Everything posted by jack
Lower application fee for a Householder.
jack replied to epsilonGreedy's topic in Planning Permission
Exactly my understanding too. That's what we did. We said "Well, we're 50:50 on whether we'll knock down or extend. We're just after an in-principle idea of what sort of thing, generally, might be allowed as a result". The planning officer eventually - and begrudgingly - agreed to give us the informal chat we'd booked. She then went on the say "I hope you're not planning anything from Grand Designs. We hate Grand Designs around here". I was in the process of pulling an issue of Grand Designs magazine out of my bag to show her, so quickly changing to a self-build magazine that had some more conventional examples. She also boasted that they'd fought several applications for Huf houses and had successfully knocked back all of them except two. Both of the Huf houses I know were built are out of sight of the road - I can't possibly see what basis there is for arguing against modernity on principle, especially when no-one other than a visitor to the property can actually see the house. In the end, we got something very modern (eg, flat roof) through, so it can be done. Short answer is likely "no". You can't pay householder fees on anything involving a new build, whether a replacement dwelling or a new build on a vacant plot. -
We had this issue when we approached our local planning department for some informal advice about knocking down our bungalow and rebuilding. The moment they heard we were considering knocking down, we were refused an informal discussion (which are advertised as being available for householders) and were instead told to pay the fee for pre-planning advice for non-householders. From memory, if you're building a new house on a vacant plot, or knocking down a house to rebuild, you can't be a householder. By definition, you're a developer, even if you owned and lived in a house that is to be knocked down and rebuilt. I don't know what the definition is if you're just doing an extension. -
Ventilation rates
jack replied to Gone West's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Similar here. 289m2 house, four occupants (and a doggo), and we run the MVHR at 80m3 per hour. In fact, we ran it at 50m3 per hour for the first year we were here and have never had any issues with moisture or air freshness. I think the critical thing is that the air is being refreshed continuously, even when we're out, or there's only one or two of us at home. There's no boost when people are having showers, and steam clears away very quickly. The only time I turn it up is if we're going to cook something smelly or we have a lot of people over and need more fresh air. -
MVHR ducting to outside
jack replied to Moira Niedzwiecka's topic in Mechanical Ventilation with Heat Recovery (MVHR)
One thing you might find handy is suitably sized grommets: https://www.greenbuildingstore.co.uk/products/pro-clima-roflex-pipe-grommet/ Much neater than strips of airtightness tape, and less likely to fail over time imo. -
Really useful summary, thanks so much for posting it. One minor point: isn't the Brink (we have the Excellent 400) meant to be self-balancing? I don't know what period it achieves this over, but 100m3 seems a massive difference between supply and extract. I wonder whether that's after it's done its best to self-balance? When I did a preliminary check on ours, most terminal flow rates were within 10% of the design. Most were slightly under, so I just bumped up the overall rate and that got me there (other than the utility room, with an extract about a metre from the manifold - was overextracting by 20% or so, which I fixed by adjusting the terminal).
We sweep ours with a wide microfibre brush. Doesn't take long. Other than that, we just do an occasional mop (probably not as often as we should, if I'm honest). Seems to work fine.
- 13 replies
- polished concrete
- inslated floorslab
- (and 4 more)
I bought a Miele washing machine last year (similar deal - on special, with cashback and free 1 yr detergent, plus 5 year warranty). It arrived with literally no screws holding the rear panel on! From my subsequent conversations with the retailer to get it replaced, they are indeed delivered direct from Miele.
I think the thing with Miele is that their stuff works better, and in general for much longer, than that of other manufacturers. It's when thing go bad that they seem to fall apart. I beggars belief that a company can sell such a premium product and yet apparently be so bad at customer service.
We have polished concrete over a structural slab. We had to go for 65mm rather than the 75mm minimum suggested, and have ended up with a couple of cracks. I haven't tried filling them yet, but they aren't the end of the world. A few things: As I said, the minimum is 75mm - thicker is recommended. That's a lot of concrete if you already have a structural slab underneath, but hey, concrete looks cool! The polishers can only get so close to walls. We did ours before plaster and skirting boards. Even so, there's a clear region along every wall that was polished by hand tools rather than the big grinders, and this does look different, and in a few places is slightly undulating. If you're happy with this (we are - we think it adds character), it isn't an issue. If you aren't happy with a different-looking edge, then the pouring and polishing needs to be done before the frame goes up. That allows the whole surface to be polished, so you get edge to edge consistency. You then have the not-insignificant problem of protecting the floor for the rest of the build, including while the frame goes up. Whether you get polished concrete before or after the frame goes up, you will be protecting it for a long time. We used Correx throughout the ground floor. Even though we taped it at every edge, we can still see dark lines in some areas where the joins were, two years after moving in. Also, dirt and dust finds its way in, and can cause scratches. Polished concrete companies get their concrete from local suppliers. In our case, we wanted to see a small amount of exposed aggregate visible after polishing. We really didn't want black/dark aggregate, but the company couldn't/wouldn't make any guarantees about aggregate colour. Was fine in the end, but a risk, albeit slight (I've never seen black aggregate anywhere near where I live. We have numerous sand and gravel pits nearby and they all have light stone). Concrete can be tinted to whatever colour you like. We wanted something a little darker than one of the standard tints and the company was happy to come up with something custom. Again, it was to our risk whether we were happy with the colour when it was down - if the concrete had been yellower, for example, that would have changed the colour in a slightly browner direction, but in the end we got a nice warm dark grey along the lines we were expecting. Concrete is easy to keep clean, but even with a sealer it can stain. My wife accidentally left a bin bag on the floor overnight once, and some sort of fluid leaked out. We now have a large, permanent dark stain in the kitchen that's a bit unpleasant. I personally wouldn't have concrete in a kitchen again under any circumstances. Would I go for concrete again? Not sure. I suspect that large-format tiles are a hardier long-term solution, but let's face it, they aren't polished concrete! If I had my time again, I think I'd perhaps tile the kitchen and have concrete everywhere else. One thing I really like is how it feels underfoot in summer. Winter... less so, especially when the ASHP is on the fritz so the slab is unheated!
- 13 replies
- 3
- polished concrete
- (and 4 more)
Snug passivhaus dwellers?
jack replied to epsilonGreedy's topic in General Self Build & DIY Discussion
We just don't have the solar gain unfortunately. The one one decent window on the south side is shaded by a large tree most of the morning. Still pretty warm, and very comfortable, with not much energy, which is the main thing. -
Concrete can develop fine surface cracks depending on various factors during curing. They don't affect strength, as I understand it. Whether this is what you have I don't know, sorry. Definitely one for the supplier
Bugger, what an inconvenience. -
I did the same! As for living in a passivhaus-level house (in terms of insulation and airtightness, although some of our windows need adjusting at the moment), we're still waiting to get our ASHP fixed. As such, our sole source of heating for the entire winter so far has been a single 2kW electric column heater in the kitchen, with a small fan on it blowing the heat around. Mostly I've had it on the medium setting, but turned it on full for the colder weather recently. It isn't on all the time, and I usually have the thermostat set at 4 out of 6. We've been perfectly comfortable (my wife would say it's too cold, but she always thinks it's too cold). At the moment, it's -3 outside. I'm sitting here with a hoodie on, in a room at the other end of the house from the heater, and the temperature is very pleasant. The bedrooms are somewhat cooler, as usual. The bathrooms could do with being 2 or 3 degrees warmer, but they're still warmer than in any house I've ever rented. I am having to wear thick socks, because the unheated slab is very cool (we have polished concrete throughout our ground floor - not the warmest option in this situation!) Incidentally, I just received my electricity bill for the last quarter and it isn't much more than for the same period last year. That really surprised me. -
Feel free to post your detailed construction drawings in the relevant subforum and you may get some useful feedback, even just along the lines of particular areas you should be watching the timberframe company.
Check your building inspector doesn't want more. There's some official-ish document around that suggests 10mm if I remember correctly. It's based on the width of a small imperial door and anticipated flow rates - something like that. Edited to add: Knew I should have searched before posting. Here it is: http://www.titon.co.uk/pages/knowledge-support/building-regulations/part-f-ventilation-england-wales.php
Ha. I remember being in that phase. You'll be absorbing information for weeks. It's extraordinary how much there is to know! Even now, I only realise how much I've managed to learn when a friend doing an extension asks me a simple question and I suddenly realise I've been talking for 15 minutes without a break. In the end I usually just direct them to the site...
Welcome. Sounds like a nice plot! One thing: if you're going for MVHR (a good thing - I'd never go back to living without it), you need to be thinking now about airtightness. Little details addressed at this stage will pay large dividends on how easy it will be to reach a reasonable airtightness level. For example, if you're going brick and block, look into parge coating (search "parge" on the forum). Consider how airtightness will be handled at interfaces between different building elements, such as around windows, and where walls meet roof. Lots of info around the forum, but if you have any specific questions, fire them off in the relevant forum and someone will hopefully be able to help.
Welcome! Sounds intriguing from what little we know (yet ) Is there any specific element in all this for which you think some creative input might still be useful? If so, post away in the relevant forum. There are some awfully smart and creative people on this forum. Hopefully someone might spark some ideas that haven't come to you yet.
- 7 replies
- self buils
- flood zone 3a
For a moment I read that as saying they did coffee and cake delivery to local train stations!
- 13 replies
- cold weather
- render
(and 2 more)
Do you ever wear any bloody clothes mate?
- 13 replies
- cold weather
- render
(and 2 more)
Welcome to Buildhub! Don't worry about asking rookie questions; we've all been (and some, like me, remain) there. You can be sure that someone, somewhere already has the same question, or will be pleased in the future to find a great forum thread answering yours. People do love pics, so if you have any you feel it's appropriate to share at this point in the purchase, feel free to do so. Again, welcome.
The spec for all ASHPs will include noise parameters. Worth checking before buying, especially if your neighbor's the one who has to hear it!
I don't think I'd want to either have the ASHP high enough to be near the MVHR outlet, nor the MVHR outlet low enough to be near a ground-based ASHP. Depending on the indoor and outdoor temperature (and your MVHR's efficiency), the MVHR outlet might only be a degree or two higher than ambient. As Jeremy says, the volume of air involved is low, too, relative to what the ASHP pushes when it's outputting a lot of heat. Re noise, our ASHP is almost silent when in heating mode. I don't know about DHW mode, as I'm never awake when it's operating like that!
A forum member/angel?
