Vaillant ashp (my battle with).
Nickfromwales replied to zoothorn's topic in Air Source Heat Pumps (ASHP)
Why do you keep disrespecting people on here with this statement??????????????????????????????????????????????? Absolute and complete fecking garbage of a statement. Just untrue, non-factual, and is now wearing people down. Stop regurgitating this nonsense as it's utterly defeatist and backed up with zero facts; by your own admission here you've not once actually heated this house, so YOU DO NOT KNOW. End of. I LIVE IN THE EXACT SAME HOUSE AS YOU DO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! You don't own the only shit house in the UK OK!!!!! Get over it!!!!! Read that 500 times, then go away, read it another 500 times, and then LISTEN ffs. Before replying, read it all over again. And then one more time. If you can't listen, and you refuse to accept these facts (not fiction or conjecture) and continue to refuse to accept said FACTS, then you are simply beyond help (and believe me, we've been trying). 10oC is 5oC warmer than a fridge you can keep meat in. Having the house at this stupidly low temp at night is just ridiculous. Have a think if you actually came here for advice and help, or just for sympathy, as I am at the end of my tether with you ignoring what I have written, and all of what the multiples of others have written (in their spare time, for free, with only the very best of intentions). You are a horse we are trying to lead to water.............. -
Yes. They're called M&E consultants. These will take everything into account, and look at your heating demands holistically, including fabric and ventilation heat loss, heating emitter types, insulation and fabric standards, airtightness, oh...........and the other X factor........the good folk who actually have to live in it comfortably, afterwards .
To which you replied “go feck yourself”?
Damp condensation in built-in wardrobe
Nickfromwales replied to steveoelliott's topic in Heat Insulation
As long as none of the new boards touch the cold structure, or are in immediate contact with the cold corner of the ceiling, then you'll be fine. Boand and screw 12,5mm or 15mm Marmox to the ceiling first, over boarding the existing PB so the dust and shit up the attic stays up there, and you can skim directly over that when the boarding is all done and you're ready for a spread. Butt the new insulated PB to the Marmox, then you are warm / warm and will have zero issues. -
Moving inspection chamber. Any issues?
Nickfromwales replied to flanagaj's topic in Waste & Sewerage
Sorry to disagree, but you know I will..... They do not need an AAV when the drop is <1300mm, some BCO's have stated <1100mm, but tbh most inverts for GF WC's is way less than this. Some are pretty much down and then straight out horizontally, so in all above instances these get an air-break soon enough for no such vacuum to be created. Ironically, I have more trouble persuading architects who are long in the tooth, vs BCO's, that this is completely fine and functions perfectly correctly. The dreaded vacuum is mostly an issue when the pellet of water etc is dropping a full 1 storey (2.4m or more) and gets up to speed, spreading out and filling the pipe as it falls. Then you defo need an AAV, but that's for falls from 1st and 2nd floors etc, only. Even if the WC is discharging immediately downwards it's fine, but if you have even a slight turn to the left or right, giving a small section of horizontal pipe before it drops the <1300mm, then the issue is basically zero. The horizontal pipe creates an instant air break, and the (perceived, possible) problem instantly gets a cure. BCO's have argued, then come to terms, and then they finally agree; some have then asked to see the WC functioning, before sign-off, but concede when they see it working flawlessly. Most just give up at the 1st challenge, where I say "it doesn't need one mate". Saves horrible boxing-in in the corners of the rooms with the requisite access panel etc. -
An SVP is exactly what it says, Soil Vent Pipe, so needs to go to atmosphere; either through the roof, or on an external façade finishing up higher than any openings etc. STP's are not part of the network, so you have no obligation to vent the main sewer gasses, as per a network connection. You just need reliable and functional. Do you have somewhere to vent the STP in the landscape (can be just a short stub above ground if far enough away to not cause nuisance) or rising up behind a shed or outbuilding etc. Methane is lighter than air, so will follow that principal. Static gasses should be prevented from building up, so if there is an SVP then even a minimal convection airflow will carry this gas up and out to atmosphere, nothing to do with the path of least resistance as none of the branches going into the house will have throughput of airflow, as you say they will all be capped off with an AAV. If you want an SVP to function as a vent, then a suitable location needs to be decided. Ground floor WC's do not (typically) need an AAV or a vent etc. Ok over short distances, yes. -
Norrsken patio doors with slide under sill
Nickfromwales replied to Selfbuildsarah's topic in Windows & Glazing
Is it just the look of outside where it meets render etc or are you still working out depth of reveal > length of sills? Been on this for quite some time on both recent projects, both Norrsken, and yes it’s not something you can flick through in an afternoon. It’s what I do day to day tbh, got the empty boxes of headache tablets to show for it, plus all the other finite detailing that often gets left out (that stuff all too often ends up in the rear view mirror). So many things need this kind of micro-detailing, for a full house build, so lots of folk just dump this in my lap and say “can you sort this?” Joy. -
To add, I was suggesting Zoot left the hard wiring alone, and added a 3rd party programmable wireless room stat that he could take around with him, as he’s the sole occupant. -
Most yes, but what madness is it, if the nerve-centre is located indoors that the terminal to connect an indoor stat is in the unit that’s outside? Bonkers world of ASHP’s. I should have said all manufacturers I guess, so let’s add that contingent here. -
Las few we've done have been the full (solid) threshold, ordered with sufficient length for external finishes. I'm often gone when the slide on sills go on as people are sometimes rendering long after I've done all the M&E / helped with window and door install etc. Norrsken should have some stock images, or ones from finished projects that they could share perhaps. -
OK to cut excess window fixing straps to help airtightness taping?
Nickfromwales replied to Gaf's topic in Ventilation
I think you can stand down red alert fella, sounds like a great spec!!! My comments are relating to the OP. -
You can vent an STP in the landscape or at an outbuilding. Gasses would travel to the end of the run and up / out the SVP at the far end of the run. You're panicking too much about that . A better drawing showing where the pipes rise inside the house would help, stating exactly what is connected and if they rise to 1st floor or not. AAV's are not require on the ground floor unless the invert is at 1300mm or more btw, and a lot of BCO's are unfamiliar with that allowance. -
UFH - do I need floor probes?
Nickfromwales replied to Great_scot_selfbuild's topic in Underfloor Heating
I direct bury the ones for UTH in bathrooms, but as they're so cheap I just put A - (in use) and B - (spare) each time. I just prefer the nub on the end to be wrapped in tile adhesive or SLC for the most accurate reading possible. The last job where I was asked to do this, we just used offcuts of 16mm ufh pipe and made long sweeping bends. The probes then got taped to piano wire and pushed into the depths; if these fail, you just pulled out the piano wire, re-attach, and poke the wee beastie back in. -
Technically you're inside the insulated envelope here, but ill-fitting PIR and airflow at the window frame makes me default to getting any last whiff of cold and condensation risk dealt with once and for all. A sheet of 6mm or 10mm Marmox with regular PB bonded to it would lift the cost by a couple of £10's per reveal, so it's not a bank-buster. -
I’d do the ceiling too. -
Yes, I hacked off as the plaster and mortar was damp, plus they didn't want to lose an ounce of space. You defo do not want voids and layers, so do this meticulously or not at all. -
If I can walk about in my cream and brown Y-fronts in Jan then I really wouldn't give 2 hoots what the mean flow temp is. I'd be warm and happy, the neighbours not so much as apparently that's not a good look. It's not just the probes, it's what you need to connect them to, if you actually do want to geek-out, but the novelty will wear off PDQ. -
Tell me again about how leccy prices are goin to come down…
Nickfromwales replied to Alan Ambrose's topic in Housing Politics
It's an absolute shitfest tbf. -
Yes, I thought they may have had the good sense to put the stat link in the indoor unit.............ffs. Just googled it, and then man is right, another cable needs taking to the outdoor unit to allow a 3rd party stat to be connected. Vaillant, if you're reading this, WTF were you thinking not giving us that terminal inside the house, (you know, where people sometimes fit their room stats)? -
Expensive Rubi ones lol. The standard blade will zoom through ceramic and travertine etc, but porcelain comes in different grades and needs a blade to suit. Any good retailer / tile shop should be able to advise and have stock of different types of blades.
Boatloads. My Rubi DU 200 radial wet bench cutter makes this a LOT easier, but still a massive ballache.
You can bin off the tumbled edges and just use the centre 'meat' of the tile, adding a trim on the top to finish it. Curved 1/4 round trims would probably be more sympathetic to a tumbled tile / rustic look.
Aerobarrier air tightness product/process
Nickfromwales replied to thaldine's topic in Heat Insulation
@Jonny, take note!
