Roundtuit
Everything posted by Roundtuit
On the basis that the additional changes and dicking about probably cost your builder* more than the marginal saving in materials, I'd suggest just paying up. * 'specialist window/door company': are we talking conservatory?
Pack the reveals a bit. You may have to pack around fitting brackets anyway. Or use 15mm plasterboard + skim and take your time taping to be accurate.
Hi Henry. Welcome aboard. Plenty of experience here in renovation and garden buildings so ask away and chip-in where you can!
- 1 reply
As above, graphite spray is recommended for locks I believe as it's 'dry' once the carrier has evaporated so doesn't get gummed up with dust and crap. I got some hideously expensive Interflon stuff, but only ever use it for locks/hinges/window mechanisms so it lasts OK.
That's the stuff for the job. Thin is good so it folds round the battens reasonably neatly. It does fray so doesn't want a lot of handling, but once cut, stapled and clad, it's not going to be a problem. As @Russdl says, be prepared to to be spiked by it, even through gloves...
Have my drains been built incorrectly, & what should I do?
Roundtuit replied to Tony L's topic in Waste & Sewerage
Sounds like you need a bit of a re-set with your builder. Looking at your posts re: drains and brickwork, I'd have to say his work looks a bit $h!t, and you're obviously lacking confidence and trust in him. Has he under-priced the job maybe, and is trying to claw some money back? Over-committed and trying to save some time? Bitten off more than he can chew in terms of competence? You've got a long way to go with your build, so for the sake of your sanity I'd suggest you need to get the relationship back on track or part company (as difficult as that might be either way...) -
Yes, folded up behind the battens. It was on to blockwork with a cavity, so I didn't bother with a membrane. I'll be doing another one in the not-to-distant future on a timber frame and plan to slide the lead under the membrane. You can just see the lead on this:
Call this an engineering report....
Roundtuit replied to ThomasB's topic in General Structural Issues
I experienced what sounds like a similar relationship with architects and topo surveyors: jobs for the boys.... Was there a spec for the inspection? Not sure there's much you can do, but if it's that poor I'd be expressing my disappointment with the quality of the report, looking for an alternative builder, and maybe thinking about having a chat with whatever professional body the SE is registered with. -
That's going to limit your audience a bit I'm afraid. Whilst we're lucky enough to have a number of professionals who keep us on track, this is more where the half-a$$ed amateurs hang out when we're not trying to rectify the last job.
How do I remove buried chicken wire
Roundtuit replied to AliG's topic in Landscaping, Decking & Patios
Probably. Depending on gauge and condition, you can get through it with a spade and some determination! -
Mini-digger to scrat it out, or just leave it in and work round it. I've done a bit of both; less disruptive to leave it in to rust away if you can. -
Entry 10: Redundancy helps progress
Roundtuit commented on BotusBuild's blog entry in South East Cornwall Low Energy build
Sometimes life throws the reset switch and gives you the space to re-evaluate and go again; well done for embracing it! Great progress on the house; love the manifold! -
Things that seem a good idea
Roundtuit replied to Pocster's topic in General Self Build & DIY Discussion
Ah...you're the one that uses them! Got a box full of unused ones somewhere I think if you need some 😄 -
Advice on distortion to roof
Roundtuit replied to queryinghomebuyer's topic in Roofing, Tiling & Slating
It's not unusual to see some deflection in old roof timbers, particularly where the original slates or clay tiles have been replaced with heavier concrete tiles. Assuming there's no need to replace the roof, then maybe all it needs is some additional internal bracing to stop any more deflection. -
Agreed. There isn't a 'need' as the ashp is more than capable, but lighting the stove and banging some extra heat into the house of a winters evening does lighten the load on the Smart meter the next morning.
Mvhr funny noises and dripping
Roundtuit replied to Pocster's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Should only be condensate at the fresh air intake side I think, unless there is anything dripping back from the exhaust where it passes through a cold loft space maybe. -
Is the unit level? Does it need tilting a fraction toward the drain? -
The only time I've had dripping and funny noises is when the condensate drain was blocked with biofilm snot and water built up to the fan blades. Now temperatures have dropped condensate levels will have increased. Have you checked inside the unit to make sure condensate is flowing away OK? -
Convince me I can put a roof on...
Roundtuit replied to Roundtuit's topic in Roofing, Tiling & Slating
Yes, but I'd like a more traditional look, and to match the house I think mortar-bedded is the way to go. I realise it will be slower and more challenging though. -
I've now got a garage frame up, and I'm seriously considering roofing it myself as a) I'd like to save a few quid, and b) I'm weary of the whole world of disappointment that trying to get someone else to do work often involves. So: approx 120 sq m, interlocking clay pantiles, fully hipped, mortar-bedded hips and ridges. How hard can it be?
So, 12 months on, the over-priced Hitachi-approved replacement part has failed and I'm back to square one. Before I get stroppy with the supplier, is there any potential underlying cause of failure I need to investigate?
Air vent not stopping mould
Roundtuit replied to bobbydave's topic in Lofts, Dormers & Loft Conversions
Condensation occurs where warm humid air hits a cold surface. I'd be looking at upgrading the insulation. -
Whatever you choose, I'd make sure they're A1-S1-T1 rated, and don't underestimate the competence of the roofer in ensuring longevity. I spent ages comparing colour, price, quality and availability and I'm pi$$ed-off at having 2 or 3 fail every year/18 months since install (5 years ago). No idea what the problem is, but at least the roofers are honouring the 10 Yr guarantee albeit in slow time...
