Temp
Everything posted by Temp
That blue painters masking tape isn't very strong :-)
entry phone/doorbell down a 200yrd track
Temp replied to Tom's topic in Networks, AV, Security & Automation
Duct normally comes with a thin string that is used to pull a thicker draw rope through. Toolstation/screwfix sell suitable polypropylene rope. -
Here is one that uses a 3g SIM. Will still need power but can work from 12v battery. https://www.ultrasecuredirect.com/wireless-intercoms/gsm-intercom/kp6-3g-gsm-intercom-006-1990-p1872.html?gclid=Cj0KCQiAyJOBBhDCARIsAJG2h5eNr66OOB_PjPjr06NSG0aHq52ChIlPgK46SRjJeTI91rWzK59-T1MaAk3TEALw_wcB -
Google "4g doorbell" without quotes. There are some but how good they are i don't know. https://www.aliexpress.com/item/4000094976724.html?spm=a2g0o.search0302.0.0.17e7376ehiLWdW&algo_pvid=a5146855-dbee-4444-a051-51732769d23a&algo_expid=a5146855-dbee-4444-a051-51732769d23a-2&btsid=0b0a187916130640592934493eb938&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_ Edit: That one mentioned 4g but it appears to be wifi or wire only! -
It sounds like the same applies to exports. Numerous companies are looking at moving jobs abroad so they can do B2B exports to themselves and then B2C within the EU. Even the government is advising companies to do this... https://www.thelondoneconomic.com/news/relocate-to-eu-to-dodge-brexit-bureaucracy-officials-tell-firms/24/01/
Lamp post?
How many objections did you receive?
Temp replied to miike's topic in General Self Build & DIY Discussion
It can go either way... it a fine line between a "contrasting high quality contemporary design" and something "totally out of keeping with other houses in the area". -
No. I would interpret your planning drawings as showing the garage sitting at/on the current ground level of the garden with the ridge 4.08m above that level. You could apply to raise the roof height but the dimensions you have appear reasonably standard and in proportion. You could also apply to raise the whole garage and driveway to avoid a sloping driveway. However that wont be simple or cheap to build. Not sure why you are worrying about kids getting on the roof as the plans show a 2m high fence which can be on your boundary - which presumably is at road level?
Heights are normally "as specified on the drawing". Height limits for permitted development on sloping ground are normally from the highest point immediately adjacent to the building. That would be the level of your garden as you dont mention having to dig into the raised ground to make a level space for it. Its not clear why you needed planning permission for the garage but I suspect an even lower height limit of 2.4m might apply if you used permitted development rights to build rather than your planning permission. eg if its within 2m of the boundary there is a 2.4m height limit. If more than 2m it can be higher.
Raise the steel on a taller padstone?
Supporting stone above opening (parapet)
Temp replied to SuperPav's topic in General Construction Issues
I wouldn't taper the insulation from 200 to 100. That's an average of 150. I'd go at least 250 to 150 for a 200 average. If the roof is a single pitch perhaps you could also consider sloping the roof front to back to allow you to get rid of the hidden gutter without affecting the appearance (eg Use a conventional gutter around the back)? Edit: What fall does the roof need? A 1:40 fall over 7m is 175mm. -
If you know the courses, is that your occupation?
Southampton. Although he's been at home since Christmas.
It all sounds fine to me, or rather nothing you have mentioned definitly needs planning permission. There is a guide here you should read before concluding that your own project would be covered by permitted development.. https://www.gov.uk/government/publications/permitted-development-rights-for-householders-technical-guidance
From what I've read building two separate walls/floors that aren't connected and both have mass is the way to go. Anything that connects one side to the other is a potential transmission route. This sort of thing... PS: My son has just started a degree in Acoustical Engineering so ask again in three years and he might tell me its all wrong ?
Getting Wi-fi in remote location
Temp replied to Russell griffiths's topic in Networks, AV, Security & Automation
That looks like your best bet so far. -
Powerline adaptors (network over mains) have a theoretical range up to around 300m but are very dependent on the topology of the mains wiring. If the two cabins get their mains from a point close to or in your house it might be worth trying. If they have their own separate grid connection then no. I'm using these to get wifi in an outbuilding. https://www.amazon.co.uk/gp/product/B0746HVPMC/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 One box in my house near the CU, other box plugged into a socket in the outbuilding provides a wifi access point. -
I'm not an electrician but my understanding is that where a wire goes through a hole in a rafter or batten the hole must be 50mm from the surface. However elsewhere I believe it can be closer to the surface. Even in contact with the top of the plasterboard. For example downlight transformers are frequently just pushed through the hole and rest on the plasterboard. So the depth of batten you need depends which direction your wires run.. Then = Than.
I believe that wires should be 50mm deep where they go through rafters/battens but there is no requirement between rafters/battens.
Changing a flat’s undeclared rear kitchen extension
Temp replied to TomInLondon's topic in Planning Permission
If the planning breech occurred 20-30 years ago I'm pretty sure the planners cannot take enforcement action. Normally they have 4 years for a regular breech and 10 years for a breech involving a change of use. Not sure if the rules are different for a flat. So first off do NOT demolish the kitchen without getting this sorted as that would probably reset the clock. I would find a planning consultant to check our understanding is correct and if so apply for a certificate of lawfulness on the grounds they can no longer take enforcement action. At the same time ask them to confirm its lawful to do the work you want or even demolish and rebuild it. -
+1 We have 80mm of PIR under our UFH and would put in more if building again.
Yes sure you can still use them...if you grind off any laitance. Its just a job I'd avoid if possible.
Still have to remove the laitance (according to the instructions) because its a weak layer. It's not recommended for wet rooms either but perhaps that doesn't matter. https://www.tilemasteradhesives.co.uk/file/TDS-AnhyFix.pdf
Self-Build with UK outside the EU
Temp replied to Ferdinand's topic in General Self Build & DIY Discussion
Sorry ebay is only collecting it on orders under £135. -
Didn't i read somewhere that ebay are collecting VAT? Would you be ordering from the UK or German Ebay site?
