Nickfromwales
    330
  1. You're probably scoring too heavily. Try one clean pass, contact from start to end, and one sharp snap to complete. After that, you're on a wet bed cutter.
  2. That’ll just be the tip of the iceberg, sadly.
  3. All of the above. They all knew this would fail spectacularly in the event of a fire……
  4. Just get a continuous rim diamond blade in a 4” grinder and chip away for 10 mins. Easy enough.
  5. Are these the JA panels with micro inverters affixed? One less thing to buy ( other than the controller ) if so.
  6. It differs from DNO to DNO, for no good reason. Some will accept written notification, but the last one we did ( 5.5kWp on single phase ) they asked to witness in person regardless. Also, you automatically provoke this when installing more than the obligatory ~4kWp as you then have to submit a full DNO application before installing, listing the equipment ergo to ask for limitations you’d need the correct equipment in the proposal.
  7. If you have at least one bypass radiator ( towel rad or back of airing cupboard ) plus each radiator has its own TRV, I would say there is a definite benefit to having the rad circuit left open, without a zone valve, so the UFH gains some additional system volume which should help with short-cycling when only one or two UFH zones are calling for heat. The UFH deffo needs a zone valve so the manifold and TMV don't act as a bypass for the radiator circuit, eg when the rads are selected on their own the UFH ZV stays shut. With 2 lots of heating and with them both adding their own percentages of bypass, I would seriously consider W-plan ( DHW priority ), unless this is an ASHP install which would give you that anyway. If it is an ASHP then you 100% need a 3-port ZV ( diverter, not mid-position ) or 3x 2-port to facilitate isolation for the heating circuits during the higher temp DHW cycle. What is the heat source?
  8. Yes, by choosing one with Export Limitation software, but you still need to notify the DNO so they can come and witness this is operation / physical presence etc. OR, just fit DC batteries and then you do not need to inform the DNO, plus I see no reason why @MikeGrahamT21 cant add them to his FiT registered installation and mop up that eye-watering 75% export ?
  9. Turn off both internal stopcocks and see if the tap still works. If it does, then it’s a rising main vs cold feed, so should really be dug out to a healthy bit of pipe and capped off with some fines around it to keep it safe from movement. In terms of a dead leg, the risk is minuscule as the fresh incoming ( chlorinated ) water will always pass this on its way to consumption. Do the above test first and then weigh up the pros and cons.
  10. Have you checked the prices recently? They’ve gone up considerably. A similar size unvented cylinder will leave around £2k change in your back pocket.
  11. None of this helped by vertical ventilation voids feeding fresh air as fast as the fire could suck it in
  12. Is this an intermittent fault or a now permanent (albeit incorrect ) situation? Trying to narrow down a zone valve or stat issue. Doesn't sound like it's the ASHP at fault at a first glance.
  13. Which is exactly the right time to be asking a bucket-load of questions Welcome to a forum where such information, impartial, factual and honest, resides, ( warts 'n all ).
  14. The reference to adding more insulation was aimed at IWI ( internal wall insulation ) So basically applying say 30mm or more insulated plasterboards to the internal face of the dwelling, and then plastering over those. LINK EWI could also help but can be far more impactful.
  15. Pedantic ones will quote 1 in 5, but if you can visually demonstrate adjoining SVP's or that the you are not the end of line or at the crest of the sewerage network you should get an agreement that the SVP is not necessary. But; No, we cannot. An AAV allows air in ( hence the name "air admittance" valve ), so these categorically will not and do not provide any such means of venting per-se. AAv's are only a requisite where the invert from a discharging SVP to the 'manhole' aka IC is above 1300mm. Below that, there is not even a requirement for the AAV.
  16. Solid core cable needs particular 'kid gloves' when stripping and terminating, and I'd choose tri-rated in a heart-beat vs solid for rack / cabinet wiring. Also, why the obsession with twisted pairs? All of the rack cabinets I've made in my time have been populated with tri-rated or screened cables suited to their individual applications. Screens will provide RF / EMF control so what are you specifically looking to combat? If I have ever wanted to set out numerous looms to 'look pretty' and twisted pairs have been my choice, I've simply pulled 10m of the chosen 2x cores of stranded ( xmm2 ) cables and then tied the ends off and put the other ends into the chuck of my cordless drill, pulled them taut, and then slowly spun them into a twisted pair. If the connectors are vice clamps vs screw down rotary type, the need for boot-laces becomes one of personal preference vs necessity.
  17. Are other PIR manufacturers to be exempt from this question?
  18. Brink are PH certified, and not enough money to convince me that a compromise on something which potentially can save me annually on my heating costs would be such a good idea..... Longevity needs to be considered here also, in equal importance, as these units will be running 24/7/365. "Buy cheap, buy twice" eg not so cheap then after-all
  19. PH standards for all new builds? You'll be lucky to find insulation in half of the new stock being sold to first time buyers, fortified by over-stretched council / back-handed private BCO's signing off these builds in non-scrutinised batches of 10+ at a time from a single dwelling inspection. A heat pump would cut any heating bill in half ( minimum ) if a dwelling had any discernible level of attention to a fabric-first approach, with robust BCO monitoring. Whilst new buyers still rave over a nice shower cubicle and a cloakroom WC, the demand of the typical new build ( mass-produced ) buyer still doesn't drive such focus 'elsewhere' I'm afraid.
  20. Only if no one else in the dwelling opens a tap / flushes a loo, and no appliances are using cold mains at the same time Otherwise your huge electric shower will shut down and you;ll have to select its lowest setting and suffer a shower akin to me peeing faster-than. That rule applies to any and all electric instantaneous heaters, which are largely over marketing-hyped utterly useless bags of shit. I will concede that if new builds receive a mandatory 3ph electricity supply, the 3ph Steibel Eltron 27 electric instant is an absolutely fantastic bit of kit. I'm seriously impressed by it. Its 1ph little brother is however completely pitiful on a good day in the peak of summer, and a complete waste of money and wall space in the depths of winter where it needs to dig deep to uplift colder incoming water temps to the same level. You do have to consider the sanity of some folk writing here 14oC "right now" = 9pm on a November night. Less gin, more tonic, eh? Probably renting @SteamyTea's conservatory and banished from making physical contact with the room stat ?
  21. Architects can be dangerous things...... What they should say to you is to do the sums and get on top of the M&E coordination as early on as possible. It is such a holistic equation, made up from so many relative ( but often overlooked ) facets, that such a statement seems to be popular in buying these professionals all the insurance they need to survive without undertaking such ( or sometimes ANY ) due diligence. One 'eco friendly' chap had actually designed a heated floor to be sat on cold strip foundations without any thermal break...... Taking advice from anyone other than qualified M&E's, or testimonials from folk who have built, and then moved into, and are now living in such a dwelling is pretty dangerous practice and often costly. Another failed to specify a heat pump for a dwelling that had a mandatory requirement for NZEB certification as part of the PP! "Double the demand" is huge in PH terms. My 2 cents would be to stop taking advice from the architect as their approach is worryingly non-robust in this particular respect.
  22. They seem spot on for a temporary / relocatable ‘hit’ of a little additional heat. Thermostatic too with timer by the looks of it. ?.
  23. All the way to each outlet that you wish to have serviced by the HRC circuit . Not to every outlet afaic as I never really bother with baths / showers ( unless the shower is the far side of the building ) or any outlets in the immediate vicinity of the hot water device. Baths and showers typically get opened up immediately to 100% flow rate, so discharge the dead leg quick enough to not waste the heat / energy from running the HRC to such an infrequently used outlet. Bottom line…..just wait, as it’ll be 10 seconds or so max, typically, before premium temp DHW gets to that outlet so not life or death imho. Typically a basin with a 10mm feed, which runs for no longer than ~10m, will not attract the HRC. Reason being is that most HRC set-ups will have a recently used outlet or an HRC pump on for the daytime / periods of occupancy ( which will ‘pre-heat’ the larger bore pipework and the hot manifold, by design ) so the non-HRC outlets will therefore not have any discernible dead leg to shift, other than the tiny volume of cool / cold water in the 10mm delivery pipe. Works a charm.
  24. I've just installed and commissioned a full house system for a client, with UVC in upstairs plant room, and I fitted 10mm runs to the downstairs en-suite and cloak WC plus upstairs master are all 10mm hot and cold runs where the water pressure is 'not excellent', and the flow is more than adequate ( given modern basin taps are restricted / air blended for low flow rates anyhoo ). I ran a HRC to the utility and kitchen ( 15mm flow and 10mm return ) for instant premium hot water to both of those outlets. I don't ever do the above series HRC as it just doesn't rid you of every drop of the dead legs, the whole point of installing one in the first place! Also, if you do a manifold / radial setup then you need individual HRC returns back to a third manifold so you can isolate every hot outlet individually ( hot and HRC both need to be shut off to isolate a HRC serviced hot outlet ). Also series HRC means several outlets can be pulling down one run of pipe, so the flow rates will suffer quite a bit too, especially with Buteline as the fittings have a lot of resistance. My preferred installation methods see just one fitting at the end of each continuous pipe run so flow rates are very very good indeed, even more so when preserving what flow you have where the cold mains is not as good as you'd have liked. Any multi-occupant dwelling would deffo benefit from a 200-300L cold mains accumulator too, which are cheap enough these days, which will stave off pressure drops when things like WC's are flushed or an appliance is filling whilst someone is showering. Makes a huge difference.
