Temp
Everything posted by Temp
Building a Block Workshop - ADVICE NEEDED!
Temp replied to stunotch's topic in General Self Build & DIY Discussion
If I was building it myself I'd go for solid blocks so I can use a jig like this then fit internal wall insulation. https://youtu.be/-mciVlgZz5g -
Think you install the liner and register plate at the bottom then fill the space around it with Vermiculite... https://youtu.be/Kk6Et89GOCg Are you saying the chimney has been removed in the loft so the bare liner would be exposed?
Good ideas and products from other countries?
Temp replied to Alan Ambrose's topic in General Self Build & DIY Discussion
If you fancy a weekend away I suggest the Batibouw Trade show in Brussels 14-19 March 23. We went in 2005 and there were 13 halls in different categories. The Belgians take house plans so they can get quotes or place orders. Caution: Some days are normally trade only so check the website. Take comfortable shoes because if you want to see the whole show its quite a bit of walking. -
RCD work by comparing the Live and Neutral currents. If there is a difference they trip because that implies a "leak" somewhere. Eg Where did the electricity go if it didn't return via the neutral? You could use a similar idea to detect central heating leaks. If the boiler flow and return aren't the same there must be a leak. A common problem occurs when two circuits have their neutrals connected together so the current from the live of one RCD can return to the neutral of another. Sometimes the problem only shows up when a high current load is switched on or off.
I should add that although we found our builder by driving around he still had to out bid the others that quoted. When you get quotes don't rush to accept the cheapest. Its important to check they have all quoted for the same thing. One may have allowed less for the kitchen or nothing for your driveway and fencing. It took quite a while and many questions to make the quotes we had comparable. If you plan to provide a lot of second fix items make sure they include for fitting if you expect them to do that. Some people prefer to hire their own trades for that. You could ask builders if they use a tame Quantity Surveyor to do detailed quotes or just the back of an envelope.
Plus 2. We found our builder by driving around looking for building sites with nice houses. When I told them I was going to need a builder they all hapilly showed me around. Nothing like an unannounced inspection for getting a good idea what they are like. One or two sites were horror stories. Look for attention to details like air tightness, neat plumbing or evidence they are protecting wood flooring or stair cases. Try and ask a few questions. Had a few tell me "You dont need to worry about that we take care of it". Others took time to explain or show me how they were doing it on the house they were working on.
Motion/PIR sensor with additional contacts?
Temp replied to Crowbar hero's topic in Networks, AV, Security & Automation
I was thinking you could run three core & earth to each PIR. So you have power to the PIR and switched live coming back to a box in the house. Then run switched live to the light(s) from there. Put the relay or onto isolators in another box in the house. I 3D printed a box for the Arduino with a wall for isolation but it could do with improving. -
Building Regs requirement for height of balustrade fixed to parapet
Temp replied to LnP's topic in Building Regulations
I'd be wary about fixing to the coping. I'd be concerned about the coping coming unstuck off the top of the wall. Better fix into the wall itself if possible. -
Never seen that type before but I'd try looking in the hole in that last photo to see if there is a screw or Allen key screw in there that releases the cover or even the whole door. Take care, I'd want help to support the door before undoing anything and put packing under the door to take the weight.
I used one of these to interface mains to an Arduino. It's used to detect when my boiler pump is running. https://www.ebay.co.uk/itm/-1-Channel-Bit-AC-220V-Optocoupler-Isolation-Module-Board-Adaptive-For-PLC-/154400482521?pageci=204718bc-c2f2-4557-a2dd-49ea4e2a55af&redirect=mobile -
I think I would ask the planners for a copy of your 1978 planning grant and check PDR we're definitly removed. Probably we're if they say so but still check. I would also consider making a planning application for the same thing as your prior approval/permitted development application. It might be they only revoked it because you don't have PDR not because of other planning reasons. In addition speak to a planning consultant/lawyer about them revoking your permission as I don't think they can do that if the original approval was granted in error. See my post above. It might be the way to proceed would be to file an application for a Certificate of Lawfulness based on the revoked planning approval and citing that they cannot revoke it on the basis of an error. But this is definitly one for an expert to advise on before you do anything.
Is it causing a problem? I think my trap is even shallower. If the stack is open vented, and nothing else connects into the pipe between the bath and the stack then I think it will probably be fine. I think digging the floor out for the trap is OK as well. You could raise the bath on a plinth but that doesn't always look great.
+1 It's easy to find people on the Internet complaining about extractor fans on neighbours wall pointing in their direction. Avoid if at all possible. I don't think there is anything in the building regs regarding the location of extractor fans (but there is a 600mm seperation for boiler flues in Part J). The only thing I can think of is that regular cooking smells might be considered a statutory nuisance.
I think I would ask a planning consultant about this. https://www.no5.com/media/publications/what-do-you-do-when-youve-been-granted-planning-permission-by-administrative-error/
Grundfos UPS2 speed selector not working
Temp replied to DannyG's topic in Central Heating (Radiators)
Common problem is sludge settling out in the summer and blocking pipes. If the new pump doesn't fix things try turning off all rads that get hot so water is forced through the cold ones. Each time a new rad gets hot shut it off. Repeat until they have all been hot at least once then you can reopen them. Once it's all been stirred up I'd drain and flush the system a few times. When happy it's all working put the right amount of Fernox F1 in the system. -
I guess they have no other access route so offering to buy out the easement isn't an option.
Which appliances for kitchen
Temp replied to Coffeepotclaire's topic in Kitchen & Household Appliances
We're Bosch fans, mostly because it's easy to get parts and fix them myself. Our Bosch washer is 18 years old. Dishwasher and fridge/freezer about 16 years. -
Not that far. We only dropped our Grant down to the minimum recommend in the manual. The manual says this actually improves efficiency slightly. It's been fine for 15 years. Our Grant heats a thermal store and we still got cycling on the standard jet. Reducing the jet size wasn't enough to eliminate short cycling. I ended up fitting a bigger water pump so that with the boiler dial set on maximum the flow temperature never gets hot enough to shut the burner off. The burner now runs until the thermal store is satisfied. This probably wont work if you don't have a thermal store/buffer. What will probably happen is the return will get hotter and that will cause the flow temperature to increase causing cycling again. It might also drop out of condensing mode. Do you have a lot of small UFH zones? You could try configuring them so you have one stat controlling multiple or all zones. Less control but might help reduce cycling a bit.
@Tamdray PM sent.
Plumbing: logical? Naaaahhhh. So how the Hell do you ....
Temp replied to ToughButterCup's topic in General Plumbing
Tag, you're it.. @pocster -
You probably don't have time but.. What foundations does it have? One option might be to ask the BCO if he would accept a surveyors report (possibly from the supplier) saying the foundations are adequate for the construction, and that there is some sort of damp proofing built in and U-values meet building regulations etc.
That makes sense. It's meant to be the front door but Building Control have some flexibility to allow it to be another door (back door or patio etc)
Does it coincide with the heating going on or off? Heating pipes can make quite a bang as they expand and contract.
