Everything posted by ProDave
That's what the "static" in "static caravan" is all about. They don't move apart from when they are delivered or when they are removed at end of life. Traditionally a static caravan was limited to about 10ft wide for road transport reasons, though larger can be transported with additional restrictions like needing an escort vehicle. So to make a large static home, twin unit residential caravans were made. 2 separate typically 10ft wide caravans that when on site bolt side by side to each other to make a 20ft wide home. If you ever expect to move one you would uncouple the 2 halves and move them as 2 separate units. That I am sure is where the original must me moveable in no more than 2 parts came from. This amendment to the HC definition of a "caravan" has been poorly thought out and appears to exclude twin unit mobile homes that are genuinely caravans on wheels, from building regulations exemption. I would like to see that contested. Are the HC really going to insist a twin unit mobile home would require building regulations? which it would fail as they are built to different regulations? It sounds to me like they have bade a huge cock up with this update to their policy note, and it needs challenging.
I would drop Building Control a line and question this change in policy and specifically the point about normal twin unit mobile homes which would no longer appear to qualify as "caravans" under this new interpretation.
That's an interesting change. It seems it can be constructed from as many sections as you want, but once complete must be capable of being moved as one piece. That seems to rule out the traditional wheeled twin unit mobile home. While no doubt you could try moving that as one piece still bolted together, I suspect it may not work very well and the joint would separate and break. Could your extension include a new "chassis" strapped underneath the whole thing so at least theoretically mean it could all be lifted as one?
Double or triple glazing options, what is the difference?
ProDave replied to JohnnyB's topic in Windows & Glazing
Very pleased with our Rationel triple glazed windows, definitely not cold so sit next to, but they are probably a bit modern looking compared to the look you are wanting. -
My neighbour had one last year. I have no idea what make, but it was orange, round and about the size of a dustbin lid. It was the type that had a wire around the perimiter and it turned round when it sensed the wire. It took a lot of adaptations of the garden to make it work. It would sense and turn round if it detected something like a solid border around a flower bed but it was no good at detecting imperfections in the ground like the rounded top of a boulder sticking through the ground and would get itself stranded and unable to move. He eventually got the garden sorted to keep it mostly happy. In use, it was completely random, no attempt to go up and down methodically cutting strips side by side. It just trundled until it reached a perimiter or an obstacle, turned around and went another direction. Never turning 180 or 90 degrees. So it eventually covered the whole lawn by the law of averages, but went over the same parts many times. It would trundle back to it's charging house when it needed or when it rained. He has not deployed it this year, I don't know why if he has given up with it or what.
Seriously, anything you do by way of patching up is going to be a short term measure before the rest of the fence goes. The only real solution is take it down and rebuild. Because you don't want to dig out the old concrete, your new posts will all be displaced one way by a distance. It will mean short section of fence at one end to reach the new, now offset, post the the remainder of posts fitted at normal regular intervals. While it is down have a serious look to see if the rest of the fence is worth saving, if it is give it a good clean and treat liberally with wood preservative. For the new posts, use short concrete posts with the wooden ones bolted to them above ground.
Fridge in hallway / fire regs and ventilation
ProDave replied to makingprogress's topic in Building Regulations
They all work by convection. On the back there is a "radiator" which is where the extracted heat is removed. sometimes it is exposed sometimes as a concealed flat panel that gets warm. The built in ones have grilles in the bottom to allow cold air to be drawn in at floor level, under the fridge and up the back. They need a gap between the back of the fridge and the wall and the top of the cabinet needs to be open. So they are certainly not "enclosed" and definitely not in a 30 minute fire compartment. I still think rather than argue against dubious implementation of a probably non existent regulation, just make sure the fridge is not there for the completion inspection. -
CU with SPD's is likely to cost in the region of £200 Full days job to change it and test everything properly so £300 would be about normal. So £600 is not extortionate.
Just make sure the fridge is not there for completion inspection, out it in the shed, in your car, anywhere out of sight. Then just put it where you want. Too trivial to do anything else with imho. -
So a chimney on a hipped roof, will have a (usually lead) valley behind the chimney to catch the rainwater that runs down that bit of roof and divert it around the chimney. It sounds like that has failed. Being a bungalow it should be an easy repair with no scaffold or perhaps a small scaffold tower. A roofer who won't climb a small ladder to look at that is not the one I would choose to do the job. Find a different roofer to go up and have a look.
Why is the fridge not in the kitchen? That seems a major design flaw. As above put it somewhere "normal" for BC sign off. Awaiting the picture..... -
Our house is well insulated, air tight and ventilated with an enthralpy mvhr unit. The hygrometer barely moves currently sitting at 58% I have never seen it above 60 or below 50 and it only ever changes very slowly. That is no guarantee that it would help your condition but it sounds hopeful. A house without mvhr has pretty much random ventilation, largely depending on how windy it is. At times it will be unfer ventilated and stuffy, at other times over ventilated and cold. Our new house is never too hot or cold, never draughty yet constantly has fresh feeling air inside.
If drilling from outside, be prepared for missing the light switch or drilling through an existing cable in the wall (which you will have isolated at the CU first just in case) and be prepared for making good the mess you make of the plaster inside.
One other thing, if you have spent a while designing developer boxes on housing estates, design your own home a LOT larger. Don't confine yourself to a developer type house where you barely get room to walk alongside the bed and no room for a dressing table etc. Be generous with your living space. Our 5M by 4M bedrooms are about adequate.
In old houses I doubt too low humidity is your problem. It would be good to identify what you are trying to avoid. Start by getting a hygrometer in the house that affects you. I think most people with an mvhr like me report good internal air quality as one of the benefits. Have you ever been in a house with mvhr?
Help with unfinished lean to roof extension
ProDave replied to kclarkey's topic in Bricklaying, Blockwork & Mortar
Can we see a more zoomed out complete picture for perspective please? -
Yes get a new CU that is very old (1965?) and as pointed out no RCD protection and no hope of getting RCBO's to upgrade it. Once cable witn no sleeving on CPC but that is trivial to fix. Likely no earth bonding to water or gas. Third MCB from main switch seems to feed a lot of different stuff.
Just drill at an angle. I would drill from inside, taking care as you are nearly through to go gentle to avoid bursting the brick. Drilling from outside, you might miss the switch.
So it means you need to request a "formal offer" only then can you discuss it and negotiate it. The formal offer should state which items are contestable (could be done by others) and which are not. I got my quote down a lot by doing all the contestable work myself. On the subject of capacity, I was offered a 12KVA supply as the most that was available, any more would require a transformer upgrade. That is ample for our needs.
Post pictures of what is on the outside, and the corresponding inside. I usually solve this by putting the switch for the lights on the inside if the wall they are fixed to and the switch creates the safe zone for the cables.
Looking in the loft will show you if it's a pipe leak or rainwater leak. It's above the fireplace, so strongly suspect a chimney issue. You should be able to see water running down the wall in the loft. If it is chimney then getting properly onto the roof is required which most likely will need scaffolding.
On an EICR that would be a C2 and so "unsatisfactory" so he should not have left it like that.
