Air source heat pump or not?
Nickfromwales replied to Simon Brooke's topic in Air Source Heat Pumps (ASHP)
It's down to consumption at the end of the day. A TS for storing excess Pv, backed up with the ashp for 'dark' days would be a good solution, as then you could have your DHW from a coil in said TS. Solar thermal would be pointless and expensive IMO, as it wouldn't give you the high target temps you'd need for a combined heating / DHW TS, but MAY suffice if the TS is for DHW preheat only plus space heating. You'd then need an UVC for DHW, again fed from both the ashp and excess Pv. How many occupants / bathrooms / what's the occupancy etc ? -
Discount Offers of the Week
Nickfromwales replied to Ferdinand's topic in General Self Build & DIY Discussion
Meat and BBQ stuff is great. Pan au chocolate's are my weakness. Can't pick one up, got to be 2. Kids love munching the mini pizza jobbies, tres bien. -
Reducing The Potential for Error
Nickfromwales replied to ToughButterCup's topic in Project & Site Management
I thought joe would have been driving the van whilst Brendan was in the back with the chop saw going, cutting wedges as they went. Good to hear there's a reasonably pain free resolve . -
Hi Ryan. Welcome to the forum. Good comment and maybe you can post an introduction and give us some background .
In fairness to the window fitters, they've arrived at a built frame and have been asked ( ordained ) to fit the windows in correctly. I strongly doubt they'd have ever thought you'd stop work to 'jack' the corner of your entire new build up to alleviate the error. Attempting to fit the Windows level and square isn't their failing, the error should have been identified WELL before they arrived . Exactly the response a lot of us expected from MBC, so let's watch this space for the feedback. -
Jesus. That's not out a bit that's out a lot. Id buy the window guys some beer ASAP, sounds like they're getting stuck in. Fyi you can self level up to 50mm with certain products, but better to use lots of a cheaper 2-part latex to build up in layers as required. Fyi #2 you can also buy self leveller which is flexible so you'd be able to level the chipboard deck also, but does this problem not reside in every room now? . -
Get a laser, make a yardstick and you'll know in 10 mins who's dropped a bollock. Update this with more detail once you've attended site please. . -
Electric gates
Nickfromwales replied to Tennentslager's topic in Networks, AV, Security & Automation
C'mon @Onoff. You know you want to build it ( and that's your tiles paid for then ) -
Surprisingly adequate for a wash basin tap. More than adequate for a WC, and as the flow velocity is reduced it helps to quieten down the noise of the loo filling . I have both my basins off radial 10mm runs teed from a 15mm pipe coming out of my TMV and it's more than adequate. Any more and I'd not be able to flick the tap to the fully open position. 3m to first one and 6m to furthest away . As is I just flick the mixer tap fully open in the hot position and it comes out with good flow rates and the exact same comfortable temp every time without fannying around. Bingo bango. ?
If you take each white knuckle of each manifold to be say 25mm and it looks like a 8-10mm gap between them you can just multiply that by the number of outlets you need.
A bit tricky mate, as I'm in Swansea and that manifold lives in oxford
Time for an Update
Nickfromwales replied to ToughButterCup's topic in Insulated Concrete Formwork (ICF)
PM sent, but up to my eyeballs ! . Being popular is great ? -
I could dip my sweaty knackers in that right now. ?
When to start worrying ?
Nickfromwales replied to Triassic's topic in General Self Build & DIY Discussion
Tell him to make sure that only one ( additional ) signatory can book goods out, as in the builder. Set up a password for the account and tell the BM that invoices will only be paid for when a signed AND printed chit is presented. If the BM get sloppy with this pull them straight away. Also ensure that all descriptions and quantities are crystal clear eg no hand-written chits. Edit to add : If your happy with the builder then work with him, and if he invoices on a Thursday make sure he's paid on the Friday. I HATE it when I hold my hand out and there's no dollars, even worse explaining to a gang that their wages are "in a meeting, sorry", and that causes massive repercussions.- 25 replies
- liquidity
- project management
£108 delivered Finish the bathroom !
What to do with BT connection?
Nickfromwales replied to Weebles's topic in General Self Build & DIY Discussion
Once it's all connected and you pick the phone up for the first time, you'll hopefully have your dial tone back. Then dial 17070. That's the ring-back test facility . Select option 1 and hang up, then it'll immediately ring you back to confirm your line is properly ringing etc and then just hang up again as instructed -
Socket and switch holes in plaster work
Nickfromwales replied to Jimbouk's topic in Plastering & Rendering
+1 on the tone set. That was what I was going to suggest. Edit it to add : boarding first and going hunting afterwards = time consuming disaster. Just wait until your sparky says you have an open ring main and let the fun commence. No ta.- 25 replies
- swtich hole
- electric
(and 2 more)
On the other hand If I recall correctly
Leyland High Opacity brilliant white Matt for me every single day. Goes on to new plaster without the grief of watering down and messing around and covers like you'd never believe. 2 coats in the same day and you’d swear it has had 4. This is NOT a finish coat btw, but rather almost a filler primer paint which will need light sanding before applying a quality ( Johnston's etc ) colour / white finish coat. A product like 'Diamond Matt' from Dulux may suit you well for finish coat as its a scrubbable hard wearing top coat that can be cleaned rather than touched up
Time for an Update
How facking big is your kettle? Oh, and looking good ? -
Cheers. There's nothing not to like about those just as long as you can reduce the pipe size to 15mm? Some gravity fed systems may not like that as the flow would be reduced. How do you find yours, or have you not tried it yet lol ?
Assessing the quality of a laid tile floor
Nickfromwales replied to Fallingditch's topic in Floor Tiles & Tiling
I've seen some tiling that you have look at twice to work out just how they did it so bad. Getting someone to admit they did it poorly is the biggest hurdle, and if you get any money back it's a bonus. Most will shrug it off and walk away, then it's down to yours and their interpretation of what was expected / asked for and what's been delivered. Regardless of title or procedure it's not a simple process, and it's down to you keeping a calm, firm tone and simply to keep pursuing the individual with 100% conviction, stating over and over again that this issue will not go away and needs to be rectified. Materisls can often be assumed as write-offs, and as you'll not want the same jerk back you may never see a penny of remuneration unless you've been prudent enough not to pay them ( until satisfaction and completion ). Deffo a sticky situation but it's best, imo, to get things corrected, even if it's at some additional cost -
Hmmm. Food for thought ?
@Onoff Are the quick change tap thingys universal fitting? Never saw them until you showed them off. Any chance of a link ?
