Temp
    43
Everything posted by Temp
  1. PS Most door liners already have joints cut at the head so these would need to be modified to move the sides in a bit.
  2. Most door liners are at least 22mm thick. For example Wickes are 27.5mm. I think you need to find 22mm liners then allow at least 5mm for packing to make the opening square and 2mm clearance around the door. So at least (22+5+2)*2= 58mm for the lining and clearances. So the door would need to be cut to 882-58=824mm wide. Your doors are 838mm wide so you would need to be able to trim about 838-824=14mm total or 7mm off both edges of the door. The amount you are allowed to cut off varies from make to mak and depends on the construction of the door. Some say only 5mm, others 12mm or more. I think I would check how much you are allowed to cut off the door each side. If it's enough make up a temporary liner from some 22mm timber and brace it up well so it's definitly square. Then try fitting it in all the openings. See how hard or easy it is before buying all the liners. It's 3:30 am so check my figures!
  3. I think if there is water nearby I'd go for the mist sprinklers. Think they can use plastic pipe so perhaps not too hard to pull through the ceiling? https://mistek.co.uk
  4. If its being valued for sale those are normally based on what the market will pay rather than the build cost. Some agents use a nominal figure per sqm to estimate market value. This is a lot more common in EU countries.
  5. Was the loft being used as a habitable room like a bedroom or just storage space when you bought it? If it was as bedroom then house didn't comply when you got it. Ideally he would have spotted the problem but he hasn't made compliance worse. If it was sold as a storage space or similar and was converted to a bedroom as part of the renovation he should have made you aware of the issue and addressed it as part of the project. If its still only storage space you could try arguing with the BCO that it's not a habitable room so the escape route doesn't need enhancing, but if it's all neatly plasterboarded and decorated they won't agree. Overall if he has any liability I don't think it would be for the full cost, just extra cost of doing the work now rather than earlier. I can't remember if sprinklers are an alternative officially mentioned in the regs, or if this is something the BCO is allowing as a concession. If its the latter you need to keep the BCO on your side.
  6. My builder told me to choose handles that have their own return spring and not rely on the spring in the latch to lift the handle. I guess he'd seen the problem before. Google found.. https://www.morehandles.co.uk/blog/door-handle-not-springing-back-how-to-guide-from-more-handles/
  7. I can't actually see where the problem is in the photos.
  8. Yes that's a fairly well know gotcha. It's what I was referring to above. A loft conversions makes the house three storey and the rules on escape routes from fire are different. Typically there has to be a 30min protected escape route from the loft to an outside door on the ground floor. In most houses it just means ensuring that all doors and walls that seperate the living room and kitchen from the stairs and hallway should be 30min fire rated. In a open plan house there might be no doors or walls so no barrier between a fire in the kitchen and the escape route from the loft to the front door. Even a wall of glass blocks or doors with a lot of glass in can cause an issue. Was it already open plan or was that something the designer introduced?
  9. Deleted as it doesn't help.
  10. Can someone fix the spelling in the title for me.
  11. Sorry if already posted.. https://www.current-news.co.uk/mcs-express-concern-as-octopus-drops-accreditation-requirement-from-smart-export-guarantee/ https://gtec.co.uk/clause-5-8-octopus-opens-up-the-solar-pv-market-with-a-paragraph/
  12. Did BT demand the Modem back? I'm not familiar with the BT Modem but it might be possible to set it up for use with NowTV.
  13. I would hope they have insurance.. https://designfor-me.com/project-types/self-build/does-my-architect-need-to-have-insurance/ But it does depends on exactly what they were tasked with doing. For example the drawings for a loft conversion might meet Buildings Regulations but the project as a whole will only meet Building Regs if the design of the fire escape route, including the ground floor layout and doors also comply.
  14. When you say you have design and drawing experience does that include structural engineering of roofs? eg Are you familiar with the different methods used to stop a roof pushing the walls out and the ridge sagging?
  15. So I believe you want Section 10 on Page 61 "Section 10: New elements in existing dwellings, including extensions". More specifically paragraphs 10.7 to 10.11. Subsequent paragraphs give alternative ways to comply if you have issues with the above. Table 4.2.. I'm not 100% sure how to interpret section 10.7 d(i) in your case. It looks like there will be three windows serving three rooms in the dormer. I would work out the percentage for each room individually. They must each be <25%. If not you have to do the more complicated calculations in the other parts of section 10. Paragraph 4.13 might also be helpful if you get stuck.
  16. Yes but there was a whole rafter there before the opening for the velux was cut 🙂
  17. Temp
    MDF painting error
    Some people report drying issues with F&B. Scroll down here to the comments.. https://fromevijawithlove.com/2018/04/23/things-you-need-to-know-before-painting-with-farrow-ball/
  18. Temp
    MDF painting error
    I suspect it might just be taking a long time to dry. High humidity? Was it stirred properly? I'd give it 24-48 hours before deciding its not drying. Perhaps paint up some scrap wood with a primer (Zinsser products are good) and then the F&B. See how that turns out. If you have issues with the F&B I've had success with Rust-oleum over Zinsser on mdf. You can get small samples on Amazon. https://www.amazon.co.uk/gp/product/B0BJ2Q1V6K/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 https://www.amazon.co.uk/gp/product/B09NW4ZG4K/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
  19. When you cut out the rafters save the offcuts. Cut them down to form a small "rafter" that fits between the trimmer and the velux frame and supports the tile batten. It may need to be tapered in depth. Get it right and it can also support the plasterboard in the splay.
  20. Before you start building walls work out how big the roof overhang or any gutters as that may dictate how big the gap is. If its a flat cold roof construction think about how the void will be ventilated. Sometimes one orientation for the rafters is better than the other for this because it moves where the vents will be.
  21. Temp
    LED LLMF....?
    Im not a lighting engineer but my guide/sanity check for kitchens goes like this... lighting experts look away now :-)... Google recommends about 500 lux for a food preparation area. 500 Lux = 500 Lumens/sqm. Our kitchen is about 4x3.5 = 14sqm so my rule of thumb says we needed 14*500= 7,000 Lumens in total. We fitted 15 led rated at abut 400-450 Lumens each. That works out at about 6500 lumens. We're happy with the result but its just a simple grid of LED down lights. I choose wide beam angle bulbs to eliminate shadows and "spotty" lighting but at the expense of a bit of glare. LED Lighting tapes/strips typically quote "Lumens per meter" in the specification so you can get a rough idea how many meters of linear lighting you would need in that central rectangle. Experts will tell you this is all wrong and that beam angles, ceiling heights and the emissivity of walls matter.. but if your lighting designer says you need a very different figure for the total Lumens you can at least ask him to explain how he arrived at his figure. If he can justify it then he's probably right. You might find a company that will do you a lighting design "free" if you buy their lights?
  22. Temp
    LED LLMF....?
    Wish my dad was still alive. He was lighting engineer/manager at BBC and could probably make a fortune designing lighting for houses. He did some garden lighting in the 1980s tor people but was getting offered projects on £ multi million houses and was meant to be retired.
  23. Google says you can get green oak beams upto 12m but I'm not sure what size you would need. You may also need wind braces. "Instant Oak Beam Online Quotes - up to 12.5 metre sawn to size" UK Timber Ltd https://www.uk-timber.co.uk https://www.uk-timber.co.uk/custom-cut-fresh-sawn-oak-beams
  24. Is it a SIP roof? If so I don't think it needs any ventilation and no void to ventilate. If not a SIP is it being done under permitted development (roof less than 2.5m) or under planning permission which might allow a bit more - possibly enough for a warm roof construction. If all else fails build this version.. Run rafters front to back and put vents behind front fasia and a small rear overhang. Only needs about 25mm slot for vents.
