This is such a no brainer! @Kevan Marshall, move it over 400mm and save all this feckin about!!!! đ¤ˇââď¸ Iirc, the 1000mm rule would be the absolute dimensions, so remember to allow for overhangs / gutters and downpipes etc.
Mid sections of pipe runs not haunched? To prevent deflection. Foreign objects like a 1/3 of a patio slab or a house brick, visible when migrating the spoil and back-filling.
Have you haunched with a sand & cement mix, to set the pipes in situ? After that you should have 100mm of pea shingle under and 100mm over, and only pick out any obvious foreign objects.
Bedding pavers onto bifold cill
Nickfromwales replied to paro's topic in Landscaping, Decking & Patios
You canât bring them to the frame. Youâd normally put a slot ACO drain in and then lay up to that, so a linear slot drain deals with rainwater runoff from the doors. Youâd need to add an ACO (if you aren't on very permeable ground) and that sits at the end of the sill. Then pavers get laid to that. -
Fermacell vs backer board in bathroom
Nickfromwales replied to divorcingjack's topic in Wall Tiles & Tiling
Apply a good few coats of primer / water solution on to it a few days before tiling, to âsizeâ the surface and reduce itâs porosity. Mix up some 75% water 25% primer and give it a good few lashings, a couple of hours apart, and youâll soon see the board becoming saturated. Apply some neat a day or two before tiling, and then tile on to freshly applied wet, neat primer. -
Backer board or plasterboard
Nickfromwales replied to Super_Paulie's topic in Bathrooms, Ensuites & Wetrooms
Indeed. Donât ever change! If we couldn't bicker over these things the forum would be a whole lot duller . -
foul waste Foul drainage. Remove inspection chamber?
Nickfromwales replied to flanagaj's topic in Waste & Sewerage
Principles, not labour, squire. -
This is best, if you don't want to lose GIA with insulated stud walls. Dab the boards on and apply the dab to the boards. Poke a hole through the centre of each dab before applying to the wall, as markers, and when the dab is dry you drill back through and mechanically fix with corrosion-resistant fixings and washers. Foam at the footer, header, and sides. Leave a 3-5mm gap between the boards to inject foam in the gaps as dab must NOT be allowed to come through these gaps. That would bridge both cold and moisture, in the worst case. -
This is pretty crap advice? I've done a LOT of insurance work over the 30+ years of me doing 'this kinda thing' and tanking would have saved so many homes from very significant, long term erosive water damage; all caused by leaking tiles / grout / sealant / shifted baths and shower trays etc etc. Tank the FECK out of it and you'll never look back. -
Cavity closure timber frame
Nickfromwales replied to Selfbuildsarah's topic in New House & Self Build Design
Blurry junk, sorry! Can you post a link or 'improve upon this meagre offering'? lol. -
There's too much variation in 'interpretations' from various BCO's, as the last one made me put rodding access internally to tick his boxes. The IC is simply rotated so you use the lower invert throughput, angle on the input and same on the output, and defo not come in on an angle from one of the higher branches. Then, then IC is simply a straight piece of pipe. Zero blockages, zero issue, done it enough times to know it works perfectly well. Agree than another downstream IC within a couple of metres max will be plenty good enough for clearing blockages, but a blockage isn't going to happen if the job's done well (robustly) by a conscientious installer. -
Should builder correct bottle gulley mistake?
Fitted a good few of them. Nice bits of kit. -
Based on what? That will work perfectly well, will not block, and is the normal way to do this. If you adjust as above then the BCO will demand that you provide a rodding access point to service the change in direction. Not a good idea at all, and itâs the side of the house so who cares about the extra IC? Stop micromanaging, and stop worrying, leave as is and get the house built! -
Phone Charger under Kitchen Worktop ?
Nickfromwales replied to Spinny's topic in Kitchen Units & Worktops
Get an off cut of the quartz, 30mm thick, do a test run to see if it only charges at 1/4 snails pace, if so then bin the idea. If it charges around (at least) 50% normal rate then go for it. If you think it'll be handy, just do it. đ¤ˇââď¸đ -
As youâve drawn it seems fine, but unless this is a 200mm raft because load bearing intermediate walls are landing on it, then go for more insulation and a thinner slab? I assume youâve omitted DPM/DPC for simplicity? Lose the cork, and replace with 30mm PIR insulation. Cork is hygroscopic and friable.
Changes to planning once house is built!
Nickfromwales replied to squealeyhealey's topic in Planning Permission
Tell the to go GF. As above, tell them youâve built as per the permission APPROVED by them. Planning officers are just insane. Neighbour is a tosser. -
Ok, lol. Which way around does that need to go and Iâll edit it for you Go for it, Iâm a big fan of basements, and I think this would be a good candidate for an EPS based ICF. Many birds, one stone. Any plans you can share yet, for comment?
If IR, think again. They're horrible, crude things.
Howdens are buying DIY Kitchens
Nickfromwales replied to saveasteading's topic in Kitchen Units & Worktops
Theyâll bean-count the shit out of itâŚ.. -
likewise. Back to helping the OP we goâŚâŚ. @Babybirddog, get some pics so we can see if the inside is as shart as the outside. And also some of the flue; check if this is loose or has been cemented in properly.
Last job I was called to, was by an electrician friend who sub-contracted to British Gas. He asked if I could go to a job he was being called out to (old to new combi conversion) as he took one look and walked off as BG had specified using whatever original infrastructure that could he reused to save time and money. BG plumbers, and not subbed out (rare occurrence as once youâve been wooâd by the sales folk youâre lucky if you ever see BG again, other than on a bill or standing orderâŚ..). Anyways, these âplumbersâ had hacked into the wiring centre and got the system running, but had requested that an electrician attend site to âtidy it upâ. I arrived, introduced myself to the 82 and 83 year old, one deaf and one with bad cataracts, and my jaw hit the floor when I saw the aftermath. Bear in mind that at this stage BG were paid up front, and had left, job declared as âcompleteâ and these pensioners had been left for multiples of days without a working heating or hot water system, that they just accepted as part of the upheaval. IIRC the bill was over ÂŁ5k for removing a Baxi 551 and screwing some bits of cement board over the opening, and they installed a Glowworm heat only boiler on the outside wall, on show in the dining room. Fecking horrific looking install. I ventured into the depths of the airing cupboard (ground floor flat btw) and located the wiring centre. It had loose wires sticking out of the poorly squeezed on lid, screw half done up. I got my tester out and found that there were live wires projecting from the side and top. I shit you not. I told the couple I had serious concerns, and asked for the sales pack. I asked the lady of the house to ring the sales support number and to speak to them to authorise myself to act on their behalf. She did. Whilst on hold (forever) I walked to rest of the job. I found the blowoff turned back on itself and in complete contact with the render of the wall, as in nearly fully sealed; there must be open gaps here so the water cannot form ice build up and block the PRV. Terrible. Also, the condensate had been drilled through the wall in 21.5mm pipe, and this had simply had a bend added (both of these immediately out of the rear if the boiler jig, at chest height) and it was just dripping onto the concrete pathway between them and the neighbour who shared the access. Set in place to slowly erode the pathway and house foundation over time. No flush had been done, 30 year old system! Guys were on site less than a day. I got given the phone to speak to some jumped up Scottish BG woman who was asking me who I was, to which I replied âyour worst enemy, loveâ. I said they had an hour to get a BG van pulling up outside or I was going to the local press and the GSR, and told her that countdown started when the lady was put on hold; that gave them 40 mins to attend. BG employee got proper shitty with me, continued to demand to know who I was, and what business of mine was it of mine to be involved in their job etc etc. I just kept saying ânow you've now got 38 minutes and counting, love, I hope youâre typing and talking as youâre about to go public for endangering the lives of two pensioners, and may also get BG struck off by the GSRâ. Eventually she said the best they could do was call out in 2-3 days and she promised everything would be sorted out without fail. I said âyou now have 35 minutes, keep chatting shit for as long as you like. BTW, Iâm parked close to this house and Iâve cancelled my next job to sit here and see this through. Your move, loveâ. 2 vans arrived about 30 mins after she hung up on me lol. Wankers. I left my phone number with the couple and told them to call me if they didnât have heating and hot water that day. Did I say wankers? Once more, for completeness, British Gas are pensioner robbing, unscrupulous, useless, underperforming, over-charging, responsibility-dodging, wankers.
Youâre better off with it going into the downpipe, but it needs to be done better. Refuse to settle until the fitting is a white one, theres a rubber bung reducer to accept the round pipe into the square fitting, and its set back to the wall and clipped; minimum of 2 clips here. A soakaway needs lime chippings in it to neutralise the condensate, and these will need changing periodically. If not, that can eat into the foundations, worst case. Do you want to post some pics of the boiler install here? Just in case the faux pas extends to the boiler and pipework. If theres now a combi, is the shower mixer a thermostatic valve vs a manual mixer valve? Gas Safe is another cartel run by muppets, so I doubt theyâll show much interest in an install which they will decide is not âimmediately dangerousâ. Show some more pics before paying is my advice.
They couldn't give 2 (expletive deleted)s mate.
British Gas are just shite on toast, and their forte is ripping off pensioners. Be lucky if she got a Worcester, more likely they've gone bottom shelf and fitted a glow-worm. The above is exactly what I would have drawn if someone asked me to sketch a typical BG condensate arrangement. Just shocking. I went to one pensioner that had become another victim, and as they hadnât brought a ladder, above 2m around the side of the house, the copper gas pipe just wasnât clipped, literally flapping in the wind. They put a combi in and left the old boy with a manual mixer shower, so he was getting scalding hot water from it; you canât leave anyone infirm with a non-thermostatic shower fed from and instantaneous hot water heater. List of this goes on and on, from what Iâve seen over the years from BG. Great adverts, even better sales-people, then the most dogshit plumbing youâve ever seen.
