Ferdinand
    41
  1. That is the best way ... make the vendor responsible. (If it gets more complex, then we can go into that). btw Manual For Streets is here: https://assets.publishing.service.gov.uk/government/uploads/system/uploads/attachment_data/file/341513/pdfmanforstreets.pdf As one aside, if they are requiring that the 30mph zone be extended beyond your new entrance, then they should perhaps not be arguing for a National Speed Limit linked visibility splay, 'cos there own requirement is 30 mph. And you could use the other condition to argue that they should be using a shorter splay - but making the vendor do it is easier. (And if they can't do it, then you can reduce your offer if you think you can ?).
  2. This is after how long living there? Do I understand that this is where all those dodgy curries and beer went? And to think I am in Kent on Friday ...
  3. You need to work out what you have to clear in order to make that splay visible from your driveway. It may just be leaving enough space at the front edge. Have a look at Manual for Streets, which explains hwo a visibility splay applies to a site. Or you could ask for an answer as to what has to be done from the seller. F
  4. Best of luck with that. I'm quite keen on art'n'stuff in architecture, but it's always a question whether we want 'extra' decorations, something in the basic architecture, or something which fits in with the design but enhances it. The "one percent for the arts" seems to be a good idea - substantial without being onerous, and a chance to support local artists who can give good value and real engagement. At home I have a Gryphon on the gable, and a custom done stained glass panel in the front door - both put in by the self-builder who converted it. The only one I have done recently is a more elaborate brick garden wall than necessary with some minimal diaper brickwork in it, with the usual blue and red bricks inverted - ie whole wall blue with red lozenges. And I am a sucker for etched glass. I am sure that there are plenty of unpuffed interesting bits on bh everywhere. Ferdinand
  5. Well done.
  6. And I suppose, never forget that it is no longer a garage.
  7. I think a fall away from the house door is an acceptable alternative. Make a flat section by the door so that wheelchair users have no risk of rolling away whilst opening the door.
  8. Certainly something I have seen; one was called a half-garage. Particularly in newish houses, where built-in store cupboards are missing as they can reduce measured room size. @SteamyTea could call it a "Smart Car" Garage. You need to decide what you call it in planning / building regs, and how you handle the conversion and future potential uses - which may require PP or Regs sometimes. Or you may choose to ignore that. Obviously you need to do things like consider ufh if required, and putting your joists along the top of potential stud walls etc. Also, calling it a garage may count against your required Planning Policy parking space quota if it is large enough - think it needs to be 6m x 3m, but check. For this plan, would need to be slightly wider and be called a "garage" in its entirety. You then need to be aware is required spaces minus one will be enough for you. I think the current dimensions commit you to chucking out the passengers in the rain, and reversing in only for a RH Drive car. So, really just map out your possible future plans carefully, and do not put stuff on the plans you do not want to have known. Dirty bikes? Unconscionable :-). Wash them ?. Ferdinand
  9. Historic Houses Association may have some guidance material.
  10. Depending on how much work you plan to do there are kit suppliers around on ebay. Start here:
  11. OK. Looks like a *relatively* small space, joined to another space. I would put the tall elements together to make them seem smaller in the space, including the fridge and freezer if tall. I might be tempted to go across the back because loosing 600mm from 3100 will make it look a little tight (perhaps). Also high cupboards will obsure your rooflight, which perhaps you want to light your main work area. For the oven, it is basically an extension of the hob, and imo fits in the triangle but I would consider where to put things coming into and out of the oven. Worktop next to it, or a tall shelf that has a 600x600 floortile on it immediately below. I would want to be able to place a hot dish or eg a roast on a safe surface with a swivel but no step for reduced safety risks. Do you have fixed points where sink, dishwasher etc need to go? It may be useful to list what you need - I make it that 13 600mm spaces are available. Perhaps also a peninsula breakfast bar and a mobile 'island' in the form of one of those wooden Ikea trolleys might be useful to create more space / flexibility. Just my thoughts. Ferdinand
  12. Unfortunately the H in Scotland is not silent, according to Sean Connery.
  13. It ‘s a travesty. Silent K is grossly overused. It should be Gnapping, as in Dennis the Menace.
  14. off grid ==> chamberpot of some sort.
  15. Get a flock of sheep for lawn tidy and freezer next year. Or talk to @newhome about the Racing Simulator she may still have gathering dust.
  16. Welcome. Personally, were I doing a renovation with a new slab in the floor, I would not bury pipes or wires in the screed or slab simply for maintainability reasons, studding out the wall where necessary. It sounds, as has been remarked, that the Planning / Supervision may have been insufficient. If they are wall mounted I would not see a need to conduit the electrics, or in extremis perhaps even insulate the water pipes. I would aim to minimise plumbing runs, but elec would need to go everywhere as I fit a *lot* of sockets. Ferdinand
  17. You may have trouble arguing that over a 20 year period. Policy changes and tightens. Though pointing out that a busy Antiques Business would generate many times more traffic might help ? .
  18. Also why you want a shower accessible from the utility room as well as study perhaps. Muddy doggoes and children, perhaps.
  19. If you want a longish read with lots of great ideas on robust design and fitout, try this old thread of mine on Landlordzone from 2011. "The Tenantproof House" About 200 posts but quite dense content, but forthright thoughts from lots of LLs. My favourite I think from this thread was someone who dealt with the Student Wear and Tear challenge by procuring a secondhand commercial kitchen from a restaurant made entirely of stainless steel. Obvs students would love that. https://forums.landlordzone.co.uk/forum/energy-efficiency-epc-design-repair-improve/35896-the-tenantproof-house F
  20. This thread seems to be a duplicate.
  21. (Seem to be 2 versions of the thread) Ouch. Make it smaller for GIA purposes. I think the first need here is thinking time, as CIL takes a bit of getting to grips with and varies by area. But the easy way is if the GIA calc is less than 100 when you correct the Council, if they accept the basis of your calculation. What is the actual GIA? Start with that. If your PP is still in process, in which case I think you can "withdraw" it then resubmit within the next 12 months without having to pay another fee. If it is not yet determined, I would check that you can do that, then withdraw and go into the regs etc. Can you make eg your logstore or your sitting area open to the outside etc. to shrink the GIA ? Walls can take up a lot of space :-); can you make some walls a bit thicker with insulation, or use other tweaks? Make it accurate, 'cos if I were the Council I would come and measure it having been subjected to that sort of claim. Ferdinand
  22. Replied to this but my reply has evanished. Will see if it reappears then try again if not.
  23. Ouch. Make it smaller for GIA purposes. I think the first need here is thinking time, as CIL takes a bit of getting to grips with and varies by area. The easy way is if the GIA calc is less than 100 when you correct the Council, if they accept the basis of your calculation. What is the actual GIA? Start with that. If it is GIA can you make your logstore open to the outside etc. to shrink the GIA ? Walls can take up a lot of space :-); can you make some walls a bit thicker with insulation, or use other tweaks? Make it accurate, 'cos if I were the Council I would come and measure it having been subjected to that sort of claim. If your PP is still in process, in which case I think you can "withdraw" it then resubmit within the next 12 months without having to pay another fee. If it is not yet determined, I would check that you can do that, then withdraw and go into the regs etc. Ferdinand
  24. Don't forget to focus on risk and time as well as money. I cam commenting from a Midlands perspective, but with family in Surrey and I live in a bungalow +1 storey, which was reduced to a hole in the ground and 3 walls then rebuilt. I am not absolutely clear about whether you are happy project managing at a level of Administrating it, or the more demanding feel willing to instruct your trades / subbies on some things. iii) I think that to get an "extra storey on your roof" company to do that could easily cost nearly your entire budget for a nice new storey and a staircase. It may not, but it could. That could put you in the "all the money on 2/3 of the project - bugger what do we do now?" category. It happens. That is a risk you need to manage. ii) I can't really comment on - turns heavily on the local market and what prices you are given. i) I would suggest this one, unless you have clear ways to manage the risks you identify on the others. I would then suggest identifying a possible "Phase 2", which would be a ground floor extension in the future if you feel you need it. That could also be doable under Permitted Development. I would also say: 1 - Given the roof complexity, buy your own scaffolding. 2 - There are certain elements not in your list of costs, as you know. A full list (incl. for example fabric improvement) would be a good next step. 3 - Explore options such as reduced rate VAT as it has been empty. 4 - Do not forget the Council Tax you save by getting in early. 5 - Is there a risk of losing your 3% Stamp Duty if you take time selling the other one off? 6 - Serious consider whether you need a PM or Advisor to help you manage the technical side. Ferdinand
