Roundtuit
Everything posted by Roundtuit
I think it's to cover a worst case scenario i.e. a fire in the flue generating abnormal temperatures.
As above: I used cement board at loft joist level (fixed to joists, with a hole cut in it for flue, assembled in two halves) sealed with fireproof mastic around the twin wall flue and across the joint, and then taped the airtight membrane to the cement board at a safe distance fron the flue.
If it all hinges on getting planning permission on the paddock, then that's the place to start! Or maybe you're further on in the process... what soil do you need to dig?
Do I Need Even more Insulation? Decision needed within next 24hrs
Roundtuit replied to peekay's topic in Heat Insulation
I'm not familiar with that sort of wall build-up, but the 50mm plasterboard and 150mm pir sound fairly decent. If it's timber frame, I suspect any cavity should be ventilated, but doesn't that render the external 90mm eps redundant? -
Some pilers do. We had an assumed depth of 10m, plus additional cost for deeper, and a few quid off if it was less.
My local BM is coming in at twice that price for 6mm 2400 x 1200 sheets; any tips on sourcing cheaper please?
Old patio freshly repointed
Roundtuit replied to AidanGee93's topic in Landscaping, Decking & Patios
Difficult to tell from the pics, but I'd guess it's not deep enough. Don't know what best practice is, but I'd be looking for maybe 15mm plus. -
I'd have a look at Witham Timber in Boston. I haven't used them personally, but suspect you'd get a good deal on that volume.
Looks like you haven't made it easy for yourself 🙂 Traditionalists would have made a square opening I think. How about squaring off the height with some sort of lintel at around the same level as the soffit. That will give you a bit of space to play with. I'd run the tracks down the back of the door piers to maintain opening width and avoid damage.
Welcome aboard. Ask away and chip-in where you can. Every day's a school day!
Ask away! There's usually someone here who's done it, made a b@lls of it and then found the right way!
Top photo looks similar to Vandersanden Old Farmhouse.
Replacing Hyundai Brush cutter. Is Stihl the only option.
Roundtuit replied to flanagaj's topic in Tools & Equipment
Tanaka. I've abused one for 5 years (with v heavy use in Yr 1) never been serviced and guaranteed to start on the third pull every time. 2 year warranty for commercial use and 5 years for domestic; I think that says something about build quality. -
Our rainwater runs to a dyke. There didn't seem to be any advantage in putting it into a lined pond as its not going to soak away effectively, and I didn't want an unlined soakaway that dries out in summer. Also, I built it several years after moving in, so conflict with newts and house construction. April 2021 June 2023
Yes. I planned a wildlife pond (no fish) to increase biodiversity, to try and soften the blow of developing what was an overgrown 'natural' plot. I don't remember it attracting comments either way at the planning stage tbh, but I like it. We have a healthy newt population but not seen GCN yet. I think all self builders should build a GCN pond/bat box/dormouse hostel if they have the space, then maybe we can get the effing things off the protected list!
A few thoughts here:
Russwood do a factory treated fire retardant/ Sioo-X combination that might be worth a look, and maybe something like their Scotlarch or Thermopine?
This is taking the P..... surely?
Roundtuit replied to kandgmitchell's topic in General Self Build & DIY Discussion
I know what you mean. It's not big things, but it's about treating other people's stuff with a bit of respect. As galling as it was, I came to the conclusion that I should expect everything on site to be considered as 'theirs to use' by trades. My wheelbarrow went off to another job and never came back. Plumbers left used teabags every where and burnt rubbish on site. Brickies even cut my broom handle down to use as a pointing tool ffs... -
Large van or dropside truck?
Roundtuit replied to flanagaj's topic in General Self Build & DIY Discussion
Agreed. I had a £1800 Transit Connect for the duration of the build, used daily too and from work and picking up stuff from merchants. Stick some roof bars on and you've got most eventualities covered. Just get aggregates delivered; if you've got an account with a merchant delivery is likely f.o.c. -
Our planning permission stipulated finished floor level as 300mm above the road level. As above; get the house built first, then landscape as necessary. Build up any driveways with stone not topsoil, and consider banking-up ground around the house rather than trying to raise the whole site.
Recommendations for good landscaping rake
Roundtuit replied to machtucker's topic in Landscaping, Decking & Patios
Turn your tarmac rake over and use the back maybe? -
Wow; that's a self-build story! If I'm reading correctly, you've paid the extra cost, it's in a livable condition and you're considering how to get some cash back after being screwed-over? Sorry, cant help with specifics, but first thought would be that getting money back once paid - i.e effectively having agreed it's due - is going to be a challenge, and second thought is that it's a job for legal professionals. Many of us have ended up spending more than we'd planned one way or another, but I hope you've got the home you wanted. Only you can judge, but I'd be weighing up the potential gain, and cost of gaining it, against the benefits of writing it off to experience, drawing a line under it and moving on.
Perhaps they were originally planning to keep the property - annexe or holiday let maybe, so a separate water supply wasn't required. Not deliberately dodgy, but agreed, it needs sorting now. Water Authority asset maps can be a bit sketchy I believe. As you're already invested in this, perhaps start a conversation with your water supplier to try an get an indication of the implications and cost for a new supply.
