Help me diagnose my electric shower issue
SteamyTea replied to Moonshine's topic in Electrics - Other
Can you get the part 3D printed, ask @Onoff -
Economical way to combine soundproofing and UFH
SteamyTea replied to Adsibob's topic in Underfloor Heating
Yes, insulate and make the walls airtight.- 34 replies
Thermal conduction is to do with temperature differences. Convection is to do with physically moving, in this case, air. Now a ground floor sitting on the foundation, and then the semi infinite heat sink of the earth, will conduct energy from the UFH to the ground, so that needs lots of insulation. Between floors is a different issue in reality. Convection dominates. Warm air rises and then gets trapped by the ceiling. This reduces the ∆T between the air temperature and the UFH system temperature. Between joists is also, generally, an air pocket, so has fairly decent thermal properties. What is important is reducing unwanted, or uncontrolled, air movement between the house and the exterior. This will, apart from being drafty, cause disproportionate energy losses. So while the place is stripped bare, make sure that area is airtight, it is easy and cheap to do when nothing, apart from the joists, is in the way. Consideration must be taken into account for condensation risks, but that is a different issue.- 34 replies
?- 34 replies
One rule for them, another for us proles
SteamyTea replied to ToughButterCup's topic in Planning Permission
I really don't care much for people getting away with a few quid. What gets me is how we seem to have two laws covering everything. One says you must do it, the other says you must not do it. If only we were like Switzerland, if it is not compulsory, then it is illegal. Or just have one law "Don't be an arse." -
ASHP, Solar PV & SunAmp (Storage) Control Problems?
SteamyTea replied to FredBristol's topic in Other Heating Systems
Just cool it to 4°C -
Help me switch my Rayburn off please! (UFH question)
SteamyTea replied to andygo's topic in Underfloor Heating
You could connect the ST via a plate heat exchange. But start off with getting the UFH fitted with a Willis and see how it goes. -
Is this the sort of thing that they cover Cornish Units with?
Not sure about this, but if the building is relatively new, building control may have some records in it.
I assume these are solar thermal, not photovoltaic. Can you send then back or resell them. Failing that, you could plumb them in to supply some energy to your domestic hot water. You will probably need a new hot water cylinder, an expansion tank, lots of compression fittings, some flexible stainless pipe, a controller, antifreeze, service schedule and other things I have forgotten about. But the efficiency is tip top while heating the water, assuming the water is only luke warm to start with. PV is so much better. -
I think this may be more to do with the nature of phase change materials. -
Are these people that have not read building regs.
Welcome. As much as I like the technology of the Sunamp, it seems that it is still, like Spain, unfinished. Why do you want to get rid of gas?
Yes please, I am struggling to envisage it.
@Onoff Did you ever get a temperature display working?
Have a look at vacuum panels.
- 9 replies
- loft insulation
- building regs
May sound odd, but have you looked at the Scanwegian coutries, not that far from you, and they know a thing or two about wood in buildings.
According to this About the same. Yes there is, but you need a whole load of information. Do you now how much insulation there is under the UFH pipes, and the overall heat losses from the area you are heating. It is not that hard to work out, just a lot of repetition and very dull. It is the same formula that you use to work out heat loss though a wall, just have to jiggle things about i.e. treat the surface area of the pipe as the hot side, and the floor as the cold side. -
A Strong Drink and a Peer Group
SteamyTea commented on Ferdinand's blog entry in The BuildHub Gardening Blog
I got two cherry trees from PoundStretchers. You are welcome to them, one has been overgrown by the Pampas Grass and the other is a dry twig.- 32 comments
- ferdinand
- housekeeping
Just have re-read the original question, how about putting in a Willis and seeing how it goes. It will not do the DHW, but you could do that with a simple immersion heater. It will give you a better idea of what is actually needed, then you can design a heat pump system better. May be worth calculating how much DHW you actually use, and at what temperature it is both stored at and used at. -
Coal varies in energy density, so does depend on what you are burning. Anthracite is between 7.2 and 9.2 kWh/kg Bituminous is between 6.7 and 9.7 kWh/kg Lignite is between 2.7 and 5.6 Ranking them in order and taking the median value gives 7 kWh/kg. So a tonne gives 7 MWh. The hard part is the efficiency of the Rayburn. Rayburn claim that their ranges can give an efficiency of between 86% and 87% for the oil and gas versions, so safe to assume that the coal one is lower, let us say 75%. So that will be 5.25 MWh/tonne. A tonne of coal will produce, in ideal combustion conditions, 3.667 tonnes of CO2. -
You can’t build here. There are no shops nearby.
SteamyTea replied to Jaqueslecont's topic in Planning Permission
We live in a place of higher than average agriculture, but nationally, the employment is very low (like fishing, not many fishermen in Buckinghamshire). I am all for building more housing in the countryside, a lot more housing, and especially keen on converting old buildings. -
Too true, any warrantee down here lasts until you walk out the door, not the sort of thing the national offer.
Got both of them near me, and a Domino, MacD, Subway, Tesco, Sainsbury, Morrison, Halfords, B&M, Poundland, any many more. And this view. And every summer, a few million new people to meet. -
Not quite. https://youtu.be/nWoWHzq21tA
