nod
Everything posted by nod
Pretty straightforward A quote is a quote Had they got it finished quicker than expected Do you think the would have cut you a discount? I agree will the above But I would try a more straightforward approach Tell him to bugger off
Half a day work saved £125 ? But if they’ve made a good job It’s not a lot in the grand scheme of things
Starlink vat
nod replied to Alexphd1's topic in Self Build VAT, Community Infrastructure Levy (CIL), S106 & Tax
Yes If it’s on your planning permission -
They are correct Window Openings are usually measured through To save paying extra for setting reveals A five bed house would normally take one man four hours to setup the reveals
We’ve contacted an installer for a 14 kw Mitsubishi 12 k supplied and fitted Including commissioning the UFH It only leaves 5 k to buy the pump buffer etc
If it’s a zero dust table you can do all your cutting inside the house with the windows closed
We used black woodgrain Facia and sofits on our first Slate roof black dow pipes Same again on our next
Yes 70 mil Plenty deep enough for a shampoo bottle
Your cheapest most effective solution would be to run a line of silicone around the bottom of the skirting where it meets the floor
which trades, when and in what order
nod replied to Post and beam's topic in General Construction Issues
First fix joinery Studs casing’s windowboards etc Plumber Electrician Lease with Heat pump company if your having one MVR also Then pre plaster inspection Then dry liners Mist coat of paint Plumber electrician back Tilers and second fix joiner back Doors arcs and Kitchen Good to go -
Useful pricing/estimating software
nod replied to Annker's topic in General Self Build & DIY Discussion
In normal times so called professional estimators can be miles out I’m not sure why you would need a QS for a refurb But your local Builders merchants will offer this service for a small fee -
With materials and labour still going up Any estimate that you get will be out of date by Christmas -
Most don’t have a choice nowadays
The guy who sold it to me installed and certified BC will ask 😁
I use an angle grinder with a turbo blade on most things Ive a couple of Robi zero dust cutters Which are handy if your in an enclosed area and several floors up But a bit big for moving around
We planned to build oak in last time and the fitter said he wouldn’t certify
I definitely wouldn’t use hardwall Sand-lime would be more suitable As there is very little shrinkage
Airtigtness of Wet plaster to screed junction
nod replied to FarmerN's topic in Plastering & Rendering
Get your floor coverings down and skirting boards on There's no real rush for a test -
You would be better using 6 mil plasterboard for a base for plaster J board isn’t suitable for plaster If your tiling You can tile directly on to ply with a flexi adhesive
To be fair If water gets past the tiles and waterproof tile adhesive ,you’re pretty much stuffed
If they are being tiled I would just tape the joints If not you can skim over them like any other wallboard
We thistle bonded moister boards for about five years Totally unnecessary Then nothing for about ten years I’m currently doing a site where they have insisted on this Total waste of money
Private BC / Habitation forcing final sign off
nod replied to ellieh89's topic in Building Regulations
Just looking at our previous build We moved in on the 17th of December BC signed off on the 10 of May Vat claim went in on the 12th of June Local Authority BC I can’t remember timescale ever being an issue Though private BC are nearly always more expensive and seem to work to there own rules -
I definitely wouldn’t go for a s##t in there 😁
- 39 replies
- 4
- demolition
- wall
