nod
    72
Everything posted by nod
  1. Vent AxA
  2. I used inline fans in our previous build Clear a shower of steam in seconds You can hardly hear them when sited above the bathroom ceiling
  3. Good point I’d no experience of GRP when I laid ours A friend who works in a boat yard came round to advise me He saiid you will finish with an upside down boat
  4. Yep The back garden to one of the plots The smoke was like a plane crash
  5. We finished boarding the third of three barn conversion for a local farmer I normally order a skip But he said Stak em out bak sev ye cash He turned up this afternoon Dug a massive hole and pushed the pb off cuts and pallets in Couldn’t get any worse Wrong Ge then tipped two 5 gallon diesel containers in and a bit of petrol for good measure Then lit it 😌
  6. We normally use metal knock ins or Tek screws Shot firing can work loose if the block is the underside of a floor
  7. It costs slightly more to tape and joint than Skim
  8. You would be better off going with your first thought Send the drawings out Find.a contractor or contractors that seem ok with references to back this up They will have a standard contract that they use Payment schedule etc Then start going through the fine detail from the foundations to the roof Then modify the contract to suit you both Any decent contractor will sit down and do this with you
  9. We’ve wet UFH on the GF Five bed Solid build and have never used the first floor rads We building a larger house UFH to GF My wife didn’t want to add any rads this time Our bedrooms are usually within 1 degree of the GF I’d seriously look at your insulation levels
  10. Afghan Kebab factory next door 😁
  11. While I don’t have a picture of his kitchen Here’s a car wrap he did for a mate of mine
  12. He did it a Matt black Said it cost him about a hundred pounds He said compared to rapping a full car it was easy Most of the better quality raps will follow the molding's when heated
  13. Our son vinyl raps cars as part of his business and decided to rap his kitchen doors and end panels Looks very impressive There must be others out there doing it
  14. Yes most tiles are bedded on 10-15 of adhesive
  15. Tile adhesive is perfect for setting shower trays Put a bed on the floor and on the back of the tray and level up once set it will never move
  16. The problem with Eco surveys is that they are often not workable Ours shows root Protection that would have blocked any vehicle access We submitted this but had to ignore it No trees lost
  17. Job done
  18. Plus 1 Condensation may be an issue further down the line
  19. We had this also Planners are happy for us to instal two bay boxes on the garage gable
  20. No they are absolutely fine horizontal
  21. Has anyone come across this condition If so Any pointers to the type of external lighting
  22. Yes used them throughout Five year on Still ok Super easy to instal Just click the wires in No fiddly screws
  23. You will find it very difficult and expensive to remove You May find your only practical option is to top up
  24. The last of the electricity quotes came back today £5700 £9200 and a whopping £25000 Apparently they need to dig 50 meters of road up even though we have a post directly in front of the plot
      • 1
      • Sad
  25. We where recently held up on a job Materials left outside three houses for over a week The roofer normally fill the top of the party walls with a fire break then tile in The bricklayers had inadvertently set the wallplate a course low which left a 100 mill gap for fire to spread Three different inspectors insisted the scaffolding needed to go back up Tiles and membrane off In the end they stuffed the void with rockwool from inside the loft If it was any of us 100% the roof would of had to come off Definitely a case of the tail wagging the dog
