Crofter
    11
Everything posted by Crofter
  1. I was told there was only one way to install a window, and that was to fix 50x50 all the way round the outside and then slide it into the frame so that these battens formed a cavity firestop. But that puts the windows in front of the insulation, and would lead to a thermally poor perimeter all around the edge. Just a case of "we've always done it this way" and not adapting to modern house designs where people actually care about thermal performance. As a minor aside, aesthetically I think windows look much better when set back a bit into the facade. Maybe it's just because that's the norm up here, but when they are flush with the outside surface of the wall it looks a bit cheap, to me. Anyway to get back onto the actual topic... I got my windows via @iSelfBuild directly from Poland, fortunately before the drop in value of Sterling. Very pleased with the quality although arranging delivery etc was not the easiest- but that might have been the case with any manufacturer, given my location. As others have said upthread, I was advised to go for inward opening windows as these were higher spec, but I had to trim back the budget a bit and ended up with outward opening, which I think I prefer for various practical reasons (no dripping windows inside the house, no worries with clearance when plastering or fitting blinds, and you can actually use the windowsills to put stuff on- important in a very small house like mine).
  2. Having done all mine one my own, I would agree!! Biggest was a 250kg sliding patio door, which I could only move with the aid of a bottlejack. I had some help getting them into the house but did the actual fitting myself. At this stage in the build I received regular visits from passing neighbours, many of whom are in the trade - every last one of them thought I was daft to install from inside the building. I thought it would be daft to try installing triple glazed windows from the outside, working much higher off the ground with no working platform... Mine spent a winter, uninsured, in a cow shed. I was pretty glad to finally get them on site.
  3. Just bumping this thread as I too am looking for LED strips. Mine will be going on the tops of the exposed beams, to light up the vaulted ceiling. I'm looking for something with fairly low light output, as this is just a touch of mood lighting- the main lighting will be spots on the undersides of the beams. Is it generally OK to buy cheap Chinese strips, and then a decent quality transformer, and if so how do you know that the transformer is OK?
  4. There are a few houses up here on Skye with Decra. From driving past, you can't tell the difference, IMO. But that's where the whole house is done with them, it might be much more obvious on an extension. I'm a fan of metal for roofing, having recently done my new build in corrugated.
  5. That's actually a good point- we have done such trips in the past and work a watch system. But I wonder how common it is for couples to do this?
  6. Go for ballast. You don't actually want to have sand and 20mm gravel with nothing inbetween. The ideal mix has a full range of sizes, and should all be crushed material, ideally, as that gives the strongest concrete.
  7. Errr, no, they are not included in the 2040 ban. https://www.autoblog.com/2017/07/26/uk-hybrid-internal-combustion-engine-ban/
  8. If you're worried about the 10%, buy a hybrid. Nobody's banning them.
  9. I doubt many people are scrapping cars for the same reasons that they discard personal electronics or clothing. It simply comes down to economics rather than fasion/greed/laziness. Last year I had to scrap my 11yr old Kia with 100k on it. I really, really wanted to keep it but the figures didn't add up. It was costing an average of over £500 a year in repairs/MOT work and a rusty subframe was an outright death sentence. Perhaps nine years in the Hebrides was to blame?
  10. You must have more stamina that I do! if I've just driven 200 miles, I'm going to need to stop for more than three minutes. Twenty would be a minimum, I would say.
  11. You could, of course, argue that a hole saw that is fractionally too shallow to do all the way through is actually perfect, because it forces you to finish the hole from the other side which will make a much neater job without breakout. Assuming, of course, that you can access both sides! And assuming that you care about the appearance of something that will be boxed away and never seen again...
  12. One of my concerns was that my towel rail was too close to the shower- but that picture puts my mind at ease
  13. I'm on the final stretch now with this little house. The last room to need significant decisions made is the en suite so I figured I would stick all my questions in the same place on this thread. The room is 1600x2400 and has a basin/wc unit (already in place, although the install is temporary for now). The shower will run along one full wall and have a fixed glass screen and full length tray. Flooring is just going to be vinyl, and I'm planning on a part tiled, part paint finish on the walls. An electric heated towel rail will fit on the wall beside the door- a tight space but I can get a 500mm wide one in, just. So.. first question. When looking at the tray and screen, is it best to get these as a package? If sourced separately, am I running the risk of incompatibility where the screen seals to the tray?
  14. Ther are some calculators available online that give a rough estimate of required stove size, but they have to make assumptions about how well insulated your house is so are very rough guesses, really. Stoves work best when they are running near flat out, so you want to size it for the expected heating requirement and not go for something too large. I've installed three different woodburners and none has been more than 5kw output; all have done a fantastic job of heating the rooms they were in. I installed a 5kw stove in a 18m2 living room and usually kept the double doors open to the equally large kitchen, as the heat was plenty for both rooms. This was in a house with pretty minimal insulation. In terms of make/model, there is a surprisingly large range of variation. Key thing is the efficiency. Each stove I have installed has been of a higher efficiency, and you can tell from the design that more thought has been put into it. So my first one was from Aarow, and was pretty basic: sliding air controls, airwash taken from the front. Next was a Charnwood, which uses rotary air control which gives a far better seal, and which draws airwash air from the back of the stove, heating it in two tubes hidden within the stove. The result is preheated air blasting down the glass and keeping it spotless. Newest one is anothe step up again, a Burley which at 89% claims to be the most efficient available. Double glazed window, fully lined/insulated firebox, all air fed from an external source via preheating chambers within the stove. And it works- I have never had a stove that burns so hot, keeps so clean, and leaves so little ash. In fact I have yet to take any ash of out it at all. The only downside of a high efficiency stove is that, because all of the heat is directed into the room, there isn't very much left to waste up the chimney. If your chimney struggles to draw, this can cause a problem.
  15. Population growth is only a taboo in as much as it is a massive economic driver. It is also not a given. As countries transition towards better living standards and healthcare, birthrates fall. In the West we now see populations begining to stagnate, and there is little reason to presume that this trend cannot continue to spread across the world. My own granny was one of ten children, perfectly normal two generations ago. Now anything over two kids is unusual. Don't make the mistake of saying that certain countries or cultures will never change. But back to cars. Grid connection can be the key here. Peak vehicle use is around rush hour, with the majority of vehicles sat parked up during the day. So long as they are parked somewhere that they can be charging up, then there is no problem with using them as a dump for PV output. But this has to be done on a national scale. Another factor which we haven't yet discussed is changes in working patterns. We ought to all work out of our (paperless) home offices by now, but it hasn't quite got there yet. That is the general direction, though, and automation might accelerate it, along with other changes at which we can only guess.
  16. There's also the concept of vehicles becoming integrated with the grid, as storage. Quite a complex one to get right, but compelling nonetheless.
  17. My guess is that ownership and useage habits will have a bigger impact than the way we power our vehicles. Driverless cars that are in near constant use, and simply rented out like a taxi when needed, make quite a compelling case. For the vast majority of the population it will make more sense to hail the nearest vehicle via your phone, and simply pay a relatively low fee per mile, than to actually own a car with all of its attendant costs and hassle. If ridesharing continues to grow, we might see buses gradually replaced by multi-seat driverless vehicles all taking a few people on a point to point journey. For people like me, out in the sticks, it makes far less sense. But people like me are too small a proportion of the population to really matter. Also someone is going to have to come up with a clever way of integrating child seats into cars, because people are not going to walk around carrying them.
  18. Where did you hear 2050? I heard that there was no date for taking existing ICE vehicles off the road. It would be nice to think that a solution can be found whereby the small numbers of classic/older vehicles, doing very small annual mileages, can be kept on the road. Perhaps a mileage based system?
  19. Do we allow ageism on this forum? The problem with generalisations- whether they are based on race, gender, age, income, whatever- is that they are wrong. Not just morally wrong, but factually wrong as well. No group of people is entirely homogenous, so as soon as you start using terms like "they are all lazy/greedy/etc" then you are onto a loser. Can we get this thread back on topic, please?
  20. Water carries much more energy than air can. This is why central heating uses pipes filled with water, not air. To heat a house using air, it really works best if the house has low heating requirements. However the big advantage is the easier and cheaper installation of a warm air system, compared to a full wet central heating system. In other countries, e.g. the US, warm air heating is very common. It's still quite unusual over here, probably because ot's only relatively recently that houses have become efficient enough to have sufficiently low heating requirements in our climate.
  21. That would be a real shame if you can't get a readymix or volumetric lorry on site- it's quicker, easier, cheaper, and the concrete may well end up higher quality. Or at least more consistent. I know that when I did my founds, I couldn't beat the price of the volumetric lorry by site batching. But to answer your actual question... 5:1 ought to be OK. A lot depends on the quality of the aggregate. Ideally you want nice sharp angular crushed material, from say 20mm down to fines. Poor quality ballast will instead have some fairly rounded pebbles in amongst sand, and not much in between. That will need a stronger mix to compensate. If you can't get a truck on site, how are you planning on getting the aggregate delivered?
  22. Hi and welcome MVHR is a ventilation system, and does not replace a heating system. There are essentially two ways to ventilate a house: the traditional 'accidental' way, using trickle vents and various random leaks around windows and within the fabric of the build, and the 'controlled' way, where you seal up the house as much as possible and then use a fan and ducting to blow fresh air into the house, and to extract stale air. It's fairly obvious that accidental ventilation leads to a lot of random variation. Some corners of the house are too drafty, others are stuffy. The amount of ventilation will depend entirely on wind speed and direction. If you choose to control the ventilation, you can have a constant supply of fresh air directed exactly where it's needed. And as a bonus, if you control ventilation using a MVHR system, there is a heat exchanger which recovers the warmth from the stale, moist air that you are getting rid of. A good system will recover 90% of this heat. Compare that to simply opening a trickle vent where you recover 0% of the heat. There is a running cost for the fan, but it is likely to be less than £50 a year. In a new build, it can actually be easier to aim for an airtight house and then use MVHR, rather than try to build a leaky but not too leaky house that gets by without. If it's too leaky, it fails building control altogether. A MVHR system should cost around 2% of your build budget, give or take. Yes it is an expense, but the rewards are better indoor air quality and lower heat loss. It also helps your SAP score, which means you can pass building regs more easily and might not need such expensive windows or insulation.
  23. I might need to put up some friends in the unfinished house (hope no Council Tax assesors catch me!) and the hot water system isn't bought yet, let alone installed. I'd like to have a working basin though. I'm planning on fitting a pillar mixer tap. If I plumb in the cold feed only, what will happen? Will water come out the unplumbed hot side??
  24. If it only lasts five years, then it isn't larch! Quality and prices vary hugely, depending on species, origin, grading (all heartwood?) and treatment (if any). If you really want to go for zero maintenance, would your planners allow you to use wood-effect cement fibre board? E.g. marley Cedral.
  25. Ouch. Really sorry to hear about this. You will soldier on. In a couple of years time that wall will become the talking point as you show your friends around the build "and this is one that blew down, let me tell you about that...".
