MikeGrahamT21
Everything posted by MikeGrahamT21
Cost of airtightness retrofit?
MikeGrahamT21 replied to anonymous's topic in Energy Efficient & Sustainable Design Concepts
They are, but its better to be safe than sorry. Boilers (and any gas appliance) shouldn't be operational in negative pressure atmospheres -
And don't forget to turn off your gas appliances, including boiler! -
Building regs drawings needed - Any reccomendations?
MikeGrahamT21 replied to NickK's topic in Building Regulations
Yes I had SE to specify foundation spec, lintels and roof fixings though BC never asked for this, so what you see on the plans is what got passed by BC. When you dig out for foundations you get them to inspect, and they'll tell you there and then if they need to be deeper etc, though as long as the ground is solid then you are good. Foundations on this particular build were slightly narrower than normal to save on concrete, was viable due to low loads, generally you would have 150mm overhang on the concrete either side of your walls -
Take a look in my blog, may give you some pointers to draw your own plans like I have done many times over the years. It’s not easy, but certainly doable. Get yourself a house builders bible book, great book to have to hand! good luck if you go for it! -
Morning All, So I'm on the feed in tarriff as i'm sure many of you are, from around 2016 time. Majority of us, me included would be on a deemed 50% export rate of around 5p/kWh. Obviously there is also the newer SEG which was introduced, and Octopus Energy take that even further by paying a fixed 15p/kWh or an agile rate based upon market rates. Now up until recently, I thought if you were to move to the SEG, you would have to give up your Feed In Tarriff, which would have been a big no-no, however I have since learned that you can split off your Export, leaving your Generation Tarriff fully intact. So I have signed up for Octopus Outgoing Agile, and they are currently creating me a new unique MPAN for export only. I'll give Agile a shot, and if it doesn't pay, i'll go for the fixed rate. Even with the battery storage i'm still exporting a lot, so this should pay dividends. Not sure if this is common knowlegde, or if i'm just a bit late to the party. https://octopus.energy/outgoing/ From their blog: Under FiT guidelines, you get paid for being a generator, and paid for whatever you export. You won’t be able to receive FiT export payments whilst also being on the Outgoing Octopus tariff. However, you will still be able to receive your generation payments. When you sign up to the Outgoing Octopus, you will be required to opt out of your deemed export payments from your existing FiT supplier (but there’s no requirement to switch your FiT contract to Octopus.) For new installations (that is, after the FiT closure date of 1/4/2019) we’ll still require a copy of your Microgeneration Certificate Scheme (MSC) certification in order to get you onto the tariff. 50% Deemed was one option under FiT for getting paid for your export. This is often the case where an export meter wasn’t fitted and so it is was assumed that 50% of the solar energy generated would be exported (the other 50% being consumed). This is calculated from the installed potential output of the solar panels at the time of install. You may find you are still better off keeping the Deemed 50% than switching to Outgoing Octopus - for example if in fact you are exporting only 20%, or if the solar panels aren’t optimally oriented to supply the potential output or have deteriorated over several years. As the FiT Export rate is now 5.38pence and our flat rate is 15 pence then you are better off with Outgoing Octopus if (average over the year) you export more than around 50% of the installed capability. Hope this helps someone out there!
- 5 replies
- solar pv
- feed in tariff
proof of postage? in terms of batteries they essentially just grab any spare energy which is grid bound, so the immersion will go first til it his temperature or end of schedule, and then the batteries will mop up anything thereafter, battery will always be the last thing to take energy and only if nothing else can be done with it
Self-centering internal pipe-cutter - for plastic
MikeGrahamT21 replied to ToughButterCup's topic in Tools & Equipment
https://www.amazon.co.uk/Superior-Tool-37516-Internal-Cutter-One/dp/B004Q05TTC ?? Or with a guide to help guage depth: https://www.reedmfgco.com/en/products/plastic-pipe-tools/internal-pipe-cutters/ -
I've a 1960's bungalow, temp in living room at midnight was 17.5C and by 6am was 15.5C giving a heat loss of 0.33C per hr. Room is very airtight, but still has double glazed window (approx 2.2-2.4Uw) and no external wall insulation on the external wall, approx u value of 0.45. I still need a further 50% energy savings to get to enerphit standard, so by no means a passivhaus.
New Velux triple glazed, frame condensation
MikeGrahamT21 replied to Sparrowhawk's topic in Skylights & Roof Windows
Mine are the 66 variety, and painted rather than PU. Its currently -4C outside, room is 15.8C and 51% RH and i've nothing on mine, just ice on the outside. Your window seals haven't been adjusted right, you see where its kind of folding back on itself on the right, you need to pull the top seal to the left to get this out. The strip of condensation on the straight bit is odd tho, must be something different there for it to collect in that specific place, and it'll likely be installation. -
Refurbish or replace UPVC bay window?
MikeGrahamT21 replied to Sparrowhawk's topic in Windows & Glazing
You’d definitely get a performance increase from what you have now (likely air filled DG with aluminium spacer) to (argon filled DG with plastic spacer), but glass prices are high at the moment. Definitely replace the gaskets, adjust the locking mechanisms and take out any beading which has air leakage, it may have just been installed incorrectly (I found this on one of mine, a bit of packer was in the way preventing it from driving home), if the beading is damaged a local window firm should be able to get some, it looks like standard stuff to me, and after all that there’s window film which can achieve some of the low emissivity benefits, and that little lot shouldn’t cost too much. also removing the trims and quadrants can uncover bad jobs which can easily be improved with a bit of time and effort. a few of us on here have used this company, including me, their prices seem fair and you can play about on their website to get quotes without having to go all in…https://www.modernupvcwindows.co.uk -
From what i've read previously, you'll definitely need to pay the VAT, which you'll reclaim at the end of the project. Not totally sure about Duty. Have a read of this: https://www.theguardian.com/money/2021/jan/21/eu-website-purchases-the-import-charges-uk-customers-have-to-pay And a calculator https://customsinsights.co.uk/duty-vat-costs/
Help, mould appearing in 5 year old house
MikeGrahamT21 replied to CBScotland's topic in Introduce Yourself
Yeah you should have a 10 year NHBC warranty, pretty sure thats standard and required (someone correct me if its not). Mould is a serious issue for human health, so needs a permanent fix which in itself is guaranteed EDIT: Yeah thats right... https://www.bellway.co.uk/buying-with-bellway/warranty-and-insurance-protection -
If its a big developer house it'll still be under warranty for another 5 years, this should be directed at them rather than attempting a fix yourself. -
That might not be the case. I had the same thought about my bathroom window, I have just had a lean to extension on the side of the bungalow so they needed concrete lintels installing for the additional load, and when the builders took the bricks out they found a steel angle lintel, it was just small enough you couldn't see anything was there. Stick a drill in the mortar directly above the timber, and you should eventually hit metal.
Mobile Phone Reception issue?
MikeGrahamT21 replied to ashthekid's topic in Networks, AV, Security & Automation
Yeah its always been pretty decent here, though the mast is at the top of the hill and slightly down other side, i live in the valley, so its not really close as such. Certainly didn't notice any drop in strength. The aircrete definitely kills WiFi though!! -
I haven’t had any issues with the foil backed, entire house has it in the ceilings/roof, for me I noticed the issue in just 2 of my extensions, both of which were built using aircrete/AAC blocks…I assumed it may be to do with the aluminium powder they use when making them to get the bubbles? -
concentrate on the fine details and plan everything in advance, that way you get a whole house fabric first approach. Good Luck!
Layering is fine, and generally a good idea. Kooltherm is the best product for getting a lower u value, and has 150kPa compressive strength, so it depends on what weight you are putting on the floor. 150kPa converts to around 15ton per m2, which would be an immense load to have on a floor. K8 their cavity product has a CS of 100kPa, so will be around 10ton per m2.
Small patch job, for oldies.
MikeGrahamT21 replied to zoothorn's topic in General Construction Issues
A cheaper alternative which will still more than do the job is HardieBacker Board (B&Q/Wickes) and also good for the tiles to stick to too and you can glue some PIR to the back of it. If you make a small frame perhaps out of 3x1 fixed to the back of the cream bit, either with screws or glue, and then screw the backboard to the same frame, intumescent silicone to fill the gap and then your tiles onto the board… if I’ve understood your project right -
Sealing skirting board to click vinyl flooring
MikeGrahamT21 replied to WWilts's topic in Heat Insulation
There are plenty of Hybrid silicone/adhesives these days which are also paintable but will stretch with the expansion/contraction. id go for one of these if I were doing that task -
Correcting Course Heights
MikeGrahamT21 replied to BadgerBadger's topic in Bricklaying, Blockwork & Mortar
Id say 40mm is too much personally. How about some kind of detail before you start above DPC? Maybe slate? Terracotta? Not entirely sure what would be suitable from a compressive strength POV. -
Should I go with an MVHR?
MikeGrahamT21 replied to anonymous's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Currently no plans for changing the gas boiler which is almost brand new and still under warranty. I’ve 3 more sections of external wall insulation to complete and 1 more window to swap out for triple glazing which should do a lot of the heavy lifting.
