Crofter
    11
Everything posted by Crofter
  1. Thanks- will standard solvent weld fit straight into the compression fitting of that trap, then?
  2. Oh and another little niggle. The combined WC/basin unit (I went for a cheapie from Soak.com, oak effect, and so far it seems fine for the price. Don't know how long the foil will stay on...) has a slight overhang on the basin, which is to be butted up against the wall. So I need to fill the gap that this creates- it's about 30mm I would say. How would you chaps go about this? I'm thinking I could just fire in a little bit of softwood painted to match the wall... or try sourcing a piece of foiled MDF to match the unit, which would look better, if it is a close enough match. Or even butcher the unit and steal a bit off the back, but I'd rather not go down that route.
  3. Urgh. After a couple of weeks away from the build, I've come back to this and the eBay seller had changed their listing so that instead of £99 delivery to Islands, it was now £49 delivery to Highland (mainland). Not a huge problem, I save a chunk of money but have to call in a favour from the inlaws. Go to click 'buy' and it says sorry we don't deliver to Highland. Sometimes you spend longer looking for someone who will deliver than you do just finding a supplier in the first place. But you get used to it... still frustrating though. Anyway, on a different topic... I need to connect the basin to the waste pipe, which is a 40mm solvent weld pipe. I have a vague memory of difficulties in compatibility between different waste pipe systems. I presume the easiest thing is to do it all in 32mm with an adapter where it meets the pipe coming up out of the floor. Should I do everything in solvent weld? Are the anti-glug traps worth having? I'm sure @Nickfromwales recommended one to me before but I can't find the thread.
  4. With a shed that size you will have lots of new best friends. And then you will find you need a bigger shed...
  5. I had high hopes for tar planings but was quoted £30/ton- all depends on location I guess.
  6. Looking at option two... if you put some winder steps in, could you shorten the staircase enough to avoid that little boxout in the room above?
  7. What about hiring one?
  8. Hat off to you Ian for taking the right decision. I can't imagine how tough that must have been to swallow. My approach was to do it myself, and then I have nobody else I can blame
  9. Be careful what you wish for. We've all seen George Clark, we've maybe seen some fantastic tiny house projects or retro caravan, gypsy caravan, yurt, etc, and thought 'how could anybody object to that?' So how do you draw up a planning policy that permits these developments but is not taken advantage of by someone who claims that their rusty shipping container, or broken down transit van, is their holiday home? Beauty is in the eye of the beholder, and one man's retro-chic is another's pile of junk.
  10. What about directly contacting one or some of the 'good guys' that has been on site? Assuming they might be flexible/available.
  11. Well that's that idea scuppered... I'll have to hide my pies somewhere else now
  12. Two things spring to mind- subsitute a cheaper wood, like Douglas Fir, and move away from an actual structural oak frame to a cheaper structure with the solid timber only used in key areas where it will be seen. A true solid oak frame is a terrible thermal bridge anyway.
  13. Yeah probably best to tank it, like the rest of the walls. No access at the back though. This is all a bit of a last minute kerfuffle. I wonder if I could engineer some sort of removable panel in the side of the boxout? That bit shouldn't see too much water.
  14. That will leave a 600mm gap to get in and out of the shower- slightly wider above the box-out. I guess that's OK but I'd better make sure I don't have any people of the, erm, larger persuasion.
  15. Keep up at the back! Having identified the standard try sizes, the room was built to 1600, and then PB'd and skimmed. Whatever idiot designed/built it cannot do basic arithmetic. So I'm going for a 1500 tray and a little box out which will make a shampoo shelf.
  16. Any last thoughts on screen size before I click the button? I think the two sensible options are 800 or 900. Tradeoff between splashing out into the room, and elbow room getting in and out. Bearing in mind this isn't (supposed to be) a wetroom...
  17. That's more my budget Turns out the magic phrase was "through the ceiling". These things are always obvious in hindsight, aren't they.
  18. On to the next question... Where can I find a riser rail that has the water feed running inside it, down from the ceiling? And are these difficult/expensive to find? I like the idea of one because it will be much easier to get access in the ceiling than in the wall- but not worth paying a big premium for. So far I've hardly found any for sale of this type, and they're all really expensive.
  19. Well SWMBO has approved the design change- 1500 tray, valve on the wall opposite the riser, and a wee shelf for shampoo (that probably swung it :D) I guess I could build the box out in PB, seeing as that's what all the walls are anyway, but it doesn't seem right for some reason. Is there any rational reason to do it in ply? Oh and I appear to have found a tray and screen- £200 plus half that again for postage, ouch. Still much cheaper than anywhere that I can pick up from in Inverness. http://www.ebay.co.uk/itm/Walk-In-Shower-Screen-Enclosure-and-Tray-Wet-Room-Cubicle-8mm-Easy-Clean-Glass-/282411062632?var=&epid=708886223&hash=item41c102d568:m:mzLESPAgPrt9ylmB_Y6_2KA
  20. What's the problem... he's probably got shares in Polyfilla.... By the way my iLumos lights arrived today. Does it matter which way I wire up the 240v side?
  21. That's quite a neat idea! The other thing I'm wondering about it whether it would be OK to position the mixer valve in that wall. If I put it where I've drawn it, I need to space out a whole wall. In an ideal world it's probably best where it is, but it would be nice to not have to space out *both* walls... EDIT- like this:
  22. OK next question... I had planned for the space to be 1600 exactly, which on hindsight was bloody daft because now that it's actually built, PB'd, and skimmed, it's more like 1590. And there's still tiles to add to that. Trays come in 1600 or 1500 and nothing inbetween. I could attempt to shoehorn a 1600 into the space, and certainly by cutting back the PB that should be possible, but it's not going to be easy. My main concern doing this would be that the extra thickness of tiles still to be added, and most suppliers don't tell you how wide the upstand around the edge of the tray is. Secondly, I don't really like the idea of the tray tucking in under the PB in case anything leaks. So the other option is to go for 1500, and then space out the wall a wee bit at the end to make up the gap. This is going to mean more work- another tiled surface and an exterior corner- but probably is the sensible option, yes?
  23. Yep having the flooring undershoot the lining is surely the way to go. Just since I've not fitted the linings yet there can't be any reason not to crack on with flooring...? Right where did I put those kneepads :0
  24. Hrm, walls are plastered and painted, but openings are still just roughed out. Kind of assumed that the point of the architrave was to cover this joint/gap between studs and lining. My thinking with doing the linings after the flooring was that I wouldn't need to worry about expansion gaps etc. Obviously you can't put beading inside a door frame, and anyway I want to avoid beading. Is it not easier to cut the bottom of the lining to the exact length, than to cut flooring to an awkward shape to fit exactly to the lining? I was planning on getting a chippie to do the linings and hang the doors, so I hope he's not going to do the whole shaky-head tut-tutting routine if I've done the flooring first
  25. Hopefully a last wee question before I start laying this... Obviously I'll leave fitting skirting boards until after the flooring is down. But what about door linings- before or after flooring?
