Nickfromwales
    346
  1. All depends if it's a system boiler . They have they're own pump inside already, so that would do TS & rads, and the UFH manifold would take care of the UFH circulation. I've never found it necessary to fit a pump between the TS and the pump on the UFH manifold as the manifold pump pulls through on its own. I think many installers who are doing these mixed installations fit one as a knee jerk but they're really not necessary.
  2. I've had my one repaired 3 times under warranty, and no quibbles. I hammer my tools so really happy that I have a working tool for 3 years. Beyond that it's a bonus, after all the tool is only £100 + vat .
  3. I think this may be best left as a respectful thread, rather than a place to settle opinions. This is beginning to lose its purpose chaps
  4. Shame it's hidden down there. Beautiful timber beams . Thanks for the update
  5. 180mm / 7" outlet centre is standard Id go for the 3 socket branch TBH. Link ?
  6. If you fit a Thermal store, it'll double up as a hot water tank ( via an integral instantaneous coil ) and also provide a means of buffering the heat delivery from the oil boiler. Plus, you can dump all your excess pv into it. ST is a one trick pony so unless you are at passive levels then I'd not even bother considering it. Pv is SO much more useful in comparison. Alternative is a small / medium buffer and an UVC. Cons with a TS is you need it hot 24/7 for the months that you require heating ( to get DHW ). Pros with a TS is you only need one tank. Edit to add : also less plumbing, controls and associated expenses with the TS too.
  7. When you find it, keep your fingers tucked in .
  8. If the 'excessive' presence only serves to stop any 'momentum' with any like minded individuals, then it will be welcome and possibly life saving. There is no right way to fight or deter these deluded, despicable people, but any visible measure is obviously better than none, but how do you combat terrorism? I'd not like to be tasked with that responsibility, nor to receive the blame and ridicule when it still proves ineffective. God speed to the organisations and individuals who do their utmost to keep us safe whilst we go about our business, and let's be grateful for the liberties we enjoy in this country as a result. My oldest daughter is 8, and I couldn't imagine waking up to that bed being empty. RIP.
  9. At least that will give you full and proper recourse against him in any adverse event. I'd say that's a result. To clarify, are you ok with him culverting the burn appropriately under / complying with the relevant guidelines?
  10. Prob best to mention the location
  11. You'll fit in just right
  12. You mean insulated ?
  13. Ok folks, let's continue the chat her please
  14. One tried and tested method here is to get a weathertight and certified 'airtight' structure from one source. That leaves you dry, secure and free to complete the internals by yourself, at your leisure whilst having an incredibly fast build time.
  15. Hi, and welcome aboard .
  16. In screed makes no sense. Cold water won't be cold . Don't forget to lag the cold feeds too to stave off any heat absorption .
  17. Where does it get the air intake from?
  18. What do the MI's for the drier say regarding it being boxed above ?
  19. It's not a vent . It's a redundant strap on boss which has had a cleaning eye ( aka rodding eye ) fitted into it to blank it off. Prob picked up a waste pipe in another life . Cut it out and get rid as its a liability. ?
  20. Let's find out with loads of tricky, sparky-related questions ! Hi and welcome to the forum. ?
  21. Top man. I forgot that a lot of the automatic air vents I fit come with those so you can change / service them without draining down the whole system. I'd recommend them on the aav's for this system too ? I think the drain off ( tap with yellow lever valve ) under the temp gauge is for draining / sampling the water, and the other is for filling / injecting new product ( glycol ) as I believe there will be a non return after the second drain off. Try blowing through it both ways ( with your hand over the spout that comes out at 45 degrees ).
