nod
    72
Everything posted by nod
  1. I’m just doing some cuts now Ready for morning A masonry day or a hammer and bolster will do the job
  2. You could do But if you look around at other chimneys and Velux It’s quite common Not pretty though Manufacturers couldn’t care less how there product is fitted once it’s left the factory
  3. Looks ok Its not always easy to get the slates-tiles to lies flat over the flashing Especially thin ones like yours With a thicker type you can knock one of the lugs off the tile Which helps Chimney looks good for a fake There’s some real horrible ones being used
  4. Ps Im not a brickie 😁
  5. It’s fine I’ve just finished building the blocks on my chimney
  6. As above Pretty standard stuff
  7. A simple quick Cheap solution Would be to use a self leveling compound to smooth over the adhesive
  8. It can be done quite easily Most of the better quality lasers can be set for slopes Use ceiling Chanel and top hat Set out your hangers and 800 apart (25x25 angle) Then set your top hat at 400
  9. I think most offer a quantity service I would imagine they will use the same software as a QS Jewsons is another name
  10. 15 mil Duplex makes it a pointless expense
  11. 11 is better
  12. The downside is they are often in rotten areas We recently witnessed a young lad knocked off his motorcycle outside the job I ran to help him and two guys with knives jumped out of the car Threatening me Then proceeded to stab the injured lad The site was shut down for four days as a potential murder scene Not a nice place to live
  13. The photo shows one of our housing association jobs Far superior to homes that we do at a million pound plus Drop ceilings under all first floor ceilings
  14. I use a lot of EWI and render as part of my business Whilst U values can vary slightly EWI and render are pretty bombproof I’ve never had any issues over the last 20 years plus I’ve no particular preference over different systems But I would ask your chosen contractor if you can look at previous jobs By the nature of the EWI They should have dozens of completed jobs in your area
  15. It’s probably the most photographed item on my phone Said but true All commercial and often housing associations Price sounds high I think we are around a fiver a sausage Buying by the box
  16. Please don’t say that I buy at least a couple of thousand tubes of the stuff each year 😂
  17. While we can build our house whilst staying in our current home As we did last time We both think we could miss the boat on the sale of house We have a second plot next to our build where we could site a static I know there’s a few on here that have to done this What are the first steps regarding permissions We have a water supply No electric as yet
  18. Definitely need a SE Normally cheaper than an Architect to do the building regs
  19. There’s a real cash flow problem out there Lots of companies are on the brink
  20. If you use gravel Planners will want a rumble strip at the start of your drive 2-3 meters deep
  21. 915 x 2100 is your standard opening size 1010 for disabled
  22. No You haven’t missed anything Your Brickie is correct But what does he know He’s only the guy that lays them Anything other than standard trench block is a nightmare I’ve just laid 340 and had to put a 100 mil concrete block in front of every row for a 125 cavity No 355 trench blocks available I was told they would be double the price if I ordered some and a long wait SE will always over spec BC also Go back to BC and explain the situation You would if you could But you can’t Our brick suppliers have said the 7n FB are being pre orders in there there thousands by Persimmon Barrets etc In the same way that caused the face brick shortage
  23. Yes I’ve seen this lots of times
  24. I think collectively we on here have could probably write a book on drainage issues Also there are quite a few on here who are very savy regarding rules and regulations for septic tans and treatment plant discharge You don’t even need to share your exact location But Scottish and English rules can vary
