Everything posted by Crofter
My gut feeling is that it would be the other way round. When you use boost it's because you're in a hurry, so you don't want to wait for the whole tank to heat up, hence you use a higher up element and just boost the top of the tank. Could be wrong, and often am...
Thanks Jeremy, I get a bit confused because my current house uses a rather peculiar dual circuit system. If I could drift the thread a little, I have yet to get my head around the wiring of the UVC- there are two immersions, and I gather that the lower one is designed to go on the E7 supply, with the top one used for boost. There must be multiple ways of skinning this particular cat, e.g. a simple switch for the boost (pref one that times out after an hour, so it can't be left on all the time), and a timer on the lower one set to sync with the E7 times- or is it better to get a fancy all in one box to control both? Perhaps a question for @Nickfromwales?
Quick question for the ill informed. If I have E7, do I need to sync my towel rail's timer with the off peak time? Or does it run off two diffeent circuits?
A few questions about vapour permeability etc
Crofter replied to Crofter's topic in General Construction Issues
@Ferdinand I've discounted the Kingspan panels already as I can't really see a way of using them on the outside of a small timber frame domestic building without it creating condensation problems. The other issues you mention are also valid- I think there's maybe a reason why we see these things used to build warehouses rather than houses. -
I don't have a specific site in mind yet, it's just a costing exercise at this stage. But you've piqued my interest now... -
The sketch that I'm working to is very utilitarian at the moment- minimum cost design. A 16x16ft box, 8ft high with a 4" fall across the roof. Corrugated steel cladding on all surfaces. It's a fairly brutal look, but stick a grass roof on there and you might get away with it. Alternatively setting the front wall back a foot or two could help, but it complicates things quite a bit and you lose floor area. -
If I don't ask this I will inevitably get it wrong...
Crofter replied to Crofter's topic in Rainwater, Guttering & SuDS
OK so returning to the original question, I need the two bends to be the same, and doesn't really matter what angle I go for. Inclined (see what I did there) to go for the 112.5 for a slightly steeper fall. Next question- with the small quantity I need, if I go to Screwies/Toolstation I potentially have to mix and match to get the quantities I need (e.g. I need seven lengths of guttering, and TS sell it in six packs). Recipe for trouble, or is everything standard sizes? -
I'd be a little worried that larger guttering could look big and bulky on my wee building. Can I mitigate the risk of overflow by having a steeper fall and/or a downpipe at each end? -
Is that these chaps? http://www.plasticdrainage.co.uk How were they on delivery? -
Not an option, unfortunately! -
Council Tax
Crofter replied to RichS's topic in Self Build VAT, Community Infrastructure Levy (CIL), S106 & Tax
Say, hypothetically, you had someone in a tent in the field next to your site... and you felt sorry for them when their tent started letting the rain in... and you let them sleep on the floor of your new build... how many nights would have to go by before your crossed the line and it was deemed 'inhabited'? (asking for a friend, obviously!) -
Council Tax
Some people on here have left their sewage treatment plants unconnected to demonstrate non-habitability, and that seems to have sufficed. -
Just bumping this one as I'm now in need of my internal cills. I had in my head that I would get a piece of oak worktop and cut it down (I need three cills- 1.8m and two at 0.9m) but having had a wee look I realise that oak kitchen worktops appear to be very obviously made up of blocks of wood glued or finger jointed together. As I want to oil or varnish these I don't think it's the look I want. I could take the easy option and use the same stuff as my exposed beams- dressed all round redwood from the BM. I get to choose the exact bits of wood from stock, and there's a wide choice of sizes. It would obviously match the beams, although not the windowframes, which are a darker and cleaner lacquered pine. The pieces I've used for the beams were stored dry but exposed to the wind, and were subject to a fair degree of shrinking/cracking- more than would be acceptable for a windowsill. @JSHarris's radiata pine sounds interesting.Any others to consider?
Thanks all, some good information in there. So I can discount the Kingspan roof panels- thought as much. Shame because in theory it would do about four layers work in one go. It may well be an idea to use nothing at all between the frame and the breather. I haven't used the rigid batts myself but if they are stiff enough not to need to be boarded into the frame on both sides, then that would certainly be useful. I'll have to have a think about how poor I want to allow the thermal performance to get. This application isn't really for permanently inhabited buildings, and low build cost is vital. I totted up my initial buildup idea (18mm osb, 95mm glasswool filled frame, 20mm woodfibre board) and got U=0.3 (not accounting for bridging) which isn't all that shabby really, for what is essentially a shed. If I lose the woodfibre layer it jumps to 0.37 and the bridging gets worse. Up the frame to 145mm and it drops again to 0.25. I really must run these numbers through a calculator which accounts for bridging. Re the inner skin, I'm sure I read somewhere about OSB that was available in a sanded/smooth finish. Can't find it again now. I think it would have to be something like this, or indeed ply, to give an acceptable finish for painting. Rather than using biscuit joints I would probably just use cover strips to hide the nail heads and expansion gap. Scratching my head somewhat for the roof, and specifically how to provide a small slope on what is likely to be a 16x16ft building. For simplicity I think a monopitch works best as it can be done in single lengths of steel sheeting; a shallow duopitch would risk having water blown up under the ridge. The sheet manufacturers don't actually give a minimum pitch for a roof, but I wonder if something like 5deg would be sensible to ensure runoff. A green roof option would be great, obviously at higher cost. And I'm also intrigued by the EPDM roof that @Tennentslager used on his hut. -
Early days yet but I'm starting to turn my attention to future projects (yes, I know). I'm sketching out some ideas for building something small and cost-effective. This would be for construction under the 'portable building'; rule and thus building regs exempt. Critical factor is cost effectiveness. Application is for glamping accommodation, studio, garden room, etc. I'm playing around with performance and cost of different materials at the moment, and I'm a big fan of corrugated steel as a cladding material (cheap, easy, fast). I also really like the idea of doing away with the whole VCL/void/battens/PB thing and simply using a ply or OSB interior sheathing layer, sealed with appropriate paint for vapour resistance, and then with all wiring etc surface mounted. Now with no VCL I think there is a risk of vapour in the structure, even if I do my best to seal the interior. So I'm looking at the vapour permeability. The frame would be most likely 45x95 stick build, fully filled with glasswool. I think I then need some sort of exterior board to hold the wool in, prior to the breather, battens, and steel cladding going on. I know that I could just use OSB on the outside, but I'm very curious about the woodfibre boards that @ProDave used. A quick glance online shows that the thinner versions of these aren't silly prices. I don't need them for racking strength, as that's what the interior osb layer will do. Question is where is it best to spend the money: beef up the frame to 145mm and just use osb outside, vs keep the 95mm frame and use say 20mm woodfibre boards as EWI. Or, should I use a different material as EWI, e.g. PIR, PUR- my gut feeling is that this isn't vapour permeable enough. Another option would be to use Kingspan's insulated roof sheets as my exterior cladding, but how do you manage vapour permeability with this system?
I bet you can't wait to get out of the ground!
I've tried to persuade SWMBO on this. Two dishwashers, no cupboards. Take out what you want, use, put in the other. When full, swap over.
Well this version uses no electricity, so that has to be a good thing. Dose it with a capful of Milton once a year, well that works for boats anyhow.
OTOH, the smaller the house, the smaller the heating requirements in absolute terms. Sometimes I think we forget this.
Nice wee project. I take it you don't fancy collecting off the roof due to all the trees around you?
Very crisp, well done! Does your budget include the appliances?
If you think our politicians can control the wholesale price of energy, then you have a lot more faith in them than I do.
James Webb space telescope is finally launching next year. It's hugely ambitious, massively over budget, years behind schedule, and turned out to be a far more complex project than it first appeared. Something I'm sure many of us can relate to
Welcome aboard. Sounds like quite a project! I take it you'll be able to claim the VAT back, given the apparent condition of the building?
