Temp
Everything posted by Temp
This one claims 370mm wide without wrap over lid.. https://www.simplybathrooms.co.uk/product/resolve-maxi-seat-d-shape-slim-soft-close-in-white/
This one claims 375mm wide.. https://www.bellabathrooms.co.uk/cassellie-d-shaped-quick-release-heavy-duty-seat.html
This one says "Toilet Seat Size: 46 cm x 36 cm, Holes Adjustment Range: 60 mm - 170 mm"... ...but also gives the same numbers for the "product size". i guess you could ask them which is right. https://www.amazon.co.uk/gp/aw/d/B01MD1O1CY/ref=psdcmw_1938753031_t1_B07S82QZVC
Combimate doses the water with Polyphosphate. There are several similar devices that also use Polyphosphate so shop around for cheapest and cheapest refills. They get a mention in Southern Waters note on water softeners.. https://www.southernwater.co.uk/Media/Default/PDFs/2835b_WaterSofteners_A4Notes_Nov12.pdf Apparently Polyphosphate makes the Calcium "less available to form deposits". Worth a read.
Status of Structure or Building after Splitting Title
Temp replied to Pemu's topic in Planning Permission
I think that link makes it very clear it would be residential duty. -
https://www.amazon.co.uk/WOLTU-Duroplastic-Toilet-Release-Adjustable/dp/B07S82QZVC No wap but lid still slightly bigger than seat. Measure yours.
Found a "long" D seat which I guess might hide the pan at the front... https://www.amazon.co.uk/Projection-Elongated-One-Release-Seat/dp/B0074K32R2 Possible D without wrap.. https://www.amazon.co.uk/Landlord-Direct-Supplies-Release-Fittings/dp/B07212F1L2
As far as I can tell there is no standard size for loo seats. Even the width between hinge points seems to vary. We have a similar D shape back to the wall pan and when I replaced the seat last time I fitted a regular oval shape wood seat and lid. Doesn't look to bad.
I can certainly see the lighter area. Are you sure it was caused by sanding as that shouldn't be needed on a laminate worktop. Was it done by an installer working for a kitchen co or did you hire him? If it was the former I would ask the kitchen co to come take a look.
I didn't think anyone made small CHP systems but this company popped up in an advert on another forum.. https://helec.co.uk/product-category/6kwe-16kwe-gasfirechp/ They have a 20kW heat and 7.5kW electrical unit. Only problem is it costs just under £30,000 !
On planning conditions having to be enforceable…
Temp replied to Dreadnaught's topic in Planning Permission
+1 I don't think the condition is enforcible as worded. -
Google found this.. https://rbwm.moderngov.co.uk/Data/Cabinet/20100225/Agenda/meetings_100225_cab_trees_appxA.pdf -
When was the speed reduced to 20mph? Was that after they had declared there were no highway issues on that other application? Eg What was the speed limit at the time there were no highway issues? I think this is starting to look like a new highway officer is just a bit fussy. If true I think when you submit the application you should point out there were no highway problems identified on the recent/previous application (reference no) when the speed limit was ??? and since then it has been reduced to 20mph.
Presumably they don't do any assembly of the kit on site themselves? If they did their labour and the kit should be zero rated.
Electric Boilers: Reliable and cost effective?
Temp replied to Raks's topic in Boilers & Hot Water Tanks
Might be worth a look at grants. Mainly for people on benefits but perhaps your tenant might qualify... https://www.government-grants.co.uk/free-insulation If the walls are solid some councils have (had?) grants for "hard to insulate" properties, might be worth seeing if they have any money left. -
I think it could be close. You will have other costs I forgot to include such as council tax. If it's uninhabitable you may not have to pay that. If you rent it for storage watch out for business rates (Some investors in storage containers/pods have been hit for that). You also pay income tax on the rental income. Is there any possibility you might want to retain part of the existing building?... 1) A knock down and rebuild qualifies for 0% VAT. 2) Retaining part might make the rest liable for VAT at either 20% or 5%.. a) Renting it out and retaining part for the new build would make the new build liable for 20% VAT. b) Leaving it empty for two years and retaining part for the new build would make the new build liable for 5% VAT (as it qualifies as an empty building). -
Standard (eg daytime) electricity is roughly four times the cost of mains gas. Scroll down this page to the table.. https://nottenergy.com/resources/energy-cost-comparison/ So an electric ASHP (heat pump) with a COP of 4 gets you back to the same ball park price as mains gas. Ok so maybe possible to get a better electricity deal than assumed by the Nottingham web site but you get the general idea. -
+1 In addition to planning permission I suspect there will be a lot of other issues just to make it habitable and legal for renting out.. New water, gas and electric supplies and meters needed. Electric circuits need separating from existing house and connecting to new meter and Consumer Unit. Heating system ? New boiler required? New sewer connection (existing WC uses sewer connection of existing house) Possibly other things to meet building regs such as... Exterior doors (fire regs). Sound proofing of wall between new and existing house. EPC (needed for renting) -
LED Circuits: Dim, Dimmer, Dimmest: or just dumb?
Temp replied to ToughButterCup's topic in Lighting
I thought trailing edge dimmers were better for LEDs? -
Garage conversion and raising roof - Permitted Development?
Temp replied to Gooman's topic in Garage & Cellar Conversions
I believe the roof light over 150mm issue would mean planning permission is required. However... Would the converted garage and roof light meet the rules for a side extension? Eg It would it be less than 4m high (3m within 2m of the boundary)? If so then you could demolish the garage and rebuild it as a side extension under permitted development. I'm not suggesting you do that but it means it would be hard for the planners to refuse permission for what you actually do want to do. If you just went ahead without planning permission I think they would be unlikely to initiate enforcement action unless there was a complaint buy a neighbour. If a neighbour was to complain the planners might feel obliged to initiate enforcement action but you could at that point submit a retrospective planning application. My guess is it would be waived through because they know you could build what you want by knocking down the garage and rebuilding it under the rules for a side extension. One option would be to apply for a CLD to knock the garage down and rebuild it within the permitted development rules for a side extension. They would not be able to refuse this. Then instead of knocking it all down just do the conversation you want. The end result would match the drawings submitted with the CLD. -
I think they are (over) concerned the ply wouldn't be well fixed to the joists due to firings in between. Perhaps could be solved by tapering the joists or raising one end of the joist (firings on the underside to level the plasterboard?).
I can't really see a problem with long pipes between heat exchanger and outside. It might be possible to get condensation in the outflow pipe hence the need for a fall. Our grill is in the eaves so getting a fall wasn't a problem. Never seen any water come out, nor from the eat exchanger drain tube.
Search eBay for mortice lock spindle and buy a longer one. Cut to length so it can't dissapear into the window.
Roof window on an upstand to avoid cutting roof trusses
Temp replied to IanMc's topic in Skylights & Roof Windows
Normally you support and then cut out a section of one rafter. Then fit doublers around the opening. Not sure if can do this with trusses. Might need input from an SE.
