nod
    72
Everything posted by nod
  1. Just cut the offending bit out This happens all the time with down lights
  2. NO You can get the same effect by using a foil backed T&G cavity board and making sure all the joints are tight and taped
  3. Difficulty of installing
  4. Always with the writing on show when fixed
  5. Check your minimum height Ours wouldn’t instal into anything less than 1100
  6. Yes I’ve also rendered Plasterboard Same for both Fix S Steel mesh over Fixed with S screw and washer every 300
  7. It’s unlikely that the PD would or could be revoked So there next best option is to play with your head You’ve already excepted the worse that they can do
  8. Vat claim is fine
  9. The core type are by far the best Plenty of water
  10. You don’t need a warranty for a Cil exception
  11. NO
  12. Watching GDs last night Quite a good one A graphic designer and an Architect I did laugh when she said we didn’t plan to be so hands on We are exhausted after working three weekends in a row My wife who doesn’t usually swear Said “Bloodyhelllllllll “ 😁
      • 2
      • Haha
  13. Thanks
  14. We laid just over 400m2 on our previous build No maintenance 5 years on
  15. I bought mine from Buildbase Stock item
  16. You should be able to lever it out with a bar Like lifting a flag
  17. As long as you tell them like anything else
  18. Yes We had that also Examples they gave was jewelry Expensive plasma screens They seem to think Not signed off = A building site with trades coming and going
  19. I think we used Liverpool Victoria last time We started the policy Two weeks prior to moving in and five months till sign off
  20. As above At the moment They are thinking of a number and doubling it Worse case scenario GW companies can easily loose money Muck away can cost a small fortune At least with a foundation design You can be pretty accurate with what needs to come out and what needs to go back in
  21. I had three quotes ALL dismissed it as a bad idea Though I have read somewhere that it would effect the BUS grant Which may explain why they are not keen
  22. it was impossible to dig down to 1800 on our previous build and keep a neat trench Not pretty But worked well
  23. Absolutely we’ve gone Hans Grohe again and Two Hacker kitchens with Siemens appliances
