could go back to cheap tools again. I'm sure you'd get a similar experience from DeWalt and others, but I'm very happy about having gone down the Makita route. Oh, and I use generic 4AH batteries, and they're brilliant. To be honest, unless you're drilling all day, you'll be hard pressed to empty one of these of charge in a hurry. Takes only 25 mins to charge from empty as well.
- 64 replies
- makita
- drill driver
All our bedrooms have floor-mounted outlets and they're fine. This also reduced the amount of ducting we needed, to the point where we got away with one fewer rolls ducting.
I recall reading that every time you give a fresh deck of cards a good shuffle, you very likely arrive at a combination that has never existed in history. The number of possible permutations is 51!, or: 80,658,175,170,943,878,571,660,636,856,403,766,975,289,505,440,883,277,824,000,000,000,000
Don't worry, this won't be the last time you'll feel like this! You don't just have to ask for advice - feel free to have a rant as well. As long as you're working and learning, you'll get sympathy. Virtually all of us have been there are some stage (some of us several times!) Keep your pecker up and crack on. Oh, and I echo what Ferdinand said.
Agree with all the above. If the architect's fees include full management throughout, then perhaps you can disengage from them once you having planning permission. I know both the architects we worked with were happy to stop their involvement at any point (and both were happy to consult later on an hourly rate if needed).
Okay then, it's a common misspelling.
A misspelling?
Very neat install. No way I'll show you the current state of my Brink 400 Excellent!
Build cost regional variations.
jack replied to Dee J's topic in General Self Build & DIY Discussion
I was about to say that the corresponding pay-cut would cancel out the reduced commuting costs, but then I recalled how much some train-drivers are on... -
Exactly right, but then the cost of commuting can itself be eye-watering. Before I gave up working in London last year, my season ticket (just the train - no tube/bus) wasn't far off £4,000 a year for a trip of under an hour. I reckon commuting cost me £10,000 a year in gross income when I added in things like lunches, the odd drinks after work, and buses when it was raining or I was in a hurry for the train.
