TonyT
    6
Everything posted by TonyT
  1. Didn’t see a tundish?
  2. What kind of hot water cylinder is that? is it unvented?
  3. The pipe is too long, max length is 3 m for 40mm pipe from the stack/110mm pipe needs ripping out and starting again
  4. Air lock Keep topping up and bleeding the rads..
  5. Cut more Of the carcass out, fit pipework, rebox to tidy up
  6. Cost per kWh gas is about a quarter of the price of electricity
  7. Use a notched trowel
  8. Wouldn’t a 4G router and normal Wi-Fi camera work, add a 12 volt battery, 230 volt inverter, solar charge controller and panel and away you go
  9. I doubt he’s coming back. if you haven’t held back a retention payment, best put efforts into someone else it will be more productive
  10. I doubt the contractor will be interested. you did some work he did some work, if you haven’t paid in full that’s a bit different as you have some leverage
  11. If you have no glycol you should have anti freeze valves. Is there another zone that isn’t getting tiled that can let the heat pump work? Get in writing what the process is for re introducing the heat, how many degree per day over what period might save a lot of grief later… good luck
  12. The display screen regulations or whatever nonsense it’s called now wouldn’t allow the moon landing now , no wrist support, no foot support, no 5 star wheely chair, breaks every hour away from the screen…
  13. Mark hole. drill 8mm hole, follow instructions get 6mm rod- Screwfix sell it for under £5 resin into hole, filling from the back to front, fit bracket, twist rod into hole filled with resin fit nut to rod and tighten
  14. What’s on the other side of the wall, any down pipes, gutters?
  15. Use resin and screwed rod, and put nut on it once bracket in place.
  16. Tapo smart plugs on amazon You get the energy version, lets you see power used at the current time or energy over the period it’s switched on. youbcan set schedules for in and off times, has manual override great kit less than £15 each used mine to switch on heaters in an off peak situation for 1 year now, no issues
  17. Fill the crack to stop further water ingress. Run a fan or dehumidifier to help dry out the wall
  18. you get switches to mute alarms that are fitted at low level
  19. You could use tar paper like a lot of flooring contractors use, approx 1mm thick, paper tar paper on a roll
  20. 1.9Deg C where I am, can’t be bothered with the stove tonight, burning gas instead!
  21. We are trying to subdivide the installation into smaller safer components to minimise lots of issues. i cant see the drama in a switched fused spur and it doesn’t then get switched off.
  22. IET. Means of isolation should be provided at the origin, for every circuit, for every item of equipment, for every motor, for every supply. all current using equipment requiring control shall be controlled by a switch Me. switched fused spur just makes sense
  23. New central heating is invasive so is a full rewire
  24. Only time I fit fuse non switches spurs would be intruder alarms, fire alarms, equipment in bathrooms, everything else is a switched fused spur. But you are the home owner expert, so find another spark if you aren’t happy
