All true. Though in the Oct-Mar period I tend to have my ufh on for very long periods sometimes up to 2/3 of the day, and the house cools down relatively (to newbuilds here) quickly, and the balance is between 1 - Warm enough, 2 - Low water temp for efficiency, 3 - Higher water temp or supplementary heating for responsiveness. F
Don't forget - I use PIV fans in all my rented houses to provide condensation / mould resistance and resilience against non-ventilating or washing-on-radiator tenants, as I have not accepted trickle vents for years. I often add a low volume trickle fan (used to use single room HR fans) in bathroom and kitchen to provide a "poor man's MVHR". I have always used fans with backdraft shutters and recent PIV loft fans, but have taken to the continuous ones more recently to give a low level forced airflow. That is all together with high quality renovations to provide a resiliently cheaper to run / humidity managed enviroment for Ts, which aims to keep them comfortable and staying for longer, partly by giving them energy bills 1/4 to 1/2 less than otherwise. The heat cost of having continuous low volume fans installed is in that context. And an extra £25-30 on your gas bill may or may not be significant in exchange for whatever difference it makes to your environment. This year I have done the same at home, and I do not think I have it quite right yet. In my case I have an increasingly frail mum coming back from hospital so need a warm and responsive environment. That she has moved into a downstairs south facing bedroom that is cold in winter and overheats in summer (runs up to 35C on sunny days) is the next thing I need to manage, exasperated by ufh not being *that* responsive, especially in a well-insulated but not superinsulated house. At this moment, my downstairs bathroom is at about 21C, my kitchen is at about 19C, and mums new bedroom is at about 16C. Clearly I need to rebalance the ufh again for the winter, and perhaps fit one of those carry around wireless controllers. I really want the whole downstairs at 22-23C. F
Fair cop. Full "question" in future. Must not make people think I am in a submarine. "Flood Q, Number One - Crash Dive". (Damn - just drowned the spy gadget specialist. No more exploding rat-poo for me.) F
Thanks. So - a detectable amount (albeit not yuuuuge on a Trumpian scale) or 1250 kWh per annum ish = £100 or so of electric or £25 of gas. My total energy usage is something like 12000 kWh gas and 4-5000 kWh electric for a 4-5 bed house (assuming the numbers I gave Cheap Energy Club are still right), for a bill of around £900-£1000 pa. The effect on responsiveness and perception is more interesting, even though the power to compensate is theoretically only 150W, which should be a rounding error on a properly sized gas boiler capacity. So a heat recovery fan there would reduce that by 75% in theory (may have one in stock) but give a slightly cooler than ambient draft in the bathroom by definition, but I suspect I am better reverting to the Airflow Icon. Suspect a bigger issue may be 1 - that the ufh is temperamental, and slow to adjust as they always are, 2 - that we are relatively poorly insulated for ufh, 3 - that the central programmer is immediately outside that bathroom door and so will switch off too quickly is not offset-programmed, and 4 - that I tend to use the upstairs heating relatively little, which means that I may lose a lot up the stairs. But every little helps, marginal gains and all that. Back to Airflow Icon I think when I get to it. F
As it is continuous there is no opportunity for backdraft. The q is about how much heat will be carried by a continuous flow of air. For vents, you can get all sorts of things. I used one of these in a gable, which has both a wind cowle and a backdraft shutter https://www.amazon.co.uk/gp/product/B01G3YNLJ8/, but may not fit. Or in line ones are available. Or you could change your fan. Go a hunting on Amazon. Ferdinand
A quick question - how much heat is lost through a fan running continually at n litres per second (currently 6) with temperature differential delta-t (currently prob. 15-17C)? I have replaced my fans in both bathrooms with a pair of Vent-Axia Lo Carbon Centra-T devices, which run at either 6 l/s or 9 l/s continuous setting. Before one was a bog standard thing installed by the (self) builder, and the other one downstairs was an Icon Airflow I have had in for a few years. Unfortunately for unavoidable reasons, the downstairs one is directly above a radiator, and it is the warmest room. I also have a PIV device fitted, which will run at a low setting in the winter (and switches itself off at low outside temperatures anyway) to give me some modest throughput. The issue is that in the last few days with outside temps at perhaps 2-3C the heating response had been sluggish, and I have someone coming back from hospital to a downstairs room and I need to run at perhaps 23C internal temp, which is either very slow to reach or out of reach without eg a fan heater on. I am wondering if my new throughput fans are part of this issue - the plan was that they would be marginal, but I am looking for causes. This morning I will switch the d/s bathroom off completely to stop the fan to see, and will take some thermal piccies, but possible solutions include putting the Airflow Icon back, or replacing the d/s bathroom fan with a Heat Recovery Version. Any comments and insights are welcome. Thanks
Welcome to the Pleasure Dome.
And think carefully about the surface of your floor tiles. I would argue matt not gloss, but think carefully before going to "textured" ie non-slip as they are significantly more painful to keep clean. The second bathroom I have done this year is matt, but I needed non-slip for my frail mum downstairs for the first one. Get whole tile samples and put scrubbed in mud on them then work out how you will clean it. Ferdinand
I was going off @Nickfromwales's numbers. F
What I would say is to make the length of the screen at least 1m-1.1m if you enter sideways, and perhaps 1.7m if you enter at the end - both without a door.
Any of that left over from the bathroom. If HMQ wants to ban the skulls, then why not put an outdoor shower on the back? Then do the panels with those blue dolphins.
Planning permission … the journey to it … and thanks!
Ferdinand commented on Dreadnaught's blog entry in Under the Chestnut Tree
There's always a piece of music, but here it seems to be either the folk song or this one, which is quite cool. The tune and variations. Apparently (alleged in Youtube comment, but sounds plausible): Wonderful, mysterious, evocative. Composed just after the Munich Agreement - the composer - a Czechoslovak saw a newsreel of the British royal Family singing this British folk song under a chestnut - representing the values it was hoped the Munich Agreement would safeguard. Poignant! the composer escaped to Ohio and later St. Petersberg, Florida! -
Oh yes, good idea but the plot looks rather like a jungle at the moment. I live about 2½ hours away from it so I haven't been a dutiful gardener. We like jungles. How about a nice photo of the jungle? And good news to see. *polishes nails on tie on behalf of entire forum* So on that timeline you completed on it before PP was approved - how did you come to that thought? -
I do cubed or sliced mushrooms in a wok to half cooked stage, then put a layer in the bottom of a Tupperware mini container with a layer of curly kale on top. Kale may be slightly cooked itself. Then do say 10 or 12 of them and freeze. Heat up in the microwave on say 30-50% power whilst doing toast and poaching egg, and it can be turned out onto the slice of toast and the poached egg put on top as a filling but lowish carb / cal breakfast with some veg included. The juice left by the mushrooms goes into all sorts of sauces and gravies to add flavour if you like to keep your toast crispy. Goes well with say half a dozen mini tomatoes or kipper or whole / flaked mackerel or even smoked salmon. Anything less robust than kale eg spinach tends to turn into green goo by the freezing and reheating process. Will look for a pic. It is a variation on a recipe Salmon and Eggs out of a book called Very Low Calorie Recipes and Meal Plans, from the people who do the Carbs and Cals App For slimmers and diabetics. https://www.amazon.co.uk/Carbs-Cals-Calorie-Recipes-Plans/ Ferdinand
See this and links therefrom. A set of articles including costs about my Conversion/Reno of shower room. It is flagged accessible but covers everything. F
I am currently working through the crocks my parents had for their wedding in 196x, and the batch I bought for University. Made the sensible decision to instruct everyone what they wanted, and ended up with about 20 of everything. My nice knives do *not* go in the dishwasher. Anybody who does put them in had better watch out. The 40 or 50 small tupperware jobbies used for batch making kale-mushrooms, porridge, and Complan (especially the Complan which turns into chocolate coloured plaster of Paris) most definitely go in the dishwasher. F
Log burner
Ferdinand replied to jpinthehouse's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Suspect that the energy density is too low for the work involved. Grow pineapples and bananas like the Victorians. -
Scaffolding tent for temporary roofing
Ferdinand replied to andyscotland's topic in General Self Build & DIY Discussion
But will not rip. -
We used a scaffold foot stood on a first pour, then added a clamp and filled up the hole iirc. It was the anchor for a 6m tower for a 1m satellite dish. -
New Avatar. Beautiful again.
Is lorry curtain better than tarp? -
Would it be worth actually concreting in the posts which are going to get the "up" vertical wind load, using a block with the top slightly below ground so you can just saw it off and cover later? Would that be of any material benefit? Depends on whether your wind direction is relatively constant (?) Empahsize: I am not experienced at this, but I have seen a scaffs blow over. -
@mvincentd if you keep an eye out for garden walls that are say 6ft high, you will see that they have thicker piers or columns in the straight sections which do the same job. Equally if you go out after a windstorm you can see the characteristics of weaker ones which may have blown over. F
That's a bit treacherous; don't tell Sir Geoffrey. ? Don't trust Yorkshiremen; they keep trying to steal Robin Hood from Nottinghamshire. Welcome from the sunny Midlands. That's interesting. Time to tell b-i-l that he is the human equivalent of a coelacanth. Real question - is this is bijou domestic "garage", or more like Bristol Street Motors?
