Everything posted by ProDave
If it has planning that is locked in because the development is clearly "started" then just go ahead and create the entrance using the details on the plans that are already approved. THEN think about a new planning application, knowing you can still fall back on the existing "started" application if that is refused.
That is for a Scottish temporary habitation certificate, I don't think England has such a formal process.
I got this written into the planning for ours, that I wanted the static caravan to remain after the build as a "garden building". This overruled the usual clause saying the static caravan must be removed. Instead they inserted an alternative clause "habitational use of the caravan shall cease upon occupation of the house" They are just ensuring you don't end up with the caravan as a second separate dwelling.
Internal floor splitting double height entrance
ProDave replied to Phyllis70's topic in Introduce Yourself
In principle you should be able to find the structural points of the wall at first floor height (that will probably be supporting the other floors) and span a floor from those. but to access your new mezanine floor you will need a short staircase up from the half landing but there I see a problem, those stairs will be cutting across a dooorway. Picture from below may help? -
Managing building control in a non-standard way…
ProDave replied to Omnibuswoman's topic in Building Regulations
English BC must be somewhat different to Scotland, as once our shell was up wind and watertight and all insulation in, BC inspected and I then asked what is the next inspection needed and was told "completion" They never did inspect first fix plumbing and electrics. As it happened we got them in sooner to get a temporary habitation certificate and then the completion inspection. -
And for mass take up of renewables like heat pumps and solar PV someone really really needs to give all the DNO's a kick up the whatsit and make it their problem to upgrade the grid rather than saying no you can't have. Take away the hostility that people like me would face if they wanted more PV for example.
The electric car thing. We are being told they are just as good as an ICE car and we should all have one. Just 2 problems with that. First they are NOT as "good" in some respects because range and charging times limit their use compared to almost instant refuelling of an ICE car, and they are even more hopeless if you want to tow something. The "sales pitch" needs to be more honest, they are just as good for many users that don't do long journeys or tow anything, but be HONEST that they are not a drop in replacement that will suit all uses. And if you answer that with "they will get better" then that just reinforces my point, they are not yet ready for all users so why buy a pre production development model? And secondly they are just too expensive, most people like me could not afford one even if I wanted one.
You build up the foundations from the existing ground to your finished floor height and then you infill the ground around the house to raise the level. Building up first would mean you are building on unstable made up ground.
That calculator gives me estimated 7KVA rising to 14KVA if I add a car charger. I better not tell anybody if I ever add a car charger then. Actually our 12KVA supply is in no way limiting, it is wired in the same 35mm concentric cable to the house as any other modern connection, and fitted with a 100A main fuse. So it is 12KVA only in name.
2.500 Acre Solar Farm.
ProDave replied to twice round the block's topic in Environmental Building Politics
Here is a thought. Can't a solar farm share the same land as a wind farm? Mostly built in hills so not productive farmland. Yes some panels would get some shading from the towers but it would seem to be a good dual use of land and infrastructure. -
The DNO's need to be forced to be less hostile and more accepting of solar PV. When ours was registered with the DNO (under the old names I forget which but 3.68kW) they read the model number of the inverter "TL4000" and without reading anything else rejected it, told us to disconnect it and apply for permission and there would be a network upgrade charge as it was over 3.68kW. Forcing them to read the documents and that even though the inverter had 4000 in it's model number, it was only 3.68kW resolved it and they accepted it, but it showed they are hostile, do not really want it, and will use any excuse to try and extract money from the customer.
I assumed they are supply pipes, but we just don't know do we. Surely the water co should at least be able to tell you if they are supply or drainage pipes? Of course there will be both in the vicinity, but if only one is on the map it still begs the question, where?
You need the lid off that chamber. There are no drainage pipes shown on the plan, but there must be some, somewhere. So perhaps that chamber is for the drains. I still say all would be answered in 5 minutes with the divining rods, then you know where to carefully dig for confirmation.
I did my 1/3 acre plot all on my own. Can you not do the same?
It is used for streaming internet radio (mostly Radio Caroline) playing music from it's own memory, or from a phone (via Hi fi Cast) I would not know how to set up two Pi's to talk to each other like that, but the advantage of a hard wired audio link is they all play in sync throughout the house, no lag between one and another.
An example of "under engineering" In the tv's I only put power, 3 * coax and a cat 5 cable to the bedroom tv points. We then decided we wanted sound in the bedroom, from the same Pi Music box as downstairs. A quick bit of lateral thinking I repurposed the 2 spare coax cables as audio left and right to the bedroom.
I had the opposite. Scottish water subcontracted our water connection. The plan said the water was in the verge the other side of the road. The subbies dug for it and could not find it. They dug deeper and further from the road into the field, still no sign. They were on the verge of packing up and going home when I got my rods out. You could see them sniggering as I slowly walked further into the field and my rods reacted, so I said "here it is". Just to humour me they dug a bit further and there it was.
Acoustic insulation that's tough enough to shove under floors?
ProDave replied to Sparrowhawk's topic in Sound Insulation
Frametherm 35 is quite stiff. I left this test piece for 6 months without any support and it did not budge or slump. But I would want something under it to support it. -
1920s cottage renovation and extension - South Wilts
ProDave replied to Anonymoose's topic in Introduce Yourself
I am interested in the cantilevered second floor. Is that what the external piers are for on the brickwork? -
If you start talking galvanised conduit, then you need a die and cutting compound to thread the ends. Never worth it for a one off job. Use PVC instead. I question the circuit design, it sounds like spurring from and existing socket to then feed a CU in the garage. The total load will be very limited, and a real chance of overloading the 2.5 t&e. A spur like that is allowed to feed one socket, that will be limited in current by the plug(s) plugged into it, not for feeding a CU for multiple circuits. Look to get a feed from the main house CU in proper sized cable for this.
Go divining to locate the pipe. Yes I AM being serious.
Crazy system penalising wind energy
ProDave replied to saveasteading's topic in Environmental Building Politics
There is no joined up thinking. We are building the wind farms where there is no more grid capacity, before the grid is upgraded to cope. 4 more are planned near here, soon there won't be a hilltop without a wind farm on it. The planned additional 400KV overhead north / south line is barely passed planning stage after nearly 10 years, yet to start construction. There is a hydrolyser plant about to be built. Being built to use the surplus power the grid can't take to make hydrogen to be trucked by tanker (hydrogen powered I hope) to feed local distileries. The hydrolyser needs water, a lot of it, so a new 15 mile pipeline is being built to pump it from a local river. Now my little brain says 2 things, surely it would be easier just to build a local distribution network to feed the distileries directly with electricity rather than have the losses making then transporting then burning hydrogen? And if you are going to build it, surely it would be easier to build it near the river and transport the electricity to the hydrolyser with a new cable, rather than lay a new pipe and pump the water up hill?
