Everything posted by Crofter
Bring on the Hydro Power :-0
Crofter replied to Lesgrandepotato's topic in General Self Build & DIY Discussion
I'd like to do a micro hydro scheme linked to my DHW. The output I have is highly variable but there's a certain satisfaction in knowing some good can come of all this rain we've had recently... -
@JSHarris Have you had any black streaks from the galv nails? From my research I concluded that it was best to use stainless. I used a coil nailer and was lucky to source 70mm nails off eBay at a very good price- I actually had to pay more for the 45mm ones that I needed elsewhere. A friend of mine had an extension clad in larch using galv nails, and almost every one has left a little black mark about an inch long. Possibly where the zinc was chipped off the nail head by the firing pin.
Seems a bit of a shame to be using cherry, beech, and ash to plank the outside of a shed! Wouldn't these boards have more value to a carpenter, cabinet maker, etc? Ash in particular is a great wood for many things but durability outdoors is not its strength. Larch or Douglas would be much lower value and intrinsically more durable.
Shower, tray, tiles, and all the rest...
Crofter replied to Crofter's topic in Bathrooms, Ensuites & Wetrooms
Coo, glad I asked now- was thinking of a simple on/off as don't most people just turn it all the way up anyway? No harm I guess in allowing people to use less water if they want! If you've been fitting unbranded eBay valves without issue, then that's good enough for me. And they're cheap enough to have a spare on hand.- 118 replies
- shower enclosure
- shower tray
Thanks- that does make a heck of a lot of sense- alas the style decision dictates remote concealed valve. This seems the best price for a known brand:http://www.ebay.co.uk/itm/Bristan-Gummers-Sirrus-Concealed-Thermostatic-Mini-Mixer-Lever-Shower-Valve-/132187948442?epid=2255305956&hash=item1ec704059a:g:510AAOSwCQZZMA5A- 118 replies
- shower enclosure
- shower tray
Welcome to the forum! The planners aren't bothered about how you build something, only what it looks like and what it's used for. Would the change in build type affect the outward appearance in any way? Personally I would say that for a small project like that timber frame may well make a lot of sense, but then I'm a timber frame sort of guy. What's tempting you down the ICF+SIPs route?
Shower tray all bedded down and draining nicely. Need to get a mixer valve asap... Concealed single lever would be prefered. @Nickfromwales how would you rate Bristan? I know (Hans)Grohe are maybe the ones to go for but I'm a bit concerned that they seem to sell the valve and trim separately and knowing me I'd probably end up with a mismatch.- 118 replies
- shower enclosure
- shower tray
Haha yes good spot, I got confused because my other timber-themed road trip was to a Black Isle sawmill for massive Douglas Fir beams. I did all these trips with a trailer made out of an old caravan which cost less to buy than a day's hire of a flatbed.
Just FYI, I used 100x20mm larch. Cost 75p/m inc VAT direct from Novaar sawmill on the Black Isle- although that was about a year ago. What cladding profile are you going for?
Absolutely. It seems not everybody does. In our current house we've inherited some very poor plumbing done without inserts, with drips everywhere. Bunch of cowboys...
Cheap stove flue pipe supplier needed
Crofter replied to ProDave's topic in Stoves, Fires & Fireplaces
I paid just over £300 for my flue bits, from www.snhuk.co.uk (no connection etc etc) This was enough to do almost all of the installation. I had to add a second silicone flashing designed to tie in with the VCB/airtightness membrane, which this supplier didn't stock. Oh and as a correction to what I stated earlier, I actually didn't end up getting anything from eBay. Quality wise it seems fine- it's all Spanish made Convesa stuff. I later added a roof brace which I made from some stainless angle iron, this worked out at a fraction of the cost of a purpose-made kit, and considerably stronger too (deeper section steel, no telescopic sections with grub screws to work loose). -
Just picked up this thread, noticed Nick 'Hallowed be His name' the pie eater saying not to use compression fittings on plastic pipe. I've had my wc cistern plumbed in using this combination for a few months now, it's a temporary install at the moment but I had been planning on doing everything this way. I don't really trust push-fit for some reason, and the fittings are quite chunky. I'm also rather prone to changing my mind and like the idea of being able to reconfigure something easily. It's not too late to swap to push-fit. Although it is decidedly too late to do anything about the long Hep2o runs that are now thoroughly boarded away. Are compression fittings on plastic liable to fail at some point down the line?
Dektite rubber flashings are so cheap that it would be silly not to use one. I got my flue bits from eBay for the single wall, and a company called SNH for the twin wall. It was a bit of a logistical nightmare working out the cheapest suppliers as some had low prices on pipe, other on the various fittings, and it was a case of seeing what worked out cheapest overall- including postage costs. -
Yay, that's what I wanted to hear. The shower won't have anything teed off since there's no need, but if I can have a single cold to the kitchen that will save a lot of hassle.
Just got round to looking this up and it answers one of my major concerns: the open pipe from tundish to outside. Could see a lot of heat loss through that. Unless you're allowed to put a u-bend in it? Still haven't got hold of the plumber I'm hoping to use (it's good that he's busy, right?) and need to get a move on with things. Should I just pair everything up for h/c for each run and bring them back to the tank? What about the cold runs (wc etc)- can these tee off the cold feeds to the taps, or do they need to be dedicated runs?
The one and only crack that has appeared in my walls so far is also in the only place where I ended up aligning a board edge with an opening (it was a compromise forced on me by the spacings involved).
It should be possible for behaviour to adjust. If you absolutely must travel at peak time, you will pay for that privilege. If it's possible to delay the journey by an hour, you'll see an incentive to do so. Schools already stagger their hours to help spread congestion; plenty of other workplaces could do the same. It's a similar idea to the smart grid concept where people pay less if they are willing to wait until the wind is blowing or sun is shining. An additional factor is that a shift away from individually owned vehicles might see more people willing to share a vehicle with others- especially once driverless technology arrives. Putting five people in a car rather than one could have an enormous impact on congestion.
- 35 replies
- bbc
- bottom line
I think the standard kits are sized for block or brick walls, not timber frame. I've got two doors in a wall framed in 2x4 (with 12.5mm PB that works out to about 120mm) and one in a wall made with 3x2 (so that comes to about 95mm). Standard sizes seem to be 108mm, 125mm, 131mm, and larger. However I have a table saw and I'm not afraid to use it! Like you, I'm going with white MDF skirts/arcs, but solid pine for the linings, which will also end up white. Yes it would all look lovely in oak or oak veneer but it trebles the cost, and you can't just fill defects/nail heads/joints and paint over them.
Ah the wonders of online user reviews! Perusing the Wickes and B&Q websites to get a feel for door lining kits (I'm aiming for the basic pine which I will prime and paint white) and the reviews paint a picture of twisted, warped, knotty, badly sized timber. Is this a DIY-shed problem, or am I just as likely to encounter this at the BM? I'm not convinced on the solidity of MDF for door linings- I guess I'd need plenty of packers (I have a 45mm gap to play with inc the width of the linings themselves)- how well do the hinge screws bite into the MDF? I only actually need three of these- maybe I should just do a bit of cherry-picking?
Interesting that there doesn't seem to be a consensus on this. I'll be using some 18mm MDF somewhere else so will tot up the numbers and hopefully the offcuts from that sheet will do the job. Will only stand slightly proud of the 14mm skirting but sounds good enough to me.
- 7 replies
- skirting
- architrave
Until five minutes ago when I googled it, I didn't even know that the little rectangular blocks of wood sometimes placed at the intersection of architrave and skirting had a name- turns out these are 'plinth blocks' or, if decorated with some sort of detailing, 'rosettes'. I'm planning a fairly contemporary finish and going to use primed MDF which will be finished in a gloss white (to give a slight contrast to the matte white walls). I *think* I prefer the look of plinth blocks, but I know you can go ahead without them. I also wonder if using them makes fitting the arc/skirt a tiny bit easier?
- 7 replies
- skirting
- architrave
MVHR - Condensation Drain - 12mm
Crofter replied to Barney12's topic in Mechanical Ventilation with Heat Recovery (MVHR)
A couple of years ago when I was just starting the build, I bought an old caravan for £90, ripped the top off and used it as a trailer to transport my big timber beams and JJI joists, as well as all the cladding from the sawmill. The aluminium got turned into a roof for a log store, and the flexi plumbing is currently in the shed awaiting reuse... condensate drain seems appropiate. I would say I've got money's worth out of that caravan anyway... -
Is there any reason why it needs to be copper? Couldn't you use flexible PVC? -
Sounds thoroughly unpleasant, well done for facing up to it- it's a situation I hate to be in myself and have fortunately only had one slight argument with a contractor over the course of the build. That was a good idea to get the Gyproc guys on side as well since their opinion should carry a lot of weight.
