Oz07
Everything posted by Oz07
Also will 2 layers work over top of each other? ive seen some 15mm bore 25mm total thickness thought this was appropriate?
I thought insulation would be plenty as have done this with standpipe before. However have known pipes to freeze in houses but suppose they are unprotected. Any reason rodents would go for the insulation?
Got to pull a hot and cold down from a first floor ensuite, above an entry, down thru the entry back into wall at ground level. Has to go outside into entry for various reasons. I had assumed pipes could just be insulated as in foam lagging as thats what you see in outhouses. My plumber (although not having seen the job thinks it may freeze). Were in the midlands and the entry is closed of at one end (so no breeze thru), the pipe drops will be halfway down entry. I cannot imagine the water freezing in there if lagged but perhaps am being naive. We are in the midlands. What do you lot think?
That's how I understood it. Upto you what you do with the shell. Just found the constant reference to 2 bedroom throughout planning application statement and reports.
Departing from the CAD argument and back to the planning. If I have a dwelling which is 100m2 what are the implications of changing it from 2 bed to 3 bed. The approved plans show 2 bed with a space for 3rd bedroom but without the partition which would close off the space. The application went to committee, while parish recommended approval, planners recommended refusal. Application was eventually approved with reference to two bedroomed dwelling. Much reference was also made to two bedrooms and lack of smaller housing in village in the planning documents. If the dwelling isn't being made any larger can they refuse you a third bedroom? Could this bedroom just be referred to as office?! The house has 2 parking spaces shown which would be appropriate for 3 beds with this local authority.
Never mind the Flint get that art up on your wall
Yeh I though of another problem aswell. You couldn't use one either end as you'd be working between two fixed points. So it's either one of those on bottom and sleeve on top, or replace the lot. I'll have a look today see what I think.
I did a minor amendment or something called similar once. It was a cheap application and a quick decision. Had as the same problem as you so just submitted an app saying building 100mm larger all round due to increase in wall thickness to achieve better energy efficiency. Stated that all internal volumes/ room sizes to remain the same. Just gave me peace of mind incase and smart arse surveyors got a tape out when I came to sell.
Any cheap place to buy Block and Beam floor please
Oz07 replied to anna's topic in Building Materials
Stressline but they're beans are always dog rough. Have an engineering brick on hand to smooth them down! -
Whether that fitting could be used upside down or would it be asking for trouble. If they're made to be water tight and stand a pressure test no reason they couldn't be used upside down?
It's not just a vent there's bends and connections above. Ill see if they're bothered about having a flex seal
http://www.plumbcenter.co.uk/product/floplast-sp140-universal-soil-pipe-connector-110mm-black-(pack-of-10)/?gclid=CK-47L7Ons8CFUgW0woddxoIMQ if this accepts the cast in the top, and will go into 110pvc this is what I'm after. Will look a lot neater than band seal
Will do ta
Oh no I don't mind putting a plastic branch in. It's just that the punters might think the band seals look a bit temporary. Specifically on about the fittings to join the two
Apart from flex seals / couplers is there a better looking fitting for connecting cast to PVC then back to cast. Something like a multiquick i I have to interrupt a cast iron stench pipe with a PVC 90 branch so would need 2 different fittings presumably. One to take PVC in female and one to take cast in female.
Ps well done on the art work don't show heritage England!
Water board are notorious for finding something wrong with what you've done. Or something additional for you to do. In your case I gather you already have a water supply so don't need them to approve before you connect? anyway take photos of the trench, tell him it's 4" duct and where you bring it up into house use a bit of 4" drain
If no inspection by water board then don't worry your duct size will be fine. If it's thru it's thru
Ha! Bet they'd like it the other way round then?!
I still think parish councils should lose their 106 contributions if they take you to committee and lose. Around here they take you to committee on grounds which are not even really valid. Then you get a full vote for permission at committee but delay of 2/3months.
i wouldn't worry about it if it was being covered and has reinforcement.
Theres also maximum bay sizes with certain types of concrete. The agilia mix I usually use for instance. Like you say, a neat saw cut following on from a nib or wall, or in the centre of a room looks proper, a wonky crack doesn't
Conventionally it's just there too control cracking. You might get away without if steel reinforced. I put them in at every weak point. Doorway etc. Also try and split tiled rooms with the direction you will be tiling. If theres no ufh then no reason not to put in for how long they take
Had to leave a 600x1200 section out of boarding for stairwell to be done other month. Said to plasterer, who also boarded, when you've skimmed stairwell don't forget to insulate that section before u board and skim. All other partitions had been filled with rock wool of which we had a few slabs left. Also just by chance had a piece of celotex knocking around near enough that size. What do u think the genius put in the wall?!? just shows what your dealing with
De Ja Vu, The regs state the level of sound which must not pass thru, not how you achieve it. Posi joists comply on their own in England, without need for wool in most cases. I'm all for 50mm of wool as above as this fits neatly between top/bottom chords and out the way of services. 42db from memory
