MikeGrahamT21
Everything posted by MikeGrahamT21
Wrap Around Extension - What Insulation should I use
MikeGrahamT21 replied to Ambaz79's topic in Heat Insulation
I'm also planning on CT-PIR for an upcoming build, 100mm for me though. There are a few other options, all equally expensive... https://www.travisperkins.co.uk/insulation-board/ecotherm-eco-cavity-full-fill-insulation-board-1200-x-450-x-90mm/p/670253 https://www.buildingmaterials.co.uk/celotex-cf5000-premium-full-fill-cavity-boards-1200mm-x-1200mm-x-97mm-pack-of-96-138-24m2 https://build4less.co.uk/products/thermaclass-cavity-wall-21?variant=40086149398721 https://www.kingspan.com/gb/en-gb/products/insulation-boards/insulation-boards/kooltherm/kooltherm-k106-cavity-board -
MVHR Making A Gurgling Sound
MikeGrahamT21 replied to deptfed's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Oh dear, someones fitted that wrong! Its basically sucking air up via the tundish, and therefore bypassing the heat exchanger, with it being cooler weather you'll have condensate, which is where the gurgling is coming from. Get rid of the tundish, and connect straight into the trap. Ideally it should be a water filled trap, with a good bend to it to prevent this. Once fixed, you'll also recover more heat too. For a very quick fix, tape the hole up in the tundish, but it must be airtight to stop that noise from happening. If it still does this after, then the airless trap doesn't like negative pressure. -
The cheaper ones will use EPS, more expensive ones use XPS, XPS performs slightly better, and i do mean slightly.
- 1 reply
Green Belt - Extension Refusal What Now?
MikeGrahamT21 replied to Littlemiss79's topic in Planning Permission
When was the original extension done? This may have been your one free ticket to PD. I think in this case it would be ideal to setup a meeting between yourselves, your architect and the planning department to get a feeling of what may be acceptable, otherwise you are just going to be blindly guessing and spending more money on plan changes. -
Plans completed and submitted
MikeGrahamT21 commented on MikeGrahamT21's blog entry in Back on the self-build waggon...
OK, thanks for the comparison though, I've a funny feeling i've undervalued the work. Really annoying as when i planned this I was going to do all the work myself, materials were around £7.5k, but now I'm not able to do the work myself due to health reasons, I guess I should just brace myself! I wonder if prices will ever come back down again, they rarely do though! -
Was that shell only though or completed inside and out? -
Dolby Atmos Speakers
MikeGrahamT21 replied to MikeGrahamT21's topic in Networks, AV, Security & Automation
I’ve got my final setup now with a Marantz nr 1710 receiver and the IC400 ceiling speakers, although there isn’t much content which is native, it does also upscale non atmos/dts:x content and this is very good, not sure I could be without now. friend has a Sonos arc plus rear speakers, this bounces off of the ceiling and also sounds very good, but despite its cost can’t replace hardwired ceiling speakers. upward firing requires a flat ceiling (no artex) to bounce properly -
Does anyone want to hazard a rough guess how much this extension may cost? I’ve had a couple of quotes which in itself was hard work, and came back at £27k which seemed a bit steep, especially as I’ve already got the facing bricks and this was for shell only, no internal works. got another lad visiting today to have a look and a company visiting in the coming days. the cost per m2, is it based on finished floor area, or the area of the footprint of the building? I’ve got in my head it’s finished floor area but maybe that’s where I’m going wrong. im still not up to doing the work myself so it’ll either have to be pay the high price or put it off for a while -
If you don’t use PIR or insulated plasterboard you’ll need a VCL on the warm side, so you may as well just go with insulated PB unless you want natural insulation. Avoid battens if you can, it’s just another thermal bridge
You’ll never get a cavity 100% sealed unless it’s built that way. having the air gap will render EWI almost pointless, you’ll save a little on thermal bridging from the wall ties, but hardly any. Thermal bypass will occur in the gap. filling with slow expanding foam is an option, but you MUST use fully breathable insulation on the outside if you do. a better option is likely insulated plasterboard unless you have a good reason not to
To do it properly, you'll definitely need 1 wired controller per zone, thats just how they work. Watch out for some offers after christmas.
Sorry I never got any further with this. I did find that eurocell no longer sell the glass which allows 0.81U as per their brochure, they now use AG Glass which I think came in at around 1.0U, so its probably better to go to a wholesaler so that you can pick and choose frame and glass.
Garage conversion internal wall insulation
MikeGrahamT21 replied to tvrulesme's topic in Heat Insulation
Yeah its a good one, where this came from- 6 replies
- solid walls
- insulation
- 6 replies
- solid walls
- insulation
- 6 replies
- solid walls
- insulation
I know me too, thats half my problem! I've pondered battery storage for the past 4 years lol
That would be possible technically. I'll have a ponder about it
I thought about that too, but for the cost and complication it seemed a waste, i barely use any hot water anyway, like literally about £2 in gas per month's worth. For me it would make more sense to bring electric usage down. I suppose the gamble is whether future prices will drop, from past experience electric and gas tend to go up but not come back down again
I've nothing currently to divert it to, don't have a hot water tank, it would have to be a battery. Its something i've thought about for a long time, now electric prices have shot up its more feasible, was hoping prices may come down a bit and tech may improve, but that hasn't happened yet. My only niggle at the moment is the standing charge which has also shot up!
I export a silly amount of my generation, probably around 75% looking at the figures on my smart meter since april. Whats the reasoning behind isolating battery discharge? is that for DNO compatability? I'd like battery storage available during the day too to cover additional loading above generation if possible as part of the solution. The existing solar array and inverter would have to remain unchanged for the FiT to remain.
Couple of points... Your 100mm studs, should be installed with 75mm foil PIR to give a 25mm air gap to the inside so the foil works. Don't put a vapour barrier on either side. The Foil will act as the barrier, just tape over the studs with foil tape.- 6 replies
- solid walls
- insulation
Can you have a second non-fit install without disturbing anything for the FiT? I've a nice south facing utility which could house 6 panels, could go hybrid inverter and maybe battery, but can it all be linked into the existing panels too for energy storage? or too complicated? I guess a DNO application would be needed too over 4kWp?
Have a look here: https://www.itstechnologies.shop/collections/single-solar-panel-order/single-panel
