SteamyTea
    200
  1. electricity prices are pretty stable, and now that the government has committed to supply all housing with RE (and nuclear probably), and with the cheapest form of new generation being wind and solar. I can see prices dropping in real terms. We can generate from wind and solar cheaper than gas now.
  2. Isn't this looking at the problem from the wrong perspective. Rather than say 200lt at 50°C, if you calculate it as the effective energy stored, say 17 MJ, then within a tiny bit, a UVC and a TS, or even a traditional WH cylinder of the same size and the same temperatures, store the same amount of energy. If you extract water (energy) at the same rate, I am really (not being difficult) struggling to see the difference. Now you can 'average' the stored temperature out by allowing turbulence within the store i.e. constant pumping, but that is not the same thing.
  3. Yes, and this is why I am claiming that sizing is important. There will be a slight temperature drop due to the heat exchanger efficiency, but that leaves more energy in the store. If space heating load is also being drawn off at the same time as DHW, then sizing is even more important.
  4. Is there some sort of different physics going on then.
  5. Those prices seem rather high, but a factor of 5.
  6. Something like this, maybe. https://www.ebay.co.uk/i/324152361393
  7. That is just sizing correctly isn't it. My cylinder is 200lt, heated to about 40°C. If I did the same with a 50lt cylinder, I would run out of hot water while filling a bath. Just sizing really, not temperature as such.
  8. I genuinely do not under stand why they will not get 'hot enough', because of the type of cylinder/store.
  9. I shall ponder this, but it is probably just a case of putting in a time delay to allow the RH peaks to settle.
  10. Yes, I do remember fitting a pump (still working) and a mixer tap (gives no problems), to my existing system over a decade ago. Oh and when I had to change my 32 year old cylinder, it was £220 (from your helpful mate) and I got quite a few quid back on the old one. KISS, it is the only way.
  11. Wasn't it done on some grant scheme, so we all have paid for it, already.
  12. I think our old mate Jeremy Harris, who is just west of Salisbury had a list of people he would recommend. The lit may be on his website. http://www.mayfly.eu/
  13. I am not sure about SAP, but seem to remember that there is no RHI on A2AHPs. This is because they are cheaper to start with.
  14. They will probably come and arrest you for attempting an RHI fraud. The NIs and Spanish are the world leaders at this.
  15. It is to do with the nature of phase change materials. When a block of ice changes to liquid water, there is a phase transition at 0°C. During this change, the energy that can be released. Water as a liquid has a specific heat a capacity of 4.2 J/g.K, when it is solid (ice) it is 2 J/g.K When it is actually changing state, is it ~325 J/g.K Now the Sunamp does not have water as the phase change material, so the numbers will be different, but it works on the same principle, it draws the majority of the energy while it undergoes transition. This is why it is hard to use Temperature as a state of charge indicator. It is not linear, but stepped i.e it drops at one rate, levels off, then drops at another rate. The same is true for charging it up, but in reverse, obviously.
  16. You can make it even cheaper to self install if you use a vented DHW system, none of that G3 nonsense. And the kit is cheaper as well, which annoys plumbers as they cannot add on such a large mark up. https://www.gledhill.net/master-pressure-get-g3-qualified/
  17. You may find it cheaper overall to not use the MCS/RHI route. Have you done the costings yet?
  18. Because of the thermal losses through the floor and into the ground. Just a case of working out the losses and see what comes out in the wash.
  19. You may find that UFH is not the best option. Have you considered 'skirting radiators'?
  20. Our Jeremy Harris put in solid copper between his ASHP and the distribution manifold. Then found it noisy. He then RTFM and found that the reason it came with a coiled flexible pipe was to dampen the sound.
  21. You have to make sure there is no noise transmitted via the pipework. But basically, make a hole, reseal all membranes, stick pipes through and seal the gaps.
  22. My view is that it is always best to insulate pipework, that reduces uncontrolled losses. Makes no real difference what the pipes are made from with regards condensation, that is a combination of RH and Temperature. Mechanically it is a different matter.
  23. More a copy than a derivative.
  24. Because Unix was locked down too much, Linux came into being. Linux is not UNIX.
  25. I do notice that MS named an OS 'Snowball'. Bet that was fun when searching for it if the Adult Filter was switched off. Especially if you added in "Work Group". (note, not much interweb about in 1993, was nearly all porn)
