Everything posted by Ed Davies
I can't visualize how a blending valve could be set up for the UFH loop but with the towel rail running at full temperature without having separate pumps for each circuit. Alternatively, what about wiring the towel rail and UFH in series so the towel rail drops the temperature a bit then the rest goes into the UFH?
Won't that need annual inspections and all that stuff?
Without an expansion tank, where would the water expand to as it warms up? Why wouldn't the tank burst? Or crinkle up as it cools down?
ICF wall hangers - Lavann..
Ed Davies replied to Big Neil's topic in Insulated Concrete Formwork (ICF)
There's blocking at the end of the joist, two bits vertically between the chords which are held in place by those crimped-on spiky things. Just wondering if they were done at the factory or on site. -
OK, thanks. But was the blocking crimped on on site or at the factory? -
@Alexphd1, were the bottom cords cut to length and the blocking crimped on on site or at the factory? Did you do the rim boards then give them mm level measurements, or what? -
Any chance of taking studs up to the roof? Perhaps 1.2 metres from each end.
I have a few, none of which is satisfactory. A little electric stapler/brad nailer which would probably be fine for furniture stuff running off mains but hardly tacks at all running off either my inverter generator or 1200W inverter - I assume it takes too large a pulse for the inverters to ramp up and give the necessary power. A little Powerfix (Lidl) one which would again be fine for furniture. An Arrow one bought from the local builder's merchant which looks appropriately chunky but usually doesn't drive the staple right in to membrane/OSB, though a quick tap with the hammer sorts that, but worse jams a lot and is a pain to take apart to unjam - have to take off a small nylock nut. Not a happy thing up scaffolding, wearing gloves in failing light. So @Cpd's Stanley looks very tempting. OTOH, I'll need a second-fix nailer too fairly soon so a cordless brad nailer/stapler might be a better bet. I find that it's best to staple two handed with the Arrow stapler as otherwise squeezing the lever can pull the staple emitting bit away from the surface and suspect the same might be true of the Stanley. Not a problem in ideal circumstances but reaching into awkward corners, etc, can make that a bit tricky. So a one-handed electric one might be better. Still, the Stanley's quite cheap so worth having in the tool box, I suspect.
The nail doesn't go through a joist hanger, it just curls back on itself. That's trying with 51mm nails in a Paslode IM360 nailgun. Yeah, I experimented. Cautiously. Wearing thick gloves and safety glasses (I do all the time anyway as I need the bifocal bits). About half way through the doing the various twist nails in my frame. Almost exactly the same number as Russell (5280 for the roof and floor plus whatever in the gable walls).
Roof sarking boards. Treated, untreated.
Ed Davies replied to Russell griffiths's topic in Building Materials
Membrane can be under the counterbattens. As designed mine would be: 1) Rafters (JJI I-beams) 2) 150x22 treated sarking boards. 3) Membrane. 4) 12x38 treated counterbattens up and down the roof, over the rafters and nailed through to them. 5) 38x50 treated battens across the roof. 6) Profile steel sheeting. (Actually, 1-4 are done but the membrane has failed so I'm planning another layer of membrane over the counterbattens). Putting insulation between the battens would be a bad idea. The purpose of the gaps is to allow ventilation and to allow any water that gets under the outer rainscreen (tiles, steel or whatever) to run down. Water can get there by being blown by wind from odd angles or by condensation on the back of the rainscreen. Apart from marking where the rafters are for future nailing the counterbattens' main purpose is to allow air to get up past the battens and water drops to run down the roof. If the battens were nailed direct to the sarking or the gap between the counterbatten but under the battens was filled with insulation then water running down the roof would be dammed by the battens leaving them permanently soaked. Even treated wood won't stand for that. -
VAT on batteries
Ed Davies replied to vivienz's topic in Self Build VAT, Community Infrastructure Levy (CIL), S106 & Tax
If you want to know a bit more about battery chemistries there's worse ways of spending 12 minutes than watching this: -
VAT on batteries
There are probably other things which can be used as a precedent for this. E.g., rainwater harvesting systems. -
I don't think much sag is needed to allow water past but perhaps somebody who really knows can give advice on the wisdom of putting in insulation which might push the membrane up against the battens.
Between the breather membrane and the tiles, are there any counterbattens up and down the roof or just horizontal tile battens? If you had counterbattens, so a ventilation path all the way up and down the roof, the rest would be fine, I imagine. If you've only got horizontal tile battens there would also be the concern that that would be relying on the membrane sagging between rafters to allow any water under the tiles to run down so if you stuff mineral wool under the membrane you might dam the water against the tile battens.
Yep, insulation and PV are amongst the few index-linked pensions available to most of us.
What's the significance of the existing row (or two) of rocks at an angle across?
https://www.downlights.co.uk/aurora-enlite-e5-led-downlight.html says beam angle 60°. https://www.electrical101.com/beam-angle.html says beam angle is right across the beam (not from the centreline to the edge, I wasn't sure). So half-width of the beam is 30°. If d is the diameter of the spot and h is the height of the light above the surface then tan 30 = 0.5d / h d = 2 × h × tan 30 = 1.1547 h. In other words, for each metre the surface is away from the light the spot will be just over a metre wide.
Consumer unit location
Ed Davies replied to Russell griffiths's topic in Consumer Units, RCDs, MCBOs
@Onoff, why do you think PV would make much difference? It's just another circuit, isn't it? -
The columns you're talking about are the four circles along the bottom left of the ground floor plan, just above the windows? Square in real life though shown as circles on the drawing? Four on the drawing but the living room won't be tiled, I assume? What centres are they on and how far are they from the corridor centreline?
https://www.tesla.com/en_GB/support/powerwall/faqs#off-grid “If you are in a remote area without access to grid power, Powerwall and solar can offer an off-grid solution. For our remote off-grid offering, please place a deposit here and someone will contact you to discuss further.” But a bit further down: “I have a wind turbine/hydro turbine. Can I charge Powerwall with it? Powerwall does not currently integrate with other renewable generation equipment. Please stay tuned for future updates.”
Sure, that's why I wrote “an established company (not a sole trader or whatever)”. I'm thinking of companies like kitchen or window suppliers, particularly ones likely to take deposits up front. Ordered a few Velux windows from the local merchants I usually use the other day. Offered to pay by bank transfer to save them the credit card fee but the manager was caught out and didn't have their bank details to hand which surprised me, thinking that most tradespeeps must pay their accounts by bank transfer. Or do they use credit cards for another month's credit?
If an established company (not a sole trader or whatever) won't take credit cards isn't that a bit of a red flag in itself? I'm thinking that the credit card companies will do background checks or watch the company's record and refuse service (or charge high fees) if they think much in the way of Section 75 liabilities are likely to come their way.
What is a sewage treatment plant???
Ed Davies replied to Big Neil's topic in General Self Build & DIY Discussion
SEPA would only allow my plans to discharge to a watercourse because the ground doesn't percolate. If any sort of infiltration was possible they'd have required that, so in that sense they have a preference. -
If it's not overlooking anybody or otherwise going to be a problem wouldn't this be a non-material amendment? £45, IIRC, with Highland Council, presumably similar elsewhere. Downsides: if they do turn it down for any reason you a) haven't got any excuse and b) have drawn attention to the matter.
Ah, that's probably where I got the idea that septic tanks aren't allowed - it was in discussions of sites that don't percolate (like mine).
