Don’t fill with water then, simples! Buy the pipes in the correct length coils from Wunda and they’ll come sealed and pre-pressurised to a good few bar. Cutting into it gets quite a notable rush of air and associated hissing noise. Either that or complete a regular installation with manifold rails and pressurise yourself / installer with air. A pressure gauge will show you that things haven’t gone tits-up during screeding
Only with an ASHP install.
You should be fine minus the AAV then Guessy-McGuess-Bob
Why the need for antifreeze? Are you winter prepping? Just dry test with air if you’re just needing to prove the pipes before install. If you’re just looking to treat the system at the point of commissioning then you just do that via the upper manifold vent / drain point with a 3/4” or 1/2” flexible hose and a funnel. Make sure the lower manifold air vent / drain are completely removed otherwise it’ll be ridiculously slow going.
As much use as a waterproof teabag. ?. Give me a measurement from the top of the muncher to the point the discharge pipe opens up at the PStn. Run there, gallop back ?
The research evidence on security alarms
Nickfromwales replied to Adsibob's topic in Networks, AV, Security & Automation
Problem is, they know where the key for the steering lock will be, on your car keys , so they get those by burglary anyhoo. Therefore only a deterrent to the opportunistic thief. Bollards are a good choice, as long as they’re not cheap bits of crap that they’ll know they can simply knock over with your car. Thieves can readily identify popular security products and gauge their resilience / robustness etc in the wink of an eye. Good ( well placed and very bright ) security lighting, and some basic disciplines re where keys are kept at night / choice of door locks / don’t have a letterbox in the house door etc are all little 5 and 10%’s of additional obstacles which may make the scrotes move on. -
Is there anything in the pipes atm?
Like it says, if you can run a 32 or 40mm pipe from the point of invert it’ll allow a natural air break. How much of a drop from the muncher to the connection to the SVP?
If, my young crapprentice, you allow a fall on the discharge pipe, and you get it wrong, you’ll set up a perfect siphon tube. That’s where the contents of the pipe then suck the turd-scoffing device empty with loads of gurgling and slurping noises ( think of a fat kid on the dregs of his McDonald’s milkshake and you get the idea )…….
You’d be better off running it uphill to the point of termination as otherwise you have to put an air admittance valve on the pumped discharge line to stop siphoning.
It was a choice of; 1) read that 2) order another bottle of Shipyard hic…..
I’ve had Rubi cutters all the way from 400mm to 900mm and then a Sigma 900mm. Gave my Rubi one away to a mate starting out and I’ll be staying with Sigma. Outstanding bit of kit and far less effort to get a good cut. Literally couldn’t spot the difference between factory and cut edges.
MBC Frame - Windows - When to order ?
Nickfromwales replied to bob the builder 2's topic in Windows & Glazing
On my current clients build there were some delays, so we've pushed ahead getting the windows in before the full weight loading can commence. I've strategized this by asking that the fixings for the heads of the windows be left so that we can tighten / loosen these fixings retrospectively after 30 or so days after final loads have been applied. That will be sufficient time for the TF to 'relax' and the weight above to transfer down onto the ground floor window heads ( if any does at all i'll be surprised tbh ) where we can then adjust accordingly. -
This isn't an issue surrounding up / down stairs loo's this is whether or not your house is fulfilling its individual obligations to vent the communal sewerage system ( street network ) to vent the built up methane aka 'sewer gasses' to atmosphere. Your house is not doing this, but, with a neighbour either side doing so, I would almost instantly discount you having / suffering from any issues related to the excessive build up of said gasses. The smell you are suffering is, IMO, being caused by damp in the room. The only way sewer gasses would be able to get into the room spaces would be if the traps on the WC / bath / basin etc were being sucked dry by vacuum when the WC was flushed. As the WC is downstairs, I am confident that this can be ruled out.
Any way of knowing if that’s a combined sewerage + storm water connection you have? Prob no SVP ( soil vent pipe ) but as you’ve no 1st floor WC then doubtful it will make any difference. Are you the end of line, or do you have houses both sides of you? If the letter, can you see SVP’s on their houses?
Can you show where this pipe terminates down low please?
Do you really expect a new gas boiler to be this noisy?
Boiler leaking water drops since January 2021
Nickfromwales replied to plumbingo's topic in Boilers & Hot Water Tanks
Sounds like a blocked condensate trap / discharge pipe etc. The "smoke" will be "plume", eg the steam created when excess levels of moisture meet the hottest parts of the heat exchanger. The condensate water is acidic, so is chewing through the steel case of the boiler as we type. Google the manufacturers installation guide and in there it will tell you how the service the condensate trap. DO NOT run the boiler with the trap off, as that being removed opens a clear path to the burner chamber and there is a possibility that products of combustion may escape. I'm not entertaining the covid jibber-jabber, but you need a plumber in ASAP to repair this, or one or two a little later to replace the rotten out boiler with a new one. Time to stop bathing with a thermos flask and get some degree of reality and a pragmatic solution to resolve this now. -
Costs of Retro Fit v Dig up and re-screed UFH
Nickfromwales replied to Digger1's topic in Underfloor Heating
If this is going to attract big bucks, why ask the question? Dig it out and get on with it !! Agree 100%. Also, you’ll need to provide an EPC when selling and if the floor insulation is dire that will still be reflected there and your marketing will suffer. UK public are far more aware of energy ratings and the longer cost subsequence of buying a pig smothered in lipstick, or as we call them “Persimmon Homes”. Do the job properly, as it sounds like you’re looking to get your money back anyways, just not as much out of the UFH job as you’d like. If it increases the kerb appeal, with no rads etc, which also lends itself to a much more flexible furniture plan, then dig it out, do it properly, and move onto the next job. Allow a week to excavate, barrow out, and prep properly for insulation and membranes. You’ll need 2 men on 2 powered barrows to keep up with removing the spoil created by one digger. Allow another week to install insulation, pipes, edge insulation and screed. Screed should be a one day event, so 4 days of prep / UFH. If you need a very good screeder that travels let me know. -
Up to or over 3M you need to upsize with UK Bregs, so 50mm is required AFAIK. I've avoided push-fit waste for over two decades, hate the stuff. Certainly not reliably enough to bury anywhere imo. Can you get someone you know here to box up stuff and post it to you?
Yup. Same supplier too. If you have a single phase electricity supply ( the most commonly found type ) and no 3-phase then you cannot install that unit I’m afraid.
Do retrofit ASHPs need larger pipes to the rads?
Nickfromwales replied to Ferdinand's topic in Air Source Heat Pumps (ASHP)
It wouldn’t matter if larger rads were fitted to the microbore if they were pumped from a smaller buffer or low loss header for hydraulic separation. Just about anything can be mitigated with a decent installer. -
Exterior grade filler for wooden eaves.
Nickfromwales replied to epsilonGreedy's topic in Building Materials
Russell is now re-homing woodpeckers. I can give you his postcode and he says don’t bother knocking the door, just release them at the gate and that’ll be fine. More the merrier he says. Bloody loves woodpeckers that guy.? -
Replace the boiler. Combi out > combi in should be change of £2k with new TRV’s + stat, magnetic filter and a gas pipe upgrade etc ( post-code allowing ). I’ve not yet seen MI’s ( in over 20 years of heating that allow a 15mm pipe to a combi as they’re so gas hungry in DHW mode. They used to say it’s ok to do a gas rate check at the appliance, ergo a short-ish run of 15mm before the appliance would be permissible. They binned that and now ask for 22mm to the appliance as other gas-burning appliances that share the same gas run may not be taken into consideration with the earlier prescribed methods. These days it is 22mm ( or larger depending on the length of the run vs boiler kW rating ), so you are guaranteed the gas delivery that is sufficient for the stated max hot water rates. The radiators you linked to are going to heat linear with demand so you won’t he able to completely strategise your off-peak heating during winter. Bad idea IMO. The instant water heater will be pathetic on a good day, and completely useless when any other tap is open anywhere. Seriously bad choice. Conversely I have recently fitted the 3-phase brother of that ( the 27 ) and it is staggeringly good for an instant. uses 32a per phase!!!! If you had 3-phase I would recommend one of these in a heartbeat. Amazing bit of kit. ?. Fit a new gas boiler, and if you want to show off get a WB unit which can be Hydrogen Ready.
