Everything posted by craig
Sounds good in theory, but you don't have the wall depth. The actual depth of a triple track system is circa 250mm, so if you have a wall depth of 350mm for example you have 100mm for structure and finishes and insulation. Your slider would in effect be 4 leafs at 1980, as it needs the space within the wall of the relevant depth. The triple track option isn't feasible to be completely honest. Start looking at a compromise.
No, they aren't impossible, however. You need to have the relevant wall depth available to accommodate them and you need to have the relevant wall width to accept the sliding door sashes sliding inside the wall. For example, a 2m sliding section, will require a length of wall in excess of 2m to accommodate. It's not something we have actually done "yet" but not because of not wanting to, It's a standard system from our supplier.
MBC Frame - Windows - When to order ?
craig replied to bob the builder 2's topic in Windows & Glazing
Which in my experience, no one wants to take responsibility for and or advises that the issue is the window/door suppliers problem for not allowing the relevant tolerance in the first place. Which to be fair is a valid point, however, obtaining the deflection in the first instance can be like getting a needle from a haystack. Usually the simplest solution is to just jack things up a touch (just enough) to get the clearance for smooth operation to occur and then fixed the unit again in that position. It invariably falls onto the window/door supplier and isn't always there fault. -
Yes, I haven't used them yet but a supplier we are in talks with at the moment manufactures the profiles from Aluprof. From all the technical data, drawings, pictures etc. that I have, they're a good aluminium window. This is the Ferroline range This is the MB104 passive range There are other ranges as well.
Classic case of deflection here. Not enough tolerance has been allowed been the door and the steel. Steel has deflected, most likely PU foam which turns solid has been used for installation/insultation. The steel has deflected, pushing down on the PU foam which can only push down on the frame of the corner opening bi fold which will not be a load bearing item. I can only think of two solutions. However, before this, take a level (laser preferably) and check. Speak to the bi fold supplier and find out what the measurement from the bottom track to the top track should be and measure it - you should be able to check this at each hinge side (wall side) of the bi fold. It will all lead to a weight bearing issue from the deflection from above in the corner - that is what I highly suspect has occurred. Solution 1: Open up above the bi fold, scoop out all the PU foam (that's what I presume has been used) and replace it with compriband only which is compressible. So when deflection occurs, it deflects into something that compresses so it doesn't push the top track of the bi fold down. Solution 2: Acro prop, push the roof back up (only slightly, you're only looking to get approx. 5mm). Look in the top tracks of the corner of the bi fold for a couple of locations you can pop 2 long screws in either side. Acro propping this up allows the screws to fix the item in place. Rather than trying to put the screws in an pulling the track up (which won't work). If you don't have an acro prop a car jack and a 2x2 and an another bit of timber to put between the ceiling and the 2x2 to try and prevent any damage to the ceiling. In my honest opinion and looking at the pictures, this is the only remedies I can think off. -
What system? Supplier? I would be expecting flush finish, no gaps. Knowing system, supplier, it would be fairy easy to check drawings.
Hi Meabh, For your project, speak to Fakro - they should be able to achieve what you're looking for.
Problems with glazing fitted into green oak frame
craig replied to Robert Clark's topic in Windows & Glazing
You’re right my bad for not zooming in on the phone 🤦♂️ If it was straight into the fabric yes, but not in this scenario (clearly framed and beaded now I have zoomed in). Might even be possible that joiner has made these frames. Beading looks like edge bead? -
4/6/4/6/4 glazing unit. I’m going out on a limb here and saying he hasn’t ordered with Krypton filling. I’m also assuming Planitherm One as coating but unlikely and needs specs to be sure. Which he will need to provide. 1.2W/m2K argon filled 90% Yes but here there is no window frame, it is glass in the building framework and would pass. Optimal for Argon and Krypton is 18mm, larger gaps create convection. Current building regs is 1.6W/m2K for windows, changing in June to 1.4W/m/K -
Rain water coming in between window and window cil
craig replied to mfmcdonagh's topic in Windows & Glazing
Having the stub cill basically expels the water out and away from, the window. Sealing underneath to prevent any water ingress into the house. -
Usually not when face drained, bottom drained yes but these are face drained, but I'd be expecting a stub cill for both options tbh. -
I don't know the system used but I presume uPVC, you have no stub cill and you have zero sealant between the window and the stone cill. The mitred welds don't look that great either from the picture. Solve the issue of the seal between the stone cill and the window and your problem should be resolved, was there any DPC installed? I also don't see any mastic running vertically between window and render? What have they done here? I'd go back to the supplier/manufacturer and ask them for the cill detail. -
Even sliding doors like the visioglide should be able to handle that. Bottom line, it's down to poor choices in the hardware/design if it cannot take the weight for a triple glazed 6m door.
I'd like to see a picture from the outside with a clear picture of the gap at the bottom but it looks like their has been no sealant added at all. It also looks like the window is sitting directly on the stone cill with no upstand for fitting a stub cill? -
What Nick said.
Design loadings of first floor low level windows
craig replied to Dan F's topic in Windows & Glazing
They are, I supplied them 😉 -
Fingers crossed, if I need to go back to the glass manufacturer/supplier I will but current info indicates it should be everything that's needed. -
Nothing as far I know, other than the specs dictate inner and outer should be the same size for barrier loading. -
Don't know the answer to that I'm afraid but regs are clear that either or is fine. -
I'll put my hands up, this is for me. The glass is all marked with the EN norm 1279:5 and EN:12150-2 but the documents which have been supplied haven't been accepted (yet) and I'm not entirely certain why but the BC may be wanting an exact report. Exactly, to be honest, all the BC should need to do is look at the glass, the CE performance declaration if/when supplied and the glass datasheets for the EN norm of 1279-5 and that should be sufficient. Doesn't actually take away from them being robust though and stringent, which is a good thing. A pain in the ass but a good thing. The inner and outer pane should match in thickness (as close as possible) and your 4mm should be 6mm. I disagreed with a structural engineer recently, he was insisting that we should be adhering to table A3 and for some units, it should be 8mm outer, 8mm inner and in some cases 10mm inner/outer. The client has to pay for this at the end of the day and when it was highlighted that he was wrong and using the wrong table. He fully accepted that the correct table is A4. The only thing he disagreed with, was my take on the m2 requirements going from 4+4 to 6+6 for example. I say it's from and to i.e. 0.15m2 for 4+4 to 3.2m2 - he says that if it's above 0.15m2, it needs to be 6mm glass. Just for a side note at 0.15m2 for the glass unit, we're looking at 390mm x 390mm and anything above that needs to be 6mm to act as a barrier. Which is wrong IMHO. I'm not a specialist on the subject, but hopefully, the issue should be resolved fairly soon. No, toughened both sides is fine for class 2 building occupancy (a house). -
We’re dropping 2g next year, just won’t be available from us.
