Everything posted by Crofter
Build cost regional variations.
Crofter replied to Dee J's topic in General Self Build & DIY Discussion
That's probably another aspect of regional variation- different flavours of "always done it this way". The few tradesmen I've dealt with have commented on how unusual my build is, and at times told me I was doing it wrong, because of features including: pier foundations; vapour barrier; airtightness requirement; windows fixed within, not on outside of, frame; MVHR; plaster finish; plasterboard finish; service void; engineered joists; full fill insulation; vaulted ceiling; 6" frame instead of 4"; use of tanking in shower; etc, etc. -
It's not a given that a self build will be worth more than it cost. Up here delivery can be a significant factor, and this may filter through to general costs. I noticed on another thread that I've been paying twice as much for battens as another poster. I sourced my roofing for two thirds of what I ended up paying, but couldn't actually realise the saving because the haulage wiped it out. -
You're getting a better deal than me! Every time I bought some, Jewsons would charge me 74p, I would phone up to complain, and they would apologise and knock it down to 44p.
Don't you just love the English language
There must be some purpose to it. Horrible stuff, when wet the blue dye comes off on your hands, and I found the quality of the timber was pretty poor and prone to splitting. You have to pre-drill if you are remotely near an end. Never used to have to do that with the plain uncoloured battens, but unfortunately my branch of Jewsons don't seem to stock that any more. I ended up with the blue stuff even though I specifically said it was for internal use only.
The problem with ripping your own battens is that a large enough knot can end up severely weakening the piece, where it would not have been a big enough proportion of the whole timber to have any detriment. But if it's just for the piggery, and if the wood is effectively free, and if you can be bothered with all the work, then yeah why not A table saw may be easier, and certainly more powerful, but you'd have to rig up suitable in and out feed supports. As to treatment, maybe have a browse of woodfinishesdirect which several people on here have used- quite good advice and easy to deal with.
Shower, tray, tiles, and all the rest...
Crofter replied to Crofter's topic in Bathrooms, Ensuites & Wetrooms
Oh well that's the first row and a half stuck on so guess I've made my choice (would have done more, but the baby woke up and I had to down tools). In the end it did come down to a bit of trial and error, seeing what starting point would avoid funny little bits of tile anywhere. With these wee tiles, with their bevel, and with the brick bond, there's precius little room for manoeuvre It must have been something I said to her. Oh hang on I forgot to buy her a bday present this year, that'll be it By the way it turns out that my sketchup model is way off- the window has actually worked out to be exactly, to the mm, centreline between the LH wall and the edge of the shower tray. So I'm going to end the tiles on that line, and it will look as though I planned it that way all along!- 118 replies
- 2
- shower enclosure
- shower tray
Your second idea sounds good, thanks. I'll mark it out and see what it looks like in the flesh. Presumably I still take the centreline as the middle of the full height tiled area.- 118 replies
- shower enclosure
- shower tray
Only another three inches, ish. I used a hole saw to cut some chipboard reinforcing pieces, and the same saw to cut holes adjacent to the line of the shower screen (on the 'dry' side), then slid the chipboard pieces in behind the PB so that the screen's screws have something to bite in to. Then I glued the cut out piece of PB back into the hole. It was a skim finish so I can probably make it good again quite easily.- 118 replies
- shower enclosure
- shower tray
Thanks for those thoughts @Ian - you could be on to something. Of course I have somewhat b*ggered up the wall next to the shower screen yesterday when I cut into it to slip in some reinforcing pieces for the screen to screw into- I can probably smooth it over but the plan was to tile over so I didn't spend much time making it good again. If I paint these areas I'll need to get the filler and sandpaper out, not a big deal really. Tiles are already bought so no savings there A half way option would be to join up the splashback and enclosure tiled areas, but on the upper area just take it to the screen, or a few mm beyond, rather than the edge of the window. This means I only have to make good two of the three holes I made in the wall...- 118 replies
- shower enclosure
- shower tray
Time to set out some tiles (and it's November... how did that happen!) SWMBO has chosen metro tiles, 100x200 with bevelled edges. Oh goody. I guess this means lots of cuts. I will be using trim to finish off in a couple of places and I think the only way to make this look OK is if I ensure that only cut edges meet the trim, so that the tiles are all the same depth. How would you set out the back wall? (see image) a) take the 'centre' to be the halfway point between the edge of the window and RH corner of the room b) take the centre to be the halfway point between the edge of the WC/basin unit, and the RH corner of the room* c) start in the RH corner and match the tiles on the adjacent wall, either to mirror them or to create a wraparound effect *this looks, in the picture, as though it lines up with the window, but it doesn't. Thoughts (looking at you, @Nickfromwales)...- 118 replies
- shower enclosure
- shower tray
Thanks both. I'll start with the back of the cupboard door just in case- I've only got two doors in the whole house so not a big job!
- 21 replies
- doors
- spraying doors
(and 2 more)
Has anybody had problems using Polyx over veneer? Wondering whether to take the chance since I've got enough left in the pot. I could test it out on the inside of a cupboard door, I suppose.
- 21 replies
- doors
- spraying doors
(and 2 more)
Wot he said!! Turns out I got pretty lucky with my Hep->comp connections. I initially had a wc cistern set up like this for use as a temporary site toilet. When I put the shower valve in, I 'borrowed' this connection, stuck a compression tee on it, and fed this to the two sides of the shower valve as a pressure test. The valve and its Hep2O fittings were fine, but the temporary tee was absolutely peeing everywhere. Slapped some self amalg on it just to allow me to do my test but it's been enough to convince me not to rely on compression fittings on Hep2O for any permanent connections.
The switch furthest on the right has a black surround, all the others have white.
And of course if you have sarking, you need a non tenting membrane and also counterbattens.
Knee pads that don't slip....
Crofter replied to ToughButterCup's topic in General Self Build & DIY Discussion
I just have work trousers with knee pad pockets in them, I think they are JCB branded ones. Have worked well through most of the build but I am now sporting ever larger yellow patches at my knees where the fabric has worn through. They always seem to be in the right place though, and I forget I'm wearing them as they are quite unobtrusive. When the trousers finally wear right through I'll just buy another pair the same. -
Breather membranes should be OK with full fill insulation- that's what I've done anyway. It's the old fashioned felts that need a 50mm gap, which also has to be vented top and bottom via soffit and tile/ridge vents. Have you got anybody locally to you who does blown-in cellulose insulation? It should offer very good real-world performance, better than PIR because it tightly fills all the space (plus improved 'decrement delay' but I'll let someone else explain that one!). I don't know how it compares on costs, but as it's a totally different material to PIR it may not have bene hit by the same price hikes.
Having had one of each, I would put Wickes several notches above B&Q in terms of quality.
Cool, I'm on the right track then. Have fitted a bent 15x1/2" Hepworth tap con on the outlet, and used straight 15x3/4" of the same on the inlets, because bent ones weren't available. Just had to use a couple of (Hepworth) elbows after. It'll all get pressure tested before it get boxed in... and the flexis are going in the bin
Here's the offending item: http://www.ebay.co.uk/itm/Modern-Concealed-Chrome-Round-Thermostatic-Shower-Mixer-Valve-Kit-SM615A/370901516038?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649 Chosen because of the idiot proof labelled controls and obviously it was a good price, with 10yr guarantee. I've fitted the tap cons onto it already, I used Hep connectors and have ditched the flexis. Whilst I'm more than happy to switch out fittings or even the whole valve if necessary, there's a time issue as it's currently holding up the rest of the bathroom.
Oh well the bits are bought now... I thought the shower needed tap connectors onto it... it's the right thread size anyway... Now that I've got them, is there any reason *not* to use them? The shower valve didn't come with any fittings- previous one I fitted did have elbows which I guess must be 'irons'. Likewise the outlet, which I had assumed was a 1/2" fitting and therefore needed a 1/2" tap con.
Hepworth don't appear to do a 3/4x22 bent connector either, so I'm just going to use a straight 3/4x15 and an elbow. Will take up slightly more room. Funny how when you flick through the BES catalogue it seems like every possible combination is available, and then when you actually need one it doesn't exist
Ok so it's not paranoid to avoid using them! Shame Hepworth don't appear to do a 3/4x15 bent connector as that would minimise the number of joints in the install. Looks like I'll just have to do the connection in copper and then switch to plastic.
Had a neighbour suffer damage due to a burst flexi. Has made me a little wary of them! And a bit of googling suggests that there is a definite failure rate. The application I have in mind is for my shower, so I really want 100% reliability before it gets boxed away and tiled over. The shower valve has 3/4" connections, and what would ideally do the job is a couple of bent connectors to meet the 15mm pipe- but such a combo seems rather rare (3/4 x 22mm is no problem). I just happen to have a couple of flexi connectors that I bought by mistake a while ago, which are 3/4 x 15mm, and also have built in isolators which would be handy. But they were very cheap! Has anybody actually had a flexi fail?
