wet room with liquid screed
Nickfromwales replied to vfrdave's topic in Bathrooms, Ensuites & Wetrooms
My work here is done. ? -
Plumbing heating design etc
Nickfromwales replied to bassanclan's topic in Boilers & Hot Water Tanks
Whatever you do, don't put the heat loss rad in the bathroom. Anyone who's unfortunate enough to come into contact with that will need hospital treatment. Id put that in the attic and dump the unwanted excess ( from burning solid fuel ) to atmosphere. -
The acc'r @ 350kg when loaded ( 50-60% water + vessel ) is a lump, agreed. Better off in the corner of the garage if there is one? Or, can you slice that corner of the study so the boiler room is bigger? Tbh, even with the 500l accumulator your borderline due to the number of hot AND cold outlets. Last job I did on this scale had a pair of 500l acc'rs ( so about 500l actual stored water combined ) which is what I'd recommend here if you wish to just use the dynamic of the cold mains, ie a passive install ( no pumps and break tanks ). To do preheated you'll need at least an additional 300l TS with 46kw coil to give any meaningful uplift, so agree with @PeterW, the boiler needs binning ( sell it off ) and upgrading, as you still couldn't match demand even with the preheat with only 28kw on tap. Upsizing considerably to say a 700 or 800l TS may 1) allow you to keep the boiler and 2) run at low enough temps to keep the boiler condensing ( very important for efficient running costs ) but you still have the issue of space heating and the property is too big to go DHW priority "w plan". For hot and cold water, this needs a whopper TBH. 3 decent simultaneous showers is a big remit, especially with white goods drawing water / toilets being flushed simultaneously too. Remember that at 2.5 bar you'll be VERY lucky to fill the acc'r half full. -
? Thats what the above mentioned accumulator is for me old China mug. . @bassanclan The major ( possible ) flaw here is the plate heat exchanger. Is it 15mm in and 15mm out for DHW? -
Yup. That is nuts. Not often no. Most issues are created by not flushing debris out of new pipework, mdpe burrs / flux / solder droplets etc which accumulate in the throat of the NRV and then get caught in the moving part when water passes through. That crud then holds the NRV open thus rendering it useless. Cleaning after commissioning is vital, about a month into normal use would suffice, and more so with any pressure reducing valves. With a large or complex install I would recommend a strainer but proper flushing and the one month clean out should suffice.
Hopefully the DIY attenuator will be enough then, or are you tempted to just buy the BPC / similar off the shelf one?
@Stones What level is the fan actually audible at? Are you saying dead of the night slight noise / other?
Get your missus to shout at you through it and see if that takes the edge off ? Theres a 'real world' test for you
Rust Removal Adventures: Electrolysis, Acid etc
Nickfromwales replied to Onoff's topic in Tools & Equipment
It would remove your head most likely. -
Enough jibber-jabber. Have the stillsons improved at all? -
If you have poor pressure / flow then I'd deffo go for a 28mm stopcock and likewise with the NRV. Cost is negligible so yes to that. Why do you need / want to reverse 2&3? My gut feeling is you may get the water board moaning in case the NRV failed and you couldn't stop the water loss. After that I doubt it makes any difference TBH, just unorthodox.
@Dee As per the vid barney bumped, you don't even need a spanner or a screwdriver to change every component. The syphon comes out like changing a light bulb, and usually the rubber seal just needs cleaning and / or reversing ( or replacing if it's truly knackered ) . It's all done up hand tight. To quote Dylan Thomas......... "These are the dogs bollocks, madam" ? You can go wall mounted for contemporary, or floor mounted for a more traditional look .
At least you make me look normal -
Are you fully weathertight? Doors / windows etc?
If the shower is the other side then just mount the shower valve immediately above the cistern top to avoid the conflict. ? All flush / concealed and with a bar mixer its a 5 minute job to remove and replace. No need for mobile boxing in etc .
Very poor results. That's exactly what i fitted on the attic one I did and it was beyond crap. After a dozen flushes the air settles and you have to ram the button to get a slight flush. If doing that ever again I'd use 6mm copper brake line and short pieces of the silicone hose supplied as final connections bonded with CT1 / similar. Over the 1.7m the silicone hose expands slightly when under pressure ( when pressing the flush button ) absorbing the energy and thus hardly moving the flush bellows which open the flush valve. Actually, if ever doing that again I'd probably use a 12/24 volt solenoid.
Have you not considered one of these framed WC's? All fits into a standard 4" stud wall and all the components can be changed in minutes. The flush plates click on / off and all the internal parts come out through that opening . Not the cheapest of solutions, but cheaper than going round the gardens with remote mounted cisterns. Fwiw, I've done a couple of high level / remote cisterns, and one where it went in the attic, and the only issue was the flush control tbh. The velocity of the water coming down the flush pipe was excessively noisy though and when it got to the pan it was doing about a 100mph so splashed beyond the pan slightly when it got there. Go for the sealed frame arrangement and dont forget they're available for floor mounting the pan as well as wall mounting depending on how brave your feeling.
And they said it couldnt be done Ive seen "roofers" who can't turn out work of that standard, looks great ? ??
@readiescards is in a similar 'boat' to you . Im not sure how far along he is with his 'offgriddyness' but he'll see the nudge and hopefully update accordingly .
- 34 replies
- electricity
- off-grid
(and 2 more)
You'll be back Until then....... Dont now.....I'll cry ? All the best, and keep your spirits and your chin up ! ? Nick.
Hot water system for the garden room
Nickfromwales replied to MikeSharp01's topic in General Plumbing
Good job your not in research and development Nick, or the SAPV would never have been invented Just finished my tea, made in record breaking time ha ha. ?- 31 replies
- inline water heater
- stiebel eltron
- (and 2 more)
If connecting to your existing boiler, is it a fully modulating one? If not, it's likely a small buffer would be needed tbh. +1 on more insulation, but if the tiles are smack on top of these boards then the floor will get hot enough, problem is that the medium to dissipate the heat is not great. Your pipes need to get hotter than normal, say in a screeded install, and you'll only have the tiles to absorb and convey the heat so may well prove to be uncomfortable if being used to heat an air leaky / high heat loss space. Retro fitting Ufh is not the best way, so if you choose this route be aware that you'll probably never turn it off in the heating seasons, just up and down ( comfort 21oC and economy aka setback at 16-17oC ) according to occupancy. That'll allow the house to stabilise and reduce response times. You can't increase the flow temp to speed up the warming times as you'll then get the overshoot that is mentioned above. Tbh that example is most likely just a poorly commissioned setup with way too high a flow temp so best not used as a benchmark. UFH works incredibly well, when fitted accordingly and commissioned properly.
