Everything posted by ProDave
Usually the cavity is filled below DPC so there is no "cavity" there. As there will be a cold bridge from the beams out through the wall, I would perhaps mitigate this a bit by not taking the UFH all the way to the edge of the floor, as another way of giving the heat further to travel to get out of the house.
Can you explain this better? Are you saying the 4" pipe from the cooker hood is venting INTO the cold loft space? It should not do that, it should be routed either to a 4" soffit vent ot a roof tile vent.
Workshop build using shipping containers - Electrical Advice
ProDave replied to Walrus's topic in Introduce Yourself
If your 2 containers are physically attached to each other you could be on a sticky wicket. Unless you are using it as one wide space, I would have kept them as 2 separate containers with a small gap, matching doorways cut and a very short connecting link that was built to be removable so allowing them so still be lifted as individual containers. -
My impression is all his questions are about the neighbours extension, trying to find something "wrong" in what they are doing. But he won't post pictures for us all to see he just PM's some to those that ask.
Where is the kWh price heading in 2022?
ProDave replied to epsilonGreedy's topic in General Self Build & DIY Discussion
I am paying 32.56p/kWh and 57.33p/day standing charge. You are paying 16p more for your day rate. You would have to be using a lot more off peak than day rate to make that worthwhile. -
Are the tiles the easiest / most cost effective?
ProDave replied to JohnBishop's topic in Wall Tiles & Tiling
I used Multipanel and always have done. BUT check how they are made now. Mine are the original ones with a marine ply backing, but I recall readinf somewhere that due to supply issues they had switched to MDF. Can anyone that has used them recently confirm or deny that. Do NOT buy them from a "bathroom shop" The local one here wanted nearly 3 times the price for them that Jewsons supplied them for. -
All interesting stuff, but it comes back to use natural gas as the soruce (bad) or we need a LOT more renewable electricity going spare to make it carbon neutral. Something for the future when (if we ever get there) there is more renewable electricity being generated than we know what to do with.
Use space under the stairs
ProDave replied to JohnBishop's topic in General Self Build & DIY Discussion
A quick search found this as an idea -
Probably easier to buy threaded rod and cut to length, a nut on each end.
Have you considered one of the "wet wall" type products like multipanel? -
If you would post some pictures of all the things that are troubling you, people may be able to give meaningful replies.
Two questions - I'm a newbie
ProDave replied to Adrian_london's topic in Air Source Heat Pumps (ASHP)
Many of us are watching this with interest. Please keep us posted with progress, good or bad. Most of us will be hoping that Octopus break the mould and manage to give affordable ASHP installations that work, in all types of housing. If they succeed in providing a cost effective install on an older property like this then ASHP's will be a viable alternative to boilers. -
Insulhub Isotex Voluntary Liquidation
ProDave replied to Surfiejim's topic in Insulated Concrete Formwork (ICF)
It needs an admin to change a users name, it is beyond the humble powers of a moderator. I am sure one will be along soon to help. -
Based on a recent thread, if you pay the £500 deposit, pay it on a CREDIT CARD. -
Can you explain this please. Does the account just need to have an overdraft facility, or actually be in debt and using that overdraft facility? and how long does that overdraft have to remain? -
No different to water sitting in any of the other grooves in a deck board. The whole frame is set with a slight fall away from the house to try and prevent that.
So what if anything is wrong with my idea of a bead of clear sealant in each deck board joint? It would stop most water getting through and still allow a bit of movement. Unless someone tells me why not, that is my plan.
If you look back the the photos of the deck frame, all sides have a solid edge, so a drooping membrane would just serve as a bucket to collect stagnant smelly water with no means of escape.
I used 12mm ply as a floor at 300mm centres for the mezanine (I wanted to minimise floor build up) and I thought that was pushing it.
So I put the balcony project to bed for the winter, while I pondered what to do about deck material, handrail, banister etc. I had pondered what to do about the floor (deck) material and in the end decided on standard decking planks. They have been ordered from Jewsons, delivery in a week. Since our local branch closed last year, we have to order from the Inverness branch, and tomorrows wagon trip up this way was full so next Friday was the soonest they could deliver. I could go and collect but I don't want to. No rush. Since the failure of the decking pant experiment, these will be left plain wood colour, contrasting with the frame, and will get painted with a coat or 2 of "clear decking sealant" (lets see if that works) Now I would like the area under the deck to be reasonably water tight. Not water tight like a roof of a building, but to minimise rainwater getting onto the deck frame, and we would like to use the space under the balcony for winter storage of garden furniture, to keep the worst of the rain off it. That is why I was pondering alternative solid boards to use. The current idea is standard deck planks, but run a bead of clear waterproof sealant along the joining edge to seal the gap between adjacent planks. It will never be totally watertight, but can anyone suggest why not? I discussed before we will be using "yacht rigging wire" as the banister. I bought the one I previously linked to from Amazon. It looks okay, and is easy to crimp the ends on with a hydraulic crimping tool so should make a neat job. You can tell the nicer weather is enticing me to get "back to work on the house"
And if you don't have a smart meter, i assume the deemed export remains?
How old is the system? did you see HOW he bled the UFH pipes? (tip is usually involves the use of a hose pipe) If a new install it is clearly not right so keep pestering him.
Talk to us here about that. The Grant is fairly simple to wire in it's basic configuration, the one I fitted, bought as a complete package came with Grant's own wiring centre and a volumiser and the pre plumbed tank. Here is a picture of inside The tall thin white box is the volumiser and the frey box just to the left of the UFH manifolds is the Grant wiring centre. You may find the 6kW ASHP is a little under sized if your heat loss calculations say 5kW. If the heat loss if 5kW on the coldest day, then your heat pump will have to run pretty much 24/7 but it will have to spend some time heating DHW. Just be prepared to have a back up heater, even if just a plug in convector heater if a few days of th year it struggles.
