nod
Everything posted by nod
It’s very difficult at the moment with materials nearly doubling over the last couple of months Plus one with Steamy regarding Architecht and also a very good point made about choosing your contribution method If you are looking for speed Look no further than TF But TF kits are costly Traditional will come in quite a bit cheaper But take longer to get to watertight
underfloor heating Concrete screed for UFH cracked
nod replied to Rowly's topic in Introduce Yourself
Normally a day per millimeter -
Ask your deck supplier for a technical sheet and show it to BC if they or uncertain
Yes BC where fine ALL sites are done like this I set my joists at 600 and they are solid
It’s normal practice to for ends not to be supported As long as all edges are glued I set ours at 600 center’s and they have been fine
If it’s a sand and cement screed Not concrete You need to leave it 12 weeks minimum to dry out and finish shrinking -
When we put the MF ceilings in All pipes ductings and wires are usually in there You could run wires on top of the MF But the edges are very sharp Mostly the wires are clipped roughly in place to the underside of the floor The electricians normally come back in for an hour to cable tie lights etc in position To the top of the MF prior to insulation and PB At 400 center's there really isn’t much room up there
A fibreglass roof is bombproof Pooling or lack of fall won’t effect the roof You need to be careful that you don’t have to much fall As the top Seddons won’t get enough water
Help with steps to get utilities in
nod replied to WWilts's topic in General Self Build & DIY Discussion
Many builders use option 1 due to time restraints I would always get all the drains and services (Ducting) in with the foundations Photographed and filled in If you do this after the scaffolding comes down You start again with all the mess and it all gets tramped into your new home -
DIY - beading a corner of a wall - can it be done by a novice!?
nod replied to TryC's topic in Decorating
Wickes or B&Q will sell singles -
Skim beads for plasterboard Angle beads for brick -
A friend of ours lives nearby this development Not exactly a small breach
Yes a novice can bead the corner with easi-Fil Just butter both edges of the corner with filler Then gently tap the bead on and clean off the excess -
The bit of good news for All Is that while trades will still be busy Those that are claiming the government handout Have till the 4th of June to claim there hopefully last government handout So normal service will resume
This has been going on for the last couple of months Sites I work on have gone from 2 days notice to seven for silo refills Partly the building boom Partly government paying companies to run short staffed
Easi-Fil is cheaper and easier to sand
Your limited for insulation You shouldn’t even put plasterboard in there Most just add a couple of coats of render or cement board and tiles
Just watched homes under the hammer A couple in Wales who have there own lettings and building companies Renovated a property for an investor Total wreck Back to brick New sash windows doors small extension NES kitchen bathroom re wire and plumb Boiler Full re plaster and damp course 15 months Total spend 16K Even with lower regional wages I find some of these hard to believe Im sat here working out the CG for a rental that we are selling We fully done out 10 years ago 2k spent on an electrician to do the rewrite and £ 200 labour to straight swap the boiler We did the rest ourselves £11400 on materials If I had charged for labour we would have been close to 20k Whilst these programs are good to watch They an be misleading
Up Even steel
No They will normally follow the exact measurements on the drawing
The construction type should t make any difference The foundations will be designed to cope with any flooding
Try Home Building and renovation is very good Also Build IT is ok
Probably answer of the day ?
Scaffolding and Vat
nod replied to Barryscotland's topic in Self Build VAT, Community Infrastructure Levy (CIL), S106 & Tax
Most companies will offer to knock the vat off for cash
