Temp
    43
Everything posted by Temp
  1. Spread it out.. Planning Permission might be required to raise ground levels.
  2. I think that will work. I would put a waxed bolt in the inserts to ensure the epoxy doesn't get into the threads before setting up. The 24h stuff is stronger than 5min. Main issue I see is... By the time you need to replace one the oak will have changed colour so the new one may not match.
  3. My 5x6m outbuilding is on approx 150mm hardcore and 150mm concrete, no rebar. Timber frame with clay tiled roof.
  4. With some mixers you can just take the cartridge out and put it back in a different position without redoing plumbing. This might be useful if only one mixer not all are wrong.
  5. No they would need to be on each mixer. Im not sure this is the problem but I've heard that when the valves are missing water can sometimes flow down a hot (or cold) pipe, through a mixer that is OFF and back up the other pipe the wrong way. From there it goes to another a mixer that is ON. So the one that is ON effectively has two hot feeds or two cold feeds. Perhaps try allowing all mixers to cool down fully then turn one on full hot. While that's running hot go to the other mixers and feel them to see if they are heating up. Don't turn them on just feel the mixer to see if its getting obviously hotter when it's been off for ages.
  6. Can you elaborate on what you mean by "still coming from the same side"? If the same pipe into to the mixer is hot then either they wernt swapped over or something else is going on. Do the mixers need non-return valves on them? Check the instructions. I think most that need non-return valves are supplied with them fitted but best check.
  7. Should be a simple job if the door is a reasonable match for the opening. Not all doors can be cut down without them coming apart. It can also look a bit odd if the frame isn't same width all the way around. Remember you probably need a level entry threshold to meet building regs.
  8. Not just above lintels. Anywhere where the exterior leaf becomes an inner leaf.
  9. If you have achieved the ridge height they want without a dormer I would just formally submit the application and fight at appeal if necessary. I recommend including images of what the house will look like with examples of other similar house in the area done in the same media, for example Pen and watercolor. Using the same media helps make your design blend in better. An artist might charge a few hundred for this or you might be able to use SketchUp. I think that can turn line drawings into pen and ink style using styles.
  10. Probably should be a cavity tray an weep vents just above where the roof joins the wall.
  11. Does the pipe have to go straight through the wall? Sometimes a dog leg just makes life easier. Flexible connectors have/had a bit of a bad reputation.
  12. Red heat shrink sleeving about £1.40 🙂 https://www.ebay.co.uk/itm/Heat-Shrink-Tube-Sleeve-Various-Colours-Lengths-Sizes-From-1-2mm-25-4mm/141462328876?var=440611385286&hash=item20efcfd62c:g:YHwAAOSwDXZZ5MCz&amdata=enc:AQAIAAAA8FXx0b7C+xu/WWF8RioQWKLAFrz5bWaIc2Gg85PJLBgEbVhYF5iiNcS0ptQx3IEsqzA+8XiFVM3WXHwrO4xcMizpYaTC/bgwPiR22GjUg5uy+RFq/h4s7Jvrn/r8EA7CKCU1pOpLy1yhtvmXwXmN2rdIIcHhZvmbueCyAf+AFZbjTi6o945fJZ2BCM965w9DgQgdnpqzI0Ja4pnNv6AkDSVwdq6ps6svaphI3xgOY79lfLbX0WU4ulX9nsL4XuwjiicQrihD/Dj3k118PcRJFvX/6449TAHy5GNP+OkKk9bDe7HPlRCJI3yjw3B9bHdCGQ==|tkp:Bk9SR9rzhc_MYg&pageci=3aa1ed6a-65fc-468f-874a-50bf6f722568&redirect=mobile
  13. You can probably get red Plastidip but a new valve might be cheaper :-) Winter is coming, build an insulated cover for it?
  14. We started building in 2005. Went for oil fired UFH. Decided to install a 300 L thermal store to give good flow rate for showers and try and reduce boiler cycling (Oil boilers don't modulate the flame down to suit demand, they cycle the flame on and off instead). This took some fettling to get it to work right, possibly because my boiler is a bit too big. These days I would fit a lot more insulation and aim for ASHP. If you really want oil I would probably fit two tanks instead of a thermal store. One tank used for DHW and one as a buffer for the UFH. That would be the easiest to switch to ASHP later. Our thermal store has too many pumps and mixers on it that leak a lot of heat into the room it's in. Fortunately that's not a problem other than one of cost - but I'm glad it's not in the master bedroom cupboard.
  15. Na 5 years later its still good as new. Possibly because its a mild metallic red so has a clear coat.
  16. See also.. https://community.hmrc.gov.uk/customerforums/vat/1bac8eed-995b-ed11-97b2-00155d9c9a65
  17. Pretty sure you cant reclaim anything before planning permission is granted. Their thinking is that before then it can't be associated with the new dwelling.. Google found.. https://www.mytipsandadvice.co.uk/2018-05/how-does-planning-permission-affect-zero-rating-UKTAVAAR_EU08070401
  18. Many builders run fatter cables on the assumption that someone might want to replace their oven with an oven and hob in the future.
  19. When we bought our red SMax the sales rep tried to upsell me a ceramic coating saying "red cars fade more than other colours". I didn't believe him.
  20. I had half a dozen fail when a flourescent strip light was turned on in another room. Good job I was there to turn off the wall switch as several were smoking.
  21. Currently stuck in house of Lords...
  22. 110 drainage pipe starts around £5/m so thats £1500 to £2000. If your pea gravel was 0.25m * 0.25m * 400m thats 25m^3. Density is about 1900kg/m^3 so 25*1.9 = 48 tons at £45/t = £2000 Digger and driver for a week or is that optimistic?
  23. Bear in mind that some service engineers won't work in lofts. Think it's mostly the ones where you pay a monthly fee and they come do an annual service. I suggested to a relative that they ask the engineer to put fernox in the system and they refused saying they weren't allowed to go up into the loft to tip it into the header tank.
  24. I have two second hand angle grinders of unknown make and hate them both. Watch out tor.... ON/Off switches that are near impossible to work or latch on when wearing gloves. Spring loaded locks you need to press to stop the disc rotating when undoing the nut. Nightmare trying to hold the grinder, hold the lock and work the spanner. This type of no tool quick release nut is great and fit most makes..
  25. My understanding is that when all TRV are shut I believe the increase in pressure causes a bypass to open. This routes hot flow back to the boiler return. The flow temperature rises until the flow stat in the boiler shuts off. The boiler will eventually cool and light up again.
